Posts posted by footey
first paint was under the paint name of camouflage to light so back to mega 10 to get a retint
my two cents on paint, first buy resene house paint heaps of colours and great price at 150 for 4Ls
step two - hand brush first coat.
Step three - do final coats with a fine haired roller, this gives it an almost flat finish
boom bobs ya uncle and fanny's your aunt laughing away with your under 300 doaller paint job that looks flash as a rat with a gold tooth- 1
but not looking at the fact of splicing my air intake pipe for the heat into the snorkel air line, that way it has no chance of sucking up any water
am then going to attach the box to the firewall with some 90 degree angle brackets, doing it this way as im not wasting time making a box for it to sit in, the box protects it mostly, and its all off the shelf components which saves time
so everyone is updated i have brought said heater and waiting for its arrival will do a tech thread on here once i get it and install the thing, allready buzzing with mounting ideas so far this is the plan
Mount it in this said box, chop the handles off and take the lid off, maybe depends if the lid rattles , chop holes in the bottom for piping and also chop holes in the side for ducting -
i thought id mount it high up on the firewire, i thought about under interior wells in the back, but then wading through water sitting in water, might swamp the unit, on the fiewall up high that will be the last of my worries if the water is that high
i do alot of skiing through out the winter im just going to leave this running on low, mint as =) have enough space between the back of the rocker cover and firewall to fit this in, will do a tech article when im installing it for all you other peps who are wanting to install one, have a design for a custom air box to re route the air up to the windscreen
rcd dont make it into 15amps all an rcd dose in layman terms is protect agaisnt a fualt as in if your extension lead has a cut in it and you touch it giving yourself a shock it will trip out,
a breaker is rated to average working current ie a power point circuit is typically rated at 15-20 amps at the board, so you can get away with pulling higher current at the socket =)
i may just be confusing things now with this electricity stuff now haha -
i vouch for the wt160 weldtech just brought one best welder i have ever brought had a supercheap auto mig before hand
bargin and free freight which means you dont have to pay gst when it comes into the country has a good rating aswell
notice it dose not have a muffler might buy one seperate, purchase this in a few weeks install in landy and see what happens toasty warm =)- 1
i want this landy to be bearable when going down the highway, i have layered it two coats of body deader on the floor then eastwood x mat i have then sealed all exposed edges with body deader again, on top of this i will put rubber mats, more x mat to go down on the floor panels
this is what im contending with not much but tricky little bits to fill
this is how i have been reinforcing the corners and fixing the rust figured it was the easiest way, im not a really good welder so im happy with this
yeah i see the use in the engine coolant lines as a heater, but this way you can have the car not operating and be able to get it all juicy and warm good for ski trips and mid winter jaunts,
these are the units i am looking at, would make up a valve box to direct air to the window demisters, could also add a wireless remote which means warm vehicle before you get in it =) oh and they dont require the engine to run
Hi all wonder if anyone on here has any experience with these cheaper diesel heaters on trade me? i know these are from china but dont want to bring my own in tax etc
Looking at a marine, rv german unit but they are about 2 grand a unit, looking at using it as my standalone heater in the landy
Any thoughts would be great
Footeys land rover series 2a 109 safari
in Projects and Build Ups
