Posts posted by piazzanoob
Well the starlet ended up getting the move this evening
but not under its own power due to no radiator and a bit of a cunt to get started
had to jack the back up and pull it round to get it out as old shed hasn't got wide doors and fence is close by
Old shed
Into the new shed
When we have finished putting everything into and away in the shed the car will be moved into a more suitable loaction in the corner where its rust surgery will go underway
So i then looked at my options to what to do with it.
paint it?
blast it?
polish it?
get it done in vht?
well so i decided to get it bead blasted.
now what next
i needed a paint that would stick to cast Aluminum.
i thought about vht clear but wanted something that would last the heat and time.
so i fucked around and talked to a few people.
I then ended up going round to a friends place where he painted all his engines in a caprithane paint.
he then offered to do mine free of charge but he would do it when he got time.
A week went by
so i popped round and spend a few hours masking all the bits up.
few weeks later....
I popped round to check for progress
He had brazied up a small piece on the water pipe that had a pin hole
And........
Applied a primer coat on the intake pieces
Mayte check out those masking skills
then a couple weeks after that he rung me and told me he had applied the final coat of paint and it was ready for collection.
but
I had to spend many hours spinning yarns before leaving with the finshed products.
- 5
So now it was week two
And
back at work
And that continued for quite awhile
then i collected the cylinder head
and fitted that on one of my days off while still trying to tidy/paint other bits up.
ONE MONTH LATER.....
I then looked at the intake system on it
And while painting and tidying everything else up on the engine side of things
it would make the whole thing look bad if i just put it back on.
Nothing much on this project car has been done for awhile apart from pull it apart more
and use it as shelve and storage cabin inside
FT dog telling me to get it done.
All of this is because it was stored in the car port then the carport became an enclosed garage so
we ended up having no proper space to do welding and grinding without setting fire to stuff.
And plus we have been building a new shed to put our shit in
mostly mine though
so now with our shed pretty much done the car should be making its way into the shed this weekend
and i shall get stuck in to finishing this heap
but....
on a brighter note all ive done is buy more parts too.
so i haven't completely done nothing
- 5
Thats a good barn find you have there
looks like you will have your hands full with that project for some time.
keep us updated on the project
cheers
Hi,
Have a friend who's in a bit of a pickle and she needs some short term accomodation ASAP.
Does anyone in Onehunga or surrounding areas have some temporary / short term accomodation on offer until she is able to find a new place?
Disclaimer: I do not know this person amazingly well but she seems nice enough.
how short term is this accomodation?
Now that this thing is up and running
You must come to the OS monthly meet this coming Wednesday!
+1 for dashboard restorations
Did my one in the piazza that a upholstery shop at the time in onehunga didnt want to touch due to the shape
Also not surprised that they are busy due to them making dashes for R/H hook conversions.
He should just pull it out and take it down there for a quote.
Also just as a note these guys don't just bog and slap some paint on your dash or do a quick recover
All their dashes are coated with a paint that is imported from the US that is $200 a litre from what he told me
and it also involves them being placed in a oven for proper paint cure
plus the use of a vacum of some sort to pervent air bubbles stuck in the dash.
so there is a reason they are not cheap
they use quality procducts and do top notch work.
Once I got these soft plastic spanner holders witch sit in the toolbox draw or hang on the wall, I need more but can't find them
snap on do them
Now everyone can call me a snappy head
Bought this toolbox for my old man as his was full and needed a bigger toolbox
Looked at others on the market but found pretty much all the others in the market aren't wide enough so when you open a few heavy draws they fall over
Where snap on boxes Have a decent widthbought this box combo second hand off my snap on dealer
tbh if he has more tools than cabinet at that size 5k is probably a small chunk of change compared with whats within
correct
Piazza - What do you reckon your hand tools are worth? Ballpark value? (I'm trying to justify an expensive box but 5K is a lot!)
i would say about 10k in tools which includes air powered and electric stuff too
Also raging at Snap on at the moment because there tool trucks are so shit at coming around/getting a hold of
My ratchet exploded and I NEED it fixed.
One of the guys at work had a thing that broke, its been two months and they're 'still waiting for a repair kit' for it.
Sounds like you have a shit snap on salesmen
The guy I get is great doesn't always turn up but he try's his best to
And is great with warranty stuff also
I broke a 3/8 12mm socket using a 3/8 snap on small battery rattle gun
And I was honest with him etc and he replaced it and just suggested for me to buy some impact sockets.
I know that you said on the north shore but
I know Auckland Automatics in Onehunga are good as we send them
transmission work that we cant do etc.
and their techs there are clued up etc
Mayte
Looks like I'm rolling no Wof or reg to the meet tomorrow
Algood
I'm a Maori officer...
With looking at the photo of the caliper
it appears that it has rust under the seal but the rust on the top ridge isnt a huge issue as it only holds the moisture boot
best bet would be to get it bead blasted then see how bad the pitting is on the metal but would most likely be fine
i would say that the caliper piston has rust on it so would require a new one
but you need a caliper rebuild kit anyway.
would also recomend doing the rebuild yourself as saves abit $$
plus they are not hard to do.
looks choice!
just needs those plates painted black
Cars you own: Toyota KP60 Starlet, currently 4K, soon to be 4AGE
Mods to them: Not much yet, just rebuilt the gearbox, carb, lapped walves and valve seats, just gotta get the old girl to be a reliable daily before I start doing more, soon to be built 4age bluetop 16v
Link to pics: https://www.instagram.com/huiaparsons97/
How you found out about oldschool: Someone who is already on this site told me about it
Anything else you want to add:
you should put up a build thread for your starlet
good to see more women using OS cars for projects
Do I want a Triumph 2000/2500?
in General Car Chat
Mayte you are all on the wrong page.........
LD28 is the only option!
