Posts posted by smokin'joe
sorry mate, but the threaded rod for steering links won't last 5 mins......... been there, failed !!
get some thick walled tube and thread inside
won't it be a YT175 motor if it is a pull start ?
can't remember any 2 wheelers having a pull start in that size range. believe they share some parts with dt175, but i doubt you'll have a 6-speeder unless it's a hybrid
do boats count as well?
definately, only because they said it wouldn't work............ infact it didn't until they doubled-up on a few bits
i win , all the others are too pretty, and shiney
- 5
ah right.
so probably crap.
an engineer looked at them and reckoned they could be shimed or have stiffer springs fitted (an option of the PG ) but likened them to adding ali filings to your diff oil, just because you could !!
so was this to suit a Datsun h165, or are we talking a t series Toyota one to mod?
looks like they are available for most makes/model , and very similar design/principal to phantom grip.
only know of one person to buy into the phantom grip sales pitch. apparently did sort of work, but was told to either put a proper lsd in, or weld it up to be certain it would be consistant (rally use TE71 small axle T diff )
I too, would like to know how this pans out
thye claim to behave like a 2-way, so guessing phantom grip with stiffer springs ??
When there's no petrol left a Prius will be a classic that you can still drive,
fuck off i'll be driving a Pryarse, cool cars will just run like i do........... on a healthy dose of alcohol.
phantom grip copied or rebranded??
i do my practice on a shitty Scottish thing made of thick steel. once i've worked out how to fix one of the cuntist double-skinned pieces of trash, wifey will have a restored Imp sport, and then i can start on thin cunty rusty Jappo shit or really rusty OZ rot !!
practice shaping on thin gauge but practice welding on thicker gauge until one gets the gist.
get a cheap hammer dolly set for a start and 2 grinders, one as a cutter and one as grinder/stripwheel....... saves chaning discs all the friggen time.
I vote they are all winners depending on application.
I vote for a mental cam and sidedrafts/4 barrel ( deliberate 'singular' with cam)
Thanks man!
That was my plan but CBF anymore lol.
Doesn't work/works but smokes out the house. But it looks cool!
have you tried cleaning out under and around the oven box ?? they are often full of soot/ bird nesting/ etc and the fire wont draw if it blocked.
logbook will show it's history
They ceased production of the only falcons worth owning in 1968
$2friggen70 for a panhard!! !!!
will have a nosy in my stash for something 825mm? long
alternatively, if there is other shit that needs cert, then make an adjustable one for diddly
Faster to get to pressure and more flow
really ?? i thought CFM at pump was CFM at pump, and FAD was exactly that.
so if it a 3 cyl 15CFM compressor, then each would be 5 CFM so pressure and flow would be equal to single cylinder 15CFM ??
flow is more dependant on size of delivery plumbing and tool fittings.
did the glass bearings fail ?
i would be inlcined to use a toyota box, w-50 maybe ?
what the advantage having 2 extra cylinders??
what's your budget ?
the belt driven 15cfm ingersoll rand i bought has served me well for over 12 years, this is it's 17cfm brother for similar money:
here's the one i have:
weak point i have found is the wheels don't like rough ground ( centres break) and they nearly fit through the rear-side window of a VN Commonwhore !
i often found the hilux abs fault was often wheel sensors covered in crud, or wiring damaged near sensors
poorly adapted factory bits usually work epic, one dosn't want to over-complicate things too much.
32/36 is probably one of the better options without the expense of a side-draft set-up.
unsure on jetting for your usage, only ever supplied the adaptor and mainfold, or used them on bigger engines without changes.
what cable actuator are you using on the Weber ?
Truenotch's dirt bike powered grass kart
in Other Projects
yip, grass cart
