Posts posted by M.H.
Does it have a VIN or frame number?
9 minutes ago, cletus said:
In your case 50% hp or torque increase would be the tipping point for needing a loop.
I would say 2.5 to 3.9 td might be a hard sell that it is actually less than a 50% increase, especially if you have things like a larger exhaust etc
Does it make any difference that the same running gear is used in later more powerful versions? The 4.6 v8 had 222hp and 400nm
On a Land Rover im doing an engine and gearbox conversion on will it need drive shaft loops? The engine and gearbox have been changed out for an isuzu unit, the orginal transfer box has been adapted to the isuzu gearbox in its original position with standard driveshafts. The land rover engine was a 2.5 turbo diesel 112hp, the isuzu is 3.9l turbo diesel 130hp. Will also have a 50mm body lift.
A highly boosted diesel would be winning
Just now, kyteler said:
Put a 13b in an AU for maximum lols.
A diesel au would be awesome
34 minutes ago, yoeddynz said:
I presume they must put caravans in containers but surely no. So they must sneak bits in.
Yea they go into 40ft high cube containers
A bit of jb weld will have that sorted
Id b e in for some land rover suspension and other heavy parts
Where did you get it from? If you bought from overseas you may have a lhd core, the part number you need is 1J2819031B. I wouldnt swap the tanks over as they go brittle and break
Just buy the correct core, they are not that expensive
Thats pretty much every profile cutting shop
Just wait until you pick up another couple for parts
partzilla are pretty good for parts, ive bought a lot for my xr600s
https://www.partzilla.com/catalog/suzuki/motorcycle/1996/rm250/clutch
Yellow pvc jacket and pants if its raining
Ive been looking at a Skoda Yeti for myself. They drive really nice and the 2.0tdi goes alright
1 minute ago, Carsnz123 said:
SUV = large fuel bill
Since when?
Or just get some T sections and make a log manifold
How many cylinders? 4cyl are easy enough but any more than that and it's better to get the pipe laser cut for perfect fitment
You will want sch40 or if you are doing it in stainless sch10
I had a 306 hdi. The clutch is cable and it shifted gears smoothly. It went hard after fitting an intercooler and a remap
2 hours ago, ajg193 said:
What's the go with finding second hand Leaf battery packs these days?
People pay a lot for them even when they get down on capacity for power storage at home
re-registering a vehicle
in Tech Talk
Then it wont matter, when it gets re registered the colour will be updated
