MitchP
Everything posted by MitchP
Used the Scotts auto rubber part number, asked Basis after checking profile, arrived as overnight delivery, south island, 4m $90 including shipping. Has metal tracks in it so it pushed on and holds very well Part number 322.030 is a x 4m cut length of 322.006, which they had on a roll Used maybe 3.5m
Been at manapouri power station this week so far, so only just seeing replies Cheers for all the info team, I'll let you know how I get on
Quick and small query to anyone in the know... Is there a photo or idea as to what to use for a 16L colt boot seal? Seal is on the boot, but looking for the seal that's glued to the body of the car. Any ideas? (It'd for this I've had painted)
Question with your seals... Did you by the door seals off rare spares only? Or did you also get the weatherstrip for the top of the door (called door belt as well I believe) Trying to find that part for my 16L, including the rear seat side window belt seals
I think they are 10 bolters. But I'm sure there's also an 8 bolt one out there to. I'll know more on Friday when I can get home and under the car for a look
That's awesome! That's pretty much the answer I was hoping to get. From memory, I'm not really sure if there are many/any diffs non-factory that fit nice anyways
I have a 16l colt build with a reconed 4g63 with mild cam jobby done.... Any ideas on a suitable diff to match? Unsure of current diff, if from the l200 as well, it's probably fine as it is I'd imagine
Were there rear seatbelts factory in the coupe model of the 16L? I have noticed mounts on the rear pillar but didn't seem to be any corresponding ones for belts... Perhaps this was for those leather Jesus handles?
Looking at getting New wheels for an old colt.... Any ideas what sort of offset I should be looking at? I'm not really up to spec with wheel selection at all...
Yah, 2l I figured the same deal, but the 4k being a 1.3 (?) And I don't know lots about jetting, so am after the sizes for it
Quick question for those in the know... Acquired a 32/36 dgv weber for a 4g63 rwd early 80's sigma. Originally off a 4k motor that was running. Does anyone know, or know how to figure out, what i need to rejet it with? Cheers in advance
Yup. From what I can see, they only have stuff for l200 utes
Good point. 16l knew I forgot something in the post. The profiles look right, it's the physical length/fitment that I'm unsure of, so don't know what I'd gain out of sending a sliver up there
http://www.rarespares.net.au/mobile/productlistings/?type=partsfinder&brand=MITSUBISHI&model=GALLANT&car=36A&productgroup=WEATHER+STRIPS+%26+RUBBERS Horrid link paste I know... Any ideas on if these rivers (coupe ponds of course) are good for the NZ version of the colt? I can't see why it wouldn't fit... The Chch rep was asking if I could bring a sample in, but living in Dunedin makes this a bit difficult. Any ideas? I personally think it'll be a goer (full rubber kits available on the site somewhere to)
found the belt mounts. previous owner had glued some cheap carpet over the holes without cutting them out. no luck with holes for the stalk side in the tunnel. surely that stalk/ fabric isn't attached to that wee nut on the seat itself, opposite side to the recliner lever?
cheers for the info... ill jump in the garage and check it out. but from memory, when i was looking blind, i didnt see anything obvious, and im sure i was looking in those areas. time will tell. cheers
gidday there fellows... getting near the last steps of putting together a 72 galant colt coupe. come across the fact i need to buy some seatbelts for the old girl, makes sense. the thing i cant see, and dont know, is, apart from the roof mount for the top of the belt (or one of those seatbelt dropper things) where/how do i mount the bottom of the belt (which i believe are retractable factory, i may be wrong) i am going to order new belts, which means i believe i have to get retractables anyways. main point of thread, does anyone know where/how to mount fron belts in the car or even have pictures of existing ones so i can figure this one out? cheers ppls
I have factory seats, but I think I may have 2 drivers side ones? judging by the side of levers on the seat hinge and lack of rear seat foot release on either seat
folding feature of the rail? excuse my ignorance, does this one mean the seat hinge folding but is not required? because i need a seat hinge to
Noel - will do, cheers. May be next week, depend if I'm working out of town or not
just passenger side, 2 rails
things are looking a bit bleak here in Dunedin for what I'm after, including looking around. if you are able to help at all, even with a supplier, let alone parts directly, would be much appreciated
cheers for the info, I'll see how we get on
sorry, I should've been more specific... 16l factory seating. passenger side I have the half of track without adjustment lever. so yes, original seats, no rails. or recliner adjustment lever/ arm for that matter
kinda a random question here.... does anyone know of any seat rails available for a 72 galant colt, or even the type off another car that will fit the same? i can look at getting a pic up later today/tonight if thats of any help, but if anyone knows off the top of their heads what i might be able to do to get around this (need my seats in for a warrant/certification cheers ppls
