chris r
Posts posted by chris r
3/4 ain't bad. Mains and rods torqued to spec and it spins freely which is good
More spaghetti
Turned it into this. Vtec wire re run and run the reverse light wires
That's all I can do on the loom until I get the motor/box into the car. Those rings are holding up the process a fair bit
- 9
bolt box came up a winner
bit of angle grinder/drill action and we are all good
crv hard line even fits pretty good
got correct rod bearings and clearances are what they are so I'm gonna send it
Assembles the rings onto the pistons, I lost my good ring compressor so grabbed a cheapie.... And paid the price. tap tap, piston feels a bit stuck so back it out and try again
Will have to order another ring set now which has ripped my undies
- 6
More clutch schenanagins
Circlip didn't want to come out nicely
The rod is a bit longer
But not long enough
Will rummage around in the bolt box tomorrow and see if I can find one long enough to barry to suit
Gave up on the idea of the arp rod bolts, will need to be pressed in and honed to suit. I'll just Wang the stock ones back in. They were good enough for the last build so they'll be good enough for this
Went to assemble and rod bearing looked off
Turns out my motor has the wider bearing which is the same as the vtec motors.
Vacuumed/cleaned all the swarf out of the head and put the oil feed plug in
Modded s2000 clutch master is perfect distance for the pedal.
But the reservoir hits everything
The Facelift orthia must have a different firewall as the earlier ones share the same clutch master as the civics/integras and those need a spacer for the s2000 master to work. I'll extend the rod to suit as I don't want to wait or pay for for the genuine master
Fitted main bearings and crank today
Cheap and cheerful one size fits all rock auto bearings are within spec which is nice
Smidge bigger than 0.02 which is factory spec ish so that's a win
Will do pistons/rods/arp rod bolts tomorrow.
Attempted to fit oil pump today and managed to mangle that seal. Luckily I ordered another by mistake with my last amayama order so that should be here next week
- 8
Not shit oil fitting arrived
Openings for the oil feed are actually at the top of the fittingand are open and not obstructed
Past me loctite the fittings into the shit sandwich plate so they'll need to get warm to be taken out. Hopefully they aren't complete chinesium and strip on the way out
Modern daily meet?
Sold crv today. Turners cash now ftw.
Super easy process and zero drama on my end. So so much better than trademe
- 6
Gave the pistons a bath in simple Green and exoff
Before on bottom and top after the first soak
Bit of scotchbrite and a pick for the ring grooves
Figured out the shift lights on the orthia/crv. Had to do some modifications to the indicator so it doesn't need the ecu/module doesn't need to be there
https://i.imgur.com/u8MT9Mv.mp4
Inhibitor wired up
https://i.imgur.com/ghxEWGn.mp4
- 6
On 11/05/2022 at 21:21, h4nd said:
SuperFastMatt made an arduino controller with a motor shield and a current sensor for an electric park brake. I've spent an hour, and can't find the bloody video.
Can everyone go back to using the internet with text, thanks?
Update: controller referred to here https://youtu.be/j1SMvM-SUHE?t=585
Up-update:
How much current do those things actually draw? anyone put a meter on one?
Apparently 20a ish? I can possibly test the set I'm about to be working with
Trip to wash world to blast the worse of the oil sludge off
Onto the healing bench in my 'clean room'
Rangi de glaze
Yes I know I should mic everything and measure it blah blah.
If I don't measure it I don't know how bad it is so I can live happily in denial. My theory is it was running well enough and not making bad noises before so it'll be good enough to go back together as it was.
Vtec oil pump fitted
The aliexpress oil feed kit is as good as the manifold and valve compressor tool
Somehow the oil is meant to magic its way through that fitting on the block. Then through that fitting and into the head
The fitting also seperates the un filtered oil and filtered oil with fresh air and hopes so doesn't instill much confidence at all.
What did I expect for $50...
Glad I figured it out now rather than once everything was installed and on startup
Stripped the block this morning.
Looks super clean for 300 thousand
Bearings look a bit worn but not fucked
I'll need to do a bit of 'porting' on the oil drains on the vtec head so it matches up with the 2L bottom end
- 7
https://www.pantera-electronics.com/epbcontroller.htm
I've found this controller. Currently working on if we can get it to meet cert specs
So clutch master stuff
Crv on the left and s2000 on the right (gene) the s2000 need a spacer to be fitted to civics etc)
Left two are s2000 and right is the crv.
The crv has a shorter u clip and push rod.
I swapped the pushrods and u clip over. Will test fit tomorrow
Put doort chamber thingy on and fitted fitted throttle cable.
Installed torque converter bolts and cover.
Connected battery and no sparks or smoke
Plugged in the 'faulty' ecu I got out of the bin to test
https://i.imgur.com/JtmWgEP.mp4
That's a good sign
Auto ecu time
Odo turns over (after its surgery) , speedo works no cel.
Only hiccup is the rad fan is on constantly, as is the ac compressor
That should be a diagnose/fix.
Just need to install the shifter and gear indicator wiring/inhibitor switch
- 15
We sell something similar at work, same as any battery if they sit connected they discharge. The suppler recommends a trickle charger if leaving them to sit for a period of time. If disconnected they should be okay
Dizzy time.
Had a cheap China housing that the timing was out or something was wrong with it
New rotor and new ish cap and its (hopefully) good to go.
Loom taped and fitted to crv
Quick trip to ripco for intake gasket
- 5
Nearly the end of spaghetti time....
For the crv. Just need to test 4 wires into the orthia body loom, I suspect they are for the gear selection input or something
Last of the auto wiring de pinned pulled out of orthia loom and and back into the crv loom/plug
Crv loom done as far as what needs go in th engine bay. I'll plug stuff in before I tape it up.
Orthia loom needs more work but that can wait for now
- 7
mixed success today - Got the manual pedals in and found out the CRV clutch master pushrod is too short. diagrams have diffrent part numbers for the pushrods on crv/ orthia so it may be a length difference. I've got a couple of masters in the lockup so I'll go out and grab them next time I'm there
That aliexpress manifold is the gift that keeps on giving - Fuel rail holes are slightly out, Nothing a file cant fix
and the stock throttle body throttle cable wheel thing fowls the body too, again I've got a spare throttle at the lockup or if that's the same I've got a grinder
- 8
More spaghetti!
Crv loom all repined to correct plugs. I added in the knock sensor wire. Will do the auto stuff tomorrow. I went to run the wire for the vtec solenoid and the orthia loom already has it populated and it's running to the dizzy plug. I'll have to look at the dizzy and see what's going there
Qc/supervisor making sure I'm staying on task
More cluster schenanagins. Turns out the crv and orthia clusters are the same size just different fonts
Crv now has gear indication and a higher redline for more doorts
If anyone wants the leftovers for digi speedo or something then let me know
- 5
Biscetti time!
Orthia, manual crv and auto crv looms
Partially stopped the orthia loom, I've started to pull out the auto stuff for the crv and I'll add in the reverse switch, vtec and re do the distributor plug to suit.
Stripped the auto crv loom
I'll need to repin the crv harness to suit the orthia ecu. Crv is obd2a and orthia obd2b so they have different plugs and totally different pinouts.
I started on the repinning last night and it was quicker than stripping the looms. It'll slow down when I need to transfer the wires acorss for the auto (4th plug which isn't populated on the diagrams)
- 5
Just need some hammering to finish it off.
Grabbed a clutch and new rotors and a bucket of cheap oil
- 9
For Questions Regarding WOFs/CERTs/NUMBER PLATEs
in Tech Talk
I'd say just bring Canada paperwork/proof it's yours and plead ignorance with jdm r grade stuff.
I don't know/imagine they'd have any access to jdm auction stuff
/barry out
