chris r
Posts posted by chris r
Rangid up the catch can with leftover hoses/fittings from my hoard. It was a cheap catch can but looks exactly the same internally as the mishimoto cans so finally a aliexpress win
Outlet goes into the resonator section of the airbox
Sits nicely where the factory massive resonator chamber sat
I've run a - 10 hose down under the rad for a drain for the can. Didn't want to buy a bung so I made one. Hopefully the orb fitting seals well enough
The tuner popped around and had a nosey, was happy enough with how everything is. I just need to check the iat sensor in the morning as it was reading a bit high
Looking a bit more factory ish. I'll try and mount the factory heat shield over the headers
I've rangid a intake pipe up while I wait for a factory one to arrive
It'll go onto the dyno some time next week. Its the 'heartbreaker' mustang dyno which reads lower than others but it's just a number at the end of the day
- 9
6 minutes ago, shrike said:
Ok nice sure you'll get a few more gains when its tuned/run in etc
Nice so a small bump up from the factory compression (Factory seems to be from 8.8 - 9.8 from what I could find)
Is the manual gearing higher or lower then the auto (ie is it revving higher or lower at say 50/100km)
Fingers crossed they don't notice the conversion, assuming it looks stock enough yeah?
Any plans for some boost later on or just drive it as is?
The vtec heads flow much better so all things being the same it should gain power compared to before, but more importantly I get more doort noises
Manual crv gearing is higher compared to the auto (or manual orthia) it's revving higher/speedo is reading about 15% faster.
Hopefully once I track down a stock intake arm it'll look more factory, its all bolt in parts (except the shifter) I'm hoping with a boot I'll get away with it with a friendly shop
- 6
16 minutes ago, shrike said:
Any up rated CR with the change in head? does it feel quicker to the butt dyno
What was the tuning method/ecu your doing again?
Assuming wof wont be an issue?
It's still on base tune so conservative, I'll be getting it tuned on Neptune (socketed/Chipped factory ecu). Butt dyno says it feels a bit "flat" but again not tuned/ haven't checked timing etc etc
Compression should be 10.2:1 with this head.
I'm hoping no wof issues, I'm more worried about the manual conversion stuff tbh
Yeah I'm stoked
Spec is original b20 block/bottom end, b18c vtec head, crv manual gearbox and rear diff (so ratio is the same)
All assembled
Throttle cable bracket didn't line up so I welded two together
Started and went to bleed the rad and check light came on.
Dizzies out of the warranty bin were there for a reason. Two China Dizzies both had sensor faults. I swapped the oem honda sensors in and same issue, I ended up swapping the shaft with the gears etc from the original Honda dizzy into one of the China housings.
Took it for a quick spin around the block and it survived.
Went for a longer drive to get lunch
The exhaust turned out great with the reso fitted, drone has gone and the volume is much better
Manifolds on and cam seals done
I didn't get many pics of the rest of today's progress was in get shit done mode.
Had to do another trip to pap to grab a bunch of manifold nuts.
Fought the inner timing belt cover as it hit the block a bit.
Quickly slapped a battery and the wiring together.
Didn't hear fuel prime and had a o shit moment, plugged the fuel relay in and had fuel and no leaks.
Figured there was enough assembly lube in it so went for a test fire
Plugged tps in and check light went out.
Will bleed coolant /check for leaks and Button the last stuff up tomorrow
Exhausting morning
Tacked flexi/reso/everything together
Welded on the lawn and back purged with a oxygen nitrogen mixture
Yes the headers are most likely shit/no good for power, they are lighter than stock and let me fit the cat and reso under there so it does what I need it to
Time for some grinder love and it'll get some paint and maybe some wrap if its really lucky
13 hours ago, flyingbrick said:
Gotta admit.. At first I didn't understand. But now we are 25 pages deep and I find your stuff quite impressive
Thanks, yes it's a silly honda wagon. I wanted a awd manual vtec wagon so I had to make one hah
- 5
So list didn't get much checked off but i got a bunch done.
Started on exhaust stuff. Expanded the headers a bit so I could slide the pipe in so it'd hold while I figure stuff out.
Got flexi in position then the rain set in and I was over laying on puddles so moved onto other stuff
Bags of new genuine bits (and some rock auto stuff)
Torqued head bolts down and started on the cams/cam caps
Two small o rings replaced there
Got the o ring ready for the middle cam cap but the dowl is missong
Moved onto sorting the intake manifold stuff
Fitted fuel rail iacv and throttle
Manifold came with a extra coolant line which isn't needed so I Wanged a bunch of epoxy and a bolt into the hole
Squirted some underseal on the inside of the trans tunnel
- 8
Grabbed new head gasket this morning.
Dowels didn't fit so it needed some careful filing
Bit of honda bond around the oil drain passages that are different
There are 84mm vtec spec head gaskets and also a couple of options that are intended for this application but everyone has been out of stock or delayed on them
Heads on with new bolts
Replaced the thermostat/waterpump pipe o rings and fitted that before I forgot
Only got two things ticked off the list today...
Shifter plate was win and took a few hours, hopefully I can smash most of that list tomorrow.
Ideally want to get to the dyno by the end of the week which is looking like a very ambitious goal at this point
Mixed success today
Got valves/retainers all sorted today, Went to put the gasket on and it was a tight fit with the dowels, Head gasket didn't survive the process
Cut/welded/seal sealed the block off/shifter mounting plate
I'll tack/weld the nuts on so its not a mission to change in the future. I'll etch prime it then give it a good dose of underseal so its factory azz gee
All the gears work which is nice
- 6
While I was on a pickapart mission I saw there was a accord with a heimholtz reso so I grabbed that - Will have to do some more reading/sciencing to figure out pipe length/sizes etc. There is space above the rear muffler so I should be able to fit it, with the new headers I should be able to fit the cat and the other resonator
Tool some brave pills today and got out the extension and the holesaw
Took a couple of cuts to find where the top was.
Hind site says dropping the subframe would have made that easier but the cbfs were strong
The shifter lines up nicely with the console which is nice, I might need to cut/weld/adjust the shifter so its not so far back but I'll wait until its bolted in and the steering wheel/column back in
Cv boots arrived for the rear, Fitted them and the crv diff when I was under there
CRV diff (right hand side)looks slightly different but bolts in the same
- 6
Lapped the valves in
Gave up fighting the keepers so called it a night after only getting two sorted
- 5
Juuust missed it
Becaue everyone likes pics of honda stuff here's some more
Grabbed some dowls from work that actually fit
Borrowed the 14mm hex of the neighbor and put in the an fitting into the block so I'll actually have a chance at pcv stuff. Next time I'm at lockup I'll grab a catch can and see if it'll fit
Bilstein do replacement struts and koni do inserts. As I understand the issue is from the steering arm being welded (and cast) on the majority of aftermarket coilovers.
Got the bottom end assembled, windage tray and oil pickup on. Sump gasket pood onto the sump with black schmoo like factory.
Replaced bypass spring and valve as it was cheap enough
Had a cunt of a time with the crank seal in the oil pump, after about 10 attempts I got it in properly.
Attempted to wrinkle black the rocker cover. Etch primed it in the paint booth and peaked there
Sat the head on and test fitted the cheap headers, I'll get away with a 2.5" 90 bend off them and it'll line up nicely with the rest of the exhaust. Hopefully I can move the cat up and fit the reso and flexi in
Unsurprisingly the dowel pins that came with aliexpress kit are shit, flop around in the head and don't for the block or the head bolts.
Fitted the shifter cables and sat the crv shifter in to see where stuff wants to sit. I'll need to very carefully drill the firewall and miss the heater core and ducting.
I can pretend I'm a rally/race driver as the crv shifter is super tall
Mounted the oil feed plate to feel better about fighting the rings and crank seal today
- 6
More wiring
Sat head on so I could figure out where plugs etc wanted to go
Intake for the same reason
Some split conduit and a roll abd a half of tape later
Vtax wire is pinned into the ecu, reverse light switch wires are run to the plug and I'll pick a couple of wires from the inhibitor/auto stuff that I can repurpose for the lights.
I grabbed a jaycar speedo corrector as the crv has a different final drive etc and it'd be nice to have a correct speedo.
Other ring set arrived from rock and my dipstick and some seals arrived from amayama
Got a decent list of stuff to do tomorrow, hopefully I can get most of it done and have it drivable in a week, my tuner only has a small window of time and I start a new job in a couple of weeks so it'd be nice to have everything done before then/before I loose access to the hoist at my current job
- 9
2dfl?? Yellow
Shrink wrapped the block so I could make some progress on everything else.
Barry crane setup and got the block in
Flywheel and clutch on/torqued up
After falling off the jack four times the gearbox just slid on with no dramas
Slave on and it all blead up relatively quickly
Drivers cv/axle installed
- 9
Reinstalled the konis into the shuttle and put the yuck 17s off the orthia on
Got drivers side front in and realised that I've got two right hand side ef forks which sucks. I thought I had hoarded more but clearly not.
Did a service on the beagle and the 'you might need to keep a eye on it' oil leak did need a eye kept on it.
Both sides are that bad, it'll drip onto the drive shafts and go everywhere. Atleast it won't rust I guess
I nipped up the sump bolts which were a Smidge loose but not horrible
Wanged the phone down and had a look at what I could see.
I'm wondering if the $4 rock auto filter was weeping or if the oil cooler o ring has perished and is leaking.
I'll throw another bottle of stop leak and some degreaser at it then have a look later
Chris R's various honda thread including punishing modern non os daily driver updates
in Other Projects
Yeah factory meant to be 110kw at the flywheel factory. Just running 95, if I sacrifice a bit of power so be it, it's intended to be a fun daily/I'm too cheap to pay for 98 all the time
My crx made 115 wkw from memory (same dyno as this will be going on) , that was type r b18c so more compression and revs/it also had aftermarket cams.
