Posts posted by pbaines
I began to start looking around for the bolt on bits for the water lines, alternator bracket/alternator to get the motor supplied with the car going however another motor popped up removed from an AE85 as a complete running motor. to save me the mucking around sorting the supplied motor, thought it would be a heck of a lot easier just to use this new one!
Out came the old motor
20210401_105010 by phillipbaines, on FlickrIn went the new motor
20210401_123656 by phillipbaines, on Flickr20210401_124106 by phillipbaines, on Flickr
I'm happy I chose to get the AE86 EFI wiring which differs from AE85 because I literally just plugged everything in. And it started pretty much first pop (had to replace ECU and set timing). For anyone doing an AE85 -> AE86 conversion. don't fuck around with the AE85 wiring. spend a few pennies and get an AE86 loom. it will save you days of prodding and poking around
20210402_191222 by phillipbaines, on Flickr
Now that this is going i'm going to book some time with my fab guy in the next few weeks to get the seat mounts sorted and also get an exhaust made. As per the video. she's just heading straight out the coby's at the moment.. heh
Parts on the way:
Parts Shop Max rear coil overs (spring/shock full coil over, replaces separate shock/spring)
BC Gold front coil overs complete
AE86 zenki 24mm rear axles
T series diff head
rear drive shaft of the 2 piece from Japan
KAAZ 2-way LSD New from JapanTODO:
Buy new wheels. this isn't a rally car anymoreOnce those arrive, it'll be time to drive it down the road!
Project discussion:
- 7
This car has laid dormant for a while.
Back before when this was N/A...I had low oil pressure. I mean there was some oil pressure, I could drive it around but it never was as high as it should be. I had to swap the sump over on the motor for the turbo drain so out came the motor, thought i'd check the bearing caps. they weren't perfect and not perfect on a motor that had done 1500 k's since rebuild was not good enough. Took the short block in to the machine shop. Turns out the thrust tolerance was too loose and it was loosing a lot of oil pressure out of there. This was a good find. I had to get the block line bored too. that was expensive.
Anyway, $4000 later for a short block rebuild. should be safe to run now. i'm just excited to have everything back and now progress is taking shape20210124_172456 by phillipbaines, on Flickr
How the cars been sitting for the past 6 months... booo
20210331_114925 by phillipbaines, on FlickrThe motor went back in
20210331_162024 by phillipbaines, on FlickrI paid the front bar a nice white.
20210331_162040 by phillipbaines, on Flickr20210331_174441 by phillipbaines, on Flickr
20210331_174505 by phillipbaines, on Flickr
Yes, i'll fix the bumper. it annoys me too
20210331_174922 by phillipbaines, on Flickr
Next, i'm getting the throttle body modified to get a ISCV sorted for it to be controlled by the ecu
Then I save some money and take it to NZ Wiring in Petone to get tuned.Discussion:
13 hours ago, CUL8R said:
I appreciate your eyeballs but that's an AE85 S series diff, the same one i have now :)
A few months ago a little rusty nugget was presented to me for sale and I couldn't help but add it to my fleet (I really shouldn't have but sometimes you just can't say no...)
20201122_190825 by phillipbaines, on Flickr
109925324_2747433878821944_9009724047312886256_n by phillipbaines, on Flickr
I got it home, parked it up. forgot about it for 4 weeks whilst I waited for a few things to come from Japan.
20210321_143536 by phillipbaines, on Flickr
The wiring loom that was in the car was the stock AE85 loom which was hacked and fudged. I thought it would be much easier to start with a clean base so I bought a set of AE86 looms. Now I know where everything is, it has wiring for a fpump, has EFI relays and wiring. I can just put in a stock 4A-GE loom and get it going with ease
Cabin loom
20210321_110325 by phillipbaines, on FlickrEngine bay loom for headlights etc
20210321_105132 by phillipbaines, on FlickrLooking tidy enough
20210321_122314 by phillipbaines, on FlickrI've got everything there to get it going except a T series diff... (it has an S series diff so if anyone knows of a full T Series diff for AE86 I am a man in need)
Discussion:
- 19
Chat amongst yourselves.
Picture thread:
It's been an exciting few weeks getting updates on the car as more gets done.
Here's a drop of what's going on at the moment. Not long now!
To start with, I deloomed the original headlight hardness, removing odds and ends I won't use on there
- Ran another wire which controls the fog lights
- Relocated the battery wires to inside the cabin, the battery will sit under the passenger seat. I'll get a professional to do the rest from where I got it to
- Relocated the alternator wiring so that I can run it with the engine harness
99399211_272930263826147_7742833918717460480_n by phillipbaines, on Flickr
Decided to change the wastegate to a v-band style gate just for a bit more flexibility:
105598043_586600778717591_5386424791277872662_n by phillipbaines, on Flickr106187882_329482148055910_2925692963242702194_n by phillipbaines, on Flickr
105597849_266782644422515_6616275111710471338_n by phillipbaines, on Flickr
Dump pipe beginning to take shape:
105615022_644681836127246_411711451309123783_n by phillipbaines, on Flickr
105556436_270675250862943_1630855409840158444_n by phillipbaines, on Flickr
101563946_1663269867160856_6554872224073908224_n by phillipbaines, on Flickr105411255_719960381903781_5357733621582254053_n by phillipbaines, on Flickr
105704969_2980500301985349_1671724521810053650_n by phillipbaines, on Flickr
Bits and bobs:
101919373_692804254841049_2029492130350628864_n by phillipbaines, on Flickr106179327_3535786496441321_3516887240554195971_n by phillipbaines, on Flickr
105491203_307504940295190_1570212433508974404_n by phillipbaines, on Flickr
filter setup:
105522170_268305891113464_4252985428165995917_n by phillipbaines, on Flickr105587316_1689267811249447_1407559088842431286_n by phillipbaines, on Flickr
BOV to go here:
106248020_2354146954894435_1154358153800778069_n by phillipbaines, on FlickrMoney shot: hngggggg
106112383_3220843104625837_1220634764419048857_o by phillipbaines, on FlickrBig plug to Glenn, he's doing a bloody good job!
https://www.facebook.com/SyndicateFabrication/Discussions and feedback is always welcome
Just now, piazzanoob said:
just here to get some info.
is your rear end an f series with t series disc brakes? with mounting brackets swapped from t to f series?
please and thanks
currently asking as got a te71 disc t series rear end for a project but thinking f series would be better for handling the jandle and less cost of parts and using said of altezza LSD unit.
hilux just seems a bit overkill for many small old rwd toyota's
Okey dokey, here are the spec's!
F Series rear end
Shortened axles/housing (axles are cut, shortened, welded back together)
Redrilled to 4 x 114.3
S14 Silvia rear brakes
BMW E30 rotors Redrilled to 4 x 114.3
Hubcentric spares made up each side to fix the different hole size between BMW E30 bore.F Series is definitely the in between of T Series and G Series (Hilux). And will definitely handle Le Jandle more than T series. But if you don't plan on doing skids or drifts, late axle T Series will be just as sufficient.
Just now, Roman said:The front bumper really doesn't appreciate the slam but.. but pics!!
Alrighty
The car has undergone a few changes.Something that drastically needed attention was the rear spring perches on the diff. The diff is an F series out of a Liteace Van and had the AE86 mounts swapped on to it. What a great idea I thought! as I purchased this off TradeMe..
Check out the state of this. No idea what it did to the actual ride of the car being like this but it's always crippled my brain bones when I thought about it
95055142_2587530994857642_8016735613954818048_n by phillipbaines, on FlickrCut bracket off:
20200502_151932 by phillipbaines, on FlickrTack in better position:
20200502_153711 by phillipbaines, on Flickr
Glue in and appreciate the view:
20200504_134955 by phillipbaines, on FlickrAfter market cams from Auckland Cams have been acquired and installed:
Handee-Dandee printable cam degree wheel.
20200411_125318 by phillipbaines, on Flickr
I forgot to get a pic with the dial indicator gauge sitting in there for cool effects but.. they're dialed in!
They're a fast street.. turbo cam which leads me to my next photos
20200411_125336 by phillipbaines, on FlickrInto the shop she goes at Syndicate Fabrication in Feilding to get some bloowey stuff sorted:
20200509_123358 by phillipbaines, on FlickrI think i'll be relocated my battery..
96582311_1183989831941174_4131192127054938112_n by phillipbaines, on FlickrIntercooler mounting:
96234626_1335441543317696_5237312287865307136_n by phillipbaines, on Flickr
97052531_332330944406187_4372249077803384832_n by phillipbaines, on Flickr96801806_1065109070557228_3969570824079278080_n by phillipbaines, on Flickr
96754189_684652285666769_2128768315122778112_n by phillipbaines, on Flickr
97122736_600582834146913_7398048078931951616_n by phillipbaines, on Flickr
97041947_726147548188757_5675273285609193472_n by phillipbaines, on Flickr
97470685_196968697946098_5761960599114219520_n by phillipbaines, on Flickr
I'm excited, it's looking the tits, I will update as I get more pics!
Work done by:
https://www.facebook.com/SyndicateFabrication/Discussion:
- 17
34 minutes ago, maxted said:
nice car mate, some cool photos by the lake. be interested how much of a difference that underlay makes I need to do something similar had thought of getting some of that kilmat sound deadening or do something like what you have done
Cheers! I did the same thing to my KE30. It was well worth it, considering getting off cuts from a carpet shop (usually they're full pieces, not the dregs like I get) is free well worth it.
In terms of noise reduction, it juts makes the sound a bit more muffled, it doesn't cure cancer but it definitely makes a noticeable difference11 minutes ago, Mof said:Yeah tis nice
May I suggest you put the underlay on the trim panels rather than against the outer skin, leave an air gap. I'd be concerned about it soaking up condensation
The area attached to the outer skin is pretty plastic'y so can't really absorb too much but I will definitely keep an eye on that. There's a nice access hole below the rear door catch so easy to check
Thanks for the tip!- 1
Howdy fellow isolated friends.
I got my crossmember adjusted for my W55. I couldn't figure out where a vibration was coming from and narrowed it down to the driveshaft. Doing a UJ angle check I got it pretty much dialed in with spacers under the box to get it 2.5 deg on both ends, then got the member remade to sit where the spacers took it to
20200221_105825 by phillipbaines, on Flickr
I made a patch harness by cutting a plug out of another small port ECU. Got the Link to fire up the motor and had the timing set. I did't have time to get it tuned for Toyota Fest so ran the old ECU down. Least I know that I can start having a play with the Link once I have some time... like ISOLATION TIIIME!
20200223_195148 by phillipbaines, on Flickr
before the lock down we were lucky enough to head down to Toyota Fest for the weekend and what a treat that was. Such a good event and so grateful that Toyota put it on for us every year.
The car drove down with no issues at all, and drove up with no issues at all. I couldn't believe it!
Thrashed it around the track, thrashed it coming over the pass to Cromwell. drove it home easy.20200307_123559 by phillipbaines, on Flickr
20200307_151653 by phillipbaines, on Flickr
20200307_153252 by phillipbaines, on Flickr
Now that i'm back i'd like to increase the drivability.
I've installed the A/C compressor and A/C lines again, once the lock down is lifted i'll buy a new O Ring kit so I can put the new AirCon gas through it (i watched a YouTube vid on how to do it.. wish me luck!).
(no photo, oops)
Added some conduit over spaghetti junction under the guard, surprising something so little/cheap can make things 1000x better
20200326_123514 by phillipbaines, on Flickr
Before the lock down I went and got some offcuts of underlay. Shame, I just missed their dump of proper big sized pieces but ah well. chopping and sticking in puzzle sized pieces will still do the jerb.
20200326_143045 by phillipbaines, on Flickr
20200326_173129 by phillipbaines, on Flickr
20200327_144505 by phillipbaines, on Flickr
For places that are vertical i've used some double sided tape. my god it could stick a 50kg weight to a wall, it's the tits
20200327_145209 by phillipbaines, on Flickr
Puzzle completed
20200327_160001 by phillipbaines, on Flickr
20200327_164144 by phillipbaines, on Flickr
This was the work station.. pissing down with this rain but i'd rather knock my jobs out now
20200327_160053 by phillipbaines, on Flickr
Onto the front doors tomorrow, i'm not expecting silence but definitely less harsh doinks.
That's all for today
FB_IMG_1584328814380 by phillipbaines, on Flickr
Discussion:
It's been reasonably quiet in the past year. I've done next to nothing on this car...
since Toyota Fest last year:
Drive shaft remade/balanced
New rear hub centric rings for the rear discs. This was necessary due to the BMW rotors. I had the centres drilled out to be the same as the Longchamps on the rear. They're nice and snug. The Longchamps have a tapered centre bore so the spacers can't fall out..
Swapped in my 4A-GZE motor that's running on the stock small port ECU for now. Turbo time after Toyota Fest this year
Swapped in the original Intake Manifold, runs heaaaps better on the stock ECU which makes sense.
Replaced broken fuse box (exciting)
ae86-1 by phillipbaines, on Flickr
ae86-2 by phillipbaines, on Flickr
ae86-3 by phillipbaines, on Flickr
ae86-4 by phillipbaines, on Flickr
ae86-5 by phillipbaines, on Flickr
And FYI this is the shifter location with a Rear Shifter type W5X box using the SQEngineering sandwich plate with the T50 bell housing. Perfect
ae86-6 by phillipbaines, on FlickrI'm also looking for a replacement fiberglass bumper as mine is broke...
On 24/08/2019 at 22:02, kyteler said:
Nicely done man, only thing I would suggest is ditching the poo Ram-flo air filter.
what's wrong with the trusty ramflo's? I haven't heard anything bad about them before, curious!
This weekend I decided to go ask about getting some carpet underlay to whip under neath the carpet in the cabin to make it a bit more homely. Ended up getting a big slab of it for free! Thank god for useless offcuts..
I am no professional fitter by any means. it didn't really come out nice in 3 cut sections but it will all fit in well when the carpet goes back in
20190817_181032 by phillipbaines, on FlickrI also got sick of the awful looking dirt ridden seats that are impossible to find in any sort of 'good' condition so the cheapest fix is to show down to Super Cheap and get some car covers. Which look 10000% better,
20190817_143241 by phillipbaines, on Flickr20190817_152236 by phillipbaines, on Flickr
After installed, got some snaps. List hasn't changed since last weekend but now it's a bit more respectable.
3 by phillipbaines, on Flickr1 by phillipbaines, on Flickr
7 by phillipbaines, on Flickr
Build Discussion:
- 6
It's been a long time since i've done a post, because it's been a long time to get me motivated to install the wiper linkeages. I ended up just buying some M18 x 1.0 pitch nuts off ebay for $15, and a week later they arrived. instead of procrastinating about it for 4 months i really should have done it sooner....
Since last update:
Installed AE92 FX-GT front seat belts
Installed previous exhaust from old KE30 which is 2.5" to the extractors and a nice dumpy at the end
Rebuilt front brakes, it's nice when they work properly.
installed a new healthier 4K motor and went to a chinese carb from eBay that actually performs quite well. I will go with a weber 28/36 if I can find one but it's good for the interim
New Coils, plugs, leads, fuel filter (the other new one i bought has clogged up with garbage. Not surprised)
Installed 3.9 ratio diff head from a KE70 to fix it's awfully high revs with the 4.3
Fixed rust on the under chassis railTODO:
Fix brake pedal on the brake switch because sometimes it doesn't disengage
Get centers repainted on the SSR Mesh's
Get underside sand blasted and painted/under sealed
Find center trim chrome for rear lights
ugly photos. will get some nicer ones this weekend
I repainted the plates with satin black paint, it looks really good, I didn't completely sand it back to the bare metal which i'm actually happy about. makes it look a bit dated in a way with some of the left over paint overtop
Then I went to VTNZ. The guy loved it.
He also stuck something on my windscreen..
Time to fix the small issues with the car, and drive her around for a bit. happy with how it's come out in the end, proud for a first time project of this scale for it to have come out so well. Looking forward to starting on another!
Build discussion:
- 18
So, a lot has happened and the car is now running around again for the first time in a long time.
I decided that I didn't have time to get an after market ECU and tune sorted, but I did have time to buy a crashed FX-GT with a small port inside, which I could pinch the loom and ecu from and get this motor I have here running. I swapped in some stock small port cams. The stock ecu should handle the rest of the mods fine! so far so good anyways...
anywho:
Stock small port loom:
2019-02-17 15.20.50 by phillipbaines, on FlickrUnmasked, and all of the unnecessary stuff removed. Like the cold start circuitry, the alternator loom (AE86 run a separate loom from the engine loom from factory), the diagnostics plug (although would have been helpful, required a bit of extra effort to incorporate it with the original AE86 body loom), and I think that's it...:
2019-02-17 16.13.24 by phillipbaines, on FlickrI had a spare motor on the engine stand so dummied everything up against that then dropped the new small port loom in:
2019-02-24 16.24.57 by phillipbaines, on Flickrspaghetti junction down below to check that the engine works before taping and conduiting together
2019-02-24 16.25.06 by phillipbaines, on FlickrI made one big boo-boo on this swap and completely lost the body loom plug for the ECU. I definitely cut it and put it somewhere safe, the problem is that the safe place is even hidden from a 24-hour later Phil.... dammit. So I headshrinked the terminals over and just put them on the ecu terminals. they're in there fine and will not pop out but it still annoys me. Hopefully I can find another ECU plug at some point and do a proper job of it...
2019-03-09 07.45.28 by phillipbaines, on FlickrI went for a drive and forgot how low the dam thing was and sort of broke the front bumper over a small drain.. dammit. lucky it was just a cheap fibre glass one and can easily find a replacement. TODO at a later date.
Attached the front license plate, not in the middle as I was having problems on the track with head and thought I would get one last thing out of the way of the radiator. That was with a stock bumper so maybe this one will be better regardless
2019-03-24 18.52.04 by phillipbaines, on Flickrfilters on, dizzy lines looking pretty ecu. Need to mount the fuse box properly..
2019-03-24 18.52.18 by phillipbaines, on Flickr2019-03-24 18.57.12 by phillipbaines, on Flickr
2019-03-24 18.57.31 by phillipbaines, on Flickr
This is the vauum line, seems to be working okay. Blue line goes to FPR, small black line goes to the MAP sensor which works (the other one in the pic is broken and took me a while to diagnose! eurgh. other line goes to the brake booster. This should work fine going forward unless anyone has any suggestions of another way to do it??
2019-03-24 18.57.57 by phillipbaines, on FlickrRear long-boiz
2019-03-24 18.59.53 by phillipbaines, on FlickrFront long-boiz (I am getting new tyres on the front with less wall so they'll match the rear better)
2019-03-24 19.00.04 by phillipbaines, on Flickrfirst sort of run underway, yes the timing belt was a bit tight, that's since been fixed. I'll get a proper video of it running once it's proven itself to be good
On to Toyota Festival!
Discussion:
Looking to get a KE30 shell to Dunedin from Palmersron North. Unlikely it'll have brakes hooked up but can be done.
Also looking to get a car from Christchurch to Auckland
Which transport companies do people recommend? Especially for a bare rolling car
I have seen a thread about this but I'm daft and can't find it...
On 27/12/2018 at 10:10, 79starlet said:
Hey mate any chance you could help me out getting some KE26 Monsoons like yours? It's a 2 door so just after the front door which should be the same as a KE25 coupe. Looks rad as so far man!
Potentially... it's hard to find for the two door KE20, KE25, KE26 but if i do some across some i will let you know
Getting close now!
I got a new center console installed. It's from a KE35 SR and looks the tits
I got some SSR 13 x 7 meshies with 215/50 tyres on them
Then i decided to tackle the bonnet. it took 3 days.... crikey.
SandFibreglass bog:
More sanding and bogging
Guidecoating:
More sanding and spot filling
I attacked the underside with a wirebrush and then some cans out.
Etch primer -> black gloss -> clear coatAnd painting!
Left todo for WOF:
Install seatbelts
Install wiper linkeage
Carb tune
Wheel alignmentBuild discussion:
- 17
1 minute ago, kyteler said:
Don't suit the car?
they may, but not with the low profile tyres on them that's for sure.
I've been ticking away at the small jobs left on this car.
Badges:
New Door seals all round:
Mint back seat (back piece). Would love to find a mint cream one or at least a black bum piece
Got it out for a clean in the sun, paint is looking great!
Ignore Long champs on rear, they don't suit the car and I only had them on there so I could take it for a driveWill crack into the bonnet next weekend and get it fixed properly! hopefully....
Discussion:
Semi productive weekend, wasn't able to do much. I'm just waiting on parts now.
this weekend I bought:
Front half of center console (got a line on a rear half so that's good)
Front seats (need a massive clean)
SR steering wheelRear shoes and new drum cylinder as the ones in there were absolute wrecked
Ordered front pads to do next weekend. I'll get a price to rebuild the front calipers tooI'll be getting a pro to do the bonnet. it's just too far out of my league to fix. it's bent in funny places, rust everywhere. These bonnets are hard to find so will get someone to do the prep on it and I maybe the paint... will see
But in much cooler news.................
Water pump leaks, exhaust leaks out the gaskets. but it runs. I'll fix those few minor things too
- 7
31 minutes ago, Bling said:
Car is looking sharp!
You really need to bite the bullet and fix that bonnet though, detracts from all the time and effort you've put into the rest of the panel job. 2c
Couldn't agree more. Just waiting to see if I can find a better one before I get amongst the effort of fixing this current one
This weekend I did some wiring which seemed to have decided it didn't want to work since disassembly, to be fair I didn't check anything before I ripped it apart so hard to be sure.
1) Fixed the reverse lamps on the rear lenses to work when in Reverse gear
2) Rewired the KE30 loom to be of KE35 pin layout type, and run and rejuggle new/existing wires to the clusterThis is for the reverse lamp, it's a different setup from the K40 that came with the car so had to to do some rejigging with the wiring. I don't have any new terminals so just chopped up some old ones, soldered and heat shrinked them up
Tired of looking at this awful bonnet, I brush painted it with black epoxy paint. If I decide to fix all the errors with it one day, I will. otherwise it can stay like this until I find a new one that isn't so buggered
I also had a nice VDO tachometer I thought would be marvelous in the cluster.
This water gauge too. I thought I could just get it all in there and swap it out for a VDO one later on
After chopping and slicing, pulling things apart it came together
only 30% of these wires are used, but I thought I would just put them all together anyway to keep them nice and tidy. This is a 24-pin ATX plug most commonly found in computers. I've got loads of these around and thought what a good way to assemble it all
**I have two of these clusters so I can always go back to original if need be!!!
So now I have a very accurate tacho, which looks pretty sweet and a water gauge to know how hot my baby 4k really is.
_MG_0379 by phillipbaines, on Flickr
it's crooked... I'll fix it when I get the new VDO gauge
Build discussion:
- 8
Another productive weekend. Was able to get the doors mounted and hanged correctly so the line up with the latchey-loopey thing on the chassis perfect so the doors close with ease.
from the outside lighting you can see it took a while to get everything sorted: Window cleaning, rubber channel moulding, remembering how the divider piece went between the rear glass and rear quarter glass, then finding the correct bolts/screws...
Proud owner of NOS rear vent trim
Outside photoz
_MG_0338 by phillipbaines, on FlickrDoor cards a bit dirty, rear seat very very very dirty, undecided if will keep or find the other 'full vinyl' type
BIG battery which is just there for temp use. I may relocate to the back yet if I can be bothered, is fine where it is for now
Time to start putting the dash back together
I am waiting on a KE35 loom before I install the instrument cluster as they vary between KE30 and KE35.
*KE35 instrument cluster has factory tacho meter, KE30 does not
Yes... I missed a spot on the LF door... will have to fix that
Build discussion:
PBaines - 1984 AE85 Levin - Race pony
in Projects and Build Ups
There has been some good progress on this.
I got the rear drive shaft section from Japan, fitted a new center hanger bearing and slapped it in
20210425_160833 by phillipbaines, on Flickr
@Mitch.Wdecided he wanted my Levin front, and I too wanted his Trueno front. An exchange happened and i've ended up with half his car
20210418_104344 by phillipbaines, on Flickr
20210425_101416 by phillipbaines, on Flickr
BC Gold front suspension upgrade time. But first, some old Barry needed 8 cable ties to hold this brake line off.
20210425_110041 by phillipbaines, on Flickr
Fitted a new front fibreglass bumper. Looks the tits, managed to get it to fit with the original bumper irons with ease. nice nice. Also BC's are in here, and lowered down to a good height
20210425_131458 by phillipbaines, on Flickr
PartsShopMax rear coil overs. Gone away with the separate spring/coil and now have this true all in one unit. I may get some support added to the lower shock mount as I don't think the load that there will be on this diff now was intended from the beginning.
20210425_144314 by phillipbaines, on Flickr
A few weeks passed and I got some time in with Glenn at Syndicate Fabrication. Whilst he worked, I pinched his bench and did a few small jobs.
Hub refresh
20210520_103521 by phillipbaines, on Flickr
Courtesy of FLOS.ie. Great kit!
20210520_104334 by phillipbaines, on Flickr
20210520_105151 by phillipbaines, on Flickr
MRP Spec Willwood brake upgrade. I can only fit the brackets for now, they are suited for 15" wheels. The rally wheels on there (which are to go...) are 14.
20210520_112951 by phillipbaines, on Flickr
woop
20210520_113857 by phillipbaines, on Flickr
Nice spanking exhaust. if it's too raspy we'll chuck a resonator in there, but for now will test it and see how it goes. Muffler is an AdrenalinR 2.5", with race baffles $$$
20210520_180716 by phillipbaines, on Flickr
20210520_180735 by phillipbaines, on Flickr
Planning seat rails. there's a massive hump in the center of the car which makes mounting seats a bit annoying. Can't really use factor pickup points as they sit too high, and as a tall man i'd like my head squished as little as possible against the roof as I can
20210521_104635 by phillipbaines, on Flickr
20210521_123021 by phillipbaines, on Flickr
Tacked in for now, will come back to this at a later date when Glenn has more room to fit me in
20210521_151437 by phillipbaines, on Flickr
Mike Shaw bonnet arrived. Really happy with fitment and quality. I'll have to do absolutely nothing to it to make it align any better. highly recommend.
20210521_151549 by phillipbaines, on Flickr
20210521_151625 by phillipbaines, on Flickr
Next on will be wheels and rear flares. Then will go back to get the seat rails fabbed!
20210521_154718 by phillipbaines, on Flickr
