Posts posted by smokin'joe
am on Home D with BOC
$180/PA with 1 free refill.......... which is a good thing when one forgets to turn the gas bottle off !!- 2
Lampola !
15 minutes ago, SOHC said:
Why waste money on a honda when you could weld a 19mm shaft onto the end of a GN125 motor,
just add coupling to front sprocket, for extra 5 gears, make sure bike stand is decent.
best bit is de-coupling, to ride to supply shop for more cutting fluid- 2
4 hours ago, Valiant said:
350 chev for 350 chev?
be half the fuel bill off of a 300ci
ticked the crane and 4WD boxes, does he get the bonus points for Isuzu diesel power ?
On 05/07/2022 at 09:25, xsspeed said:
seems too much of a coincidence, is that the 3pot HRE was building?
Jack Hawkswood maybe ? , as he seemed a bit unimpressed with his new car, which is sister-car to McKenzies, i believe
7 hours ago, mjrstar said:
I'm back,
This time it's my falcon ute with rear imbalance..
First test was L200 - R240 (listed as 27% imbalance) but my maths says 20%
Stripped slider pins, cleaned and re-greased there was a bit of crud on the left ones,they move nice and free in the bore.
Went back for a re-test now L300 - R360 so new 26%
Discs and pads have less than 10,000ks on them and look mint, no uneven wear..
Is there a chance if the lsd setting on the roller machine isn't done incorrectly that you could get an out of wack reading?
we often had semi-seized pistons in the Falcons, especially the utes . maybe from burnouts or too many heavy loads rooting the prop. valve
2 minutes ago, NickJ said:
I've got a number of this type of supply off Ali, all work and provide rated power, quite hard to release the smoke.
Just designed to be inside an enclosure, exposed wires etc
even with a constant load ? that's what killing the PSU's.
1 minute ago, Bling said:
12v would be much easier to sort in your case. I have a PC PSU I powered a car stereo from in the shed, 12V rail on them tends to be decent, well so long as you don't buy low end.
burning PSU's out, as each heater draws 7-8A, plus have cycle pumps and lighting.
30A will be a decent starting point, may need 2 of them -
2 minutes ago, Bling said:
I feel like including the knackered batteries in the mix of this will do more harm than good. Would they even offer up the capacity you're needing from them?
Purely for examples sake, this unit is used for 3D printers https://www.trademe.co.nz/a/marketplace/computers/3d-printers-supplies/3d-parts-accessories/listing/3652425447?bof=0yiT1ElZ
Scrap the batteries to fund a 24v PSU
that's the 24v version of what i will try and keep the smoke in tomorrow
14 minutes ago, NickJ said:
Just checked all mine, largest is 200W and all 12V. I do have a spare 200W 24V supply if thats any use for testing?
Or, buy the 600W Ali express supply, by the time it turns up summer will be here and you can dump it in the pile of unfinished projects.
have recently bought 12v 30Amp unit, and very doubtful about its capabilities....... might wire up tomorrow to see if smoke stays in, as need heating in shed capsicums are sulking
1 hour ago, ThePog said:
Bitches.
solar
often the cat light will iluminate, so the wire needs to be grounded.
sell cat to pay for str8pipe- 3
be thinking liteace or hiace if the tops are original
On 25/05/2022 at 14:43, ThePog said:
OK foamers, ballpark how much is this worth?
94
2.8D
Current reg
Driven daily
Looks to be a beam axle but will check.
Been quoted 3k for rust work for a warrant.
I have not seen it, nor will I be able to.
took a 93 , similar kms, tidy-ish with add-ons, south for a $14K buyer 3 weeks ago
what is the Hampden concoction ? always driving when i go past and don't pay enough attention to it
plenty of NZ new Y-series engines, see if you can find carb and manifold
had 3Y in YN57 hilux ute, and was as cheap to run as my 5L diesil hilux, and 7AFE corolla
i had the crappy emissions nonsense on an early incarnation of 3T silliness, and was a prick for miss/ carb icing, richening/leaning, so fitted NZ new carb manifold... too easy- 1
run length of clear hose between filter and pump .
many older nissan filter housing get porous/crack and allow air into fuel- 2
5 hours ago, GuyWithAviators said:
TD27 would sort your misfire.
/lingbut you will be late everywhere, needs more LD28+T
to fix the CV style 2E corolla, i used factory downdraft manifold and a 4K carb with manual choke.
worked a treat, but was tuoch and go to fit the auto-kickdown -
On 11/05/2022 at 22:11, yetchh said:
Pretty much every surf I've ever seen has sagged on the drivers seat, even low km ones. Must use inferior foam..
ya wanna see the bench in the 106 i picked-up in CHCHur monday, and driving to Catlins in morning...... gonna be a 4-5 stopper to ease the pain
7 hours ago, Spooky said:
For anyone that might come across this thread in future searching for an answer, I called Palmside and they said either 150 or 170 would be fine, the guy I spoke to said he would go 170.
it is all relative to what the tune is, and where you want the power to be.
there is a good tech article floating around by Dave Vizard? that explians how and where changes are made. he did have a tuning programm that one could change parameters , and give baseline jetting for varous tunes -
26 minutes ago, Bling said:
I would expect Palmside to be pretty knowledgable on which bits to go for. They are pretty into Escorts.
Not saying don't ask here, but more so that when i've been in there they have been helpful. Wasn't for jets, but still.
this
Deane and co know their stuff..... especially with those wee english harlets
Welder buying spam
in Tech Talk
are you on Air Liquide ownership ?
