Posts posted by AllTorque
That burger looks yummo
see you there
25 minutes ago, gibbon said:
I don't quite get what you mean by a bellmouth
Common on WRXs
Why have such a large waste gate pipe? Are you planning on running low boost? What about a bellmouth at the turbo flange into a single down pipe so you can move it forward away from the brake stuff. It seems a bit backward to me to change the brake booster because you made the pipe wrong.
Can you cut the pipe off the flange and shorten the pipe by 20mm?
What heat shielding have you planned for the brake master cylinder? -
Mmmmmmm, RIBS!
I’ll be there. +1
36 minutes ago, gibbon said:
swapping wheel bearings into the new hub, there was no pickup ring or anything like that. I have since read that some wheel bearings contain abs components? I didn't pay any attention to the orientation of the bearings
I’m not sure about this specific car, but many have metal pins in the seal of the bearing to trigger the abs sensor. You can’t really see the pins. Usually the bearing will have a metal seal on one side and a black rubber seal on the other. You want the black side pointed at the sensor. Does the abs sensor point to the bearing?
1 hour ago, cletus said:
My interpretation is a vehicle either has individual mudguards or a body panel mudguard. Like most of the virm it is unclear.
Any time I have called nzta for help they tell me to use my judgment.
Here is my understanding of current WOF requirements for mudguards.
The cover down to the centre line rule is for trucks or flat decks that have a seperate ‘individual’ mudguard. If a car has the body panel as the mudguard it does not need to go down as far as the centre line.
Sublet, so another company has done the alignment. Maybe they are charging time for the apprentice to drive the car to the alignment place and check his Facebook while they do the alignment and drive the car back to work?
Oh,wait, just saw the bottom number. $236 for an alignment and wheel balance. something is not right. Should be half that
Looks to me they have removed the wheel from the car, removed the tyre from the wheel, repaired the wheel, painted the wheel, fit the tyre, balanced the tyre.
59 minutes ago, Nominal said:
Maybe? Would that kill it dead just like that though?
Probably not, but it’s easy to spray some cleaner on it. Or try starting it with the AFM unplugged. Some cars will start without them.
Another thought, crank sensor?
Nope. No airbags for a start. I can’t imagine the meet any emissions standards either.
Is your air flow meter covered in K&N oil?
Yes it is ok to seal over the crack. As long as it doesn’t effect the pattern.
Will turn over but will not start without a coded key. There may be some sneaky way through the obd to make a coded key if you are a locksmith with a fancy computer tool machine. When I was at Toyota there were a few cars that needed new immobiliser ECUs because the owners had lost all the keys. Unfortunately for them the ECU is between the heater box and the firewall, so whole dash out.
They have a factory immobiliser. Key gets read in the ignition.
Nope. Another guy did a wheel alignment. Apparently it had a big turbo.
Shit, that looks good. Better not get it dirty.
Cool.
The booster has a ‘silencer’ or ‘filter’ that is foam around input rod. Chances are when the new pads were put in or the brakes bled and the pedal was pushed all the way down the foam has fallen apart.
If the brakes are working as they should,then the booster is sad.
If you get a hard pedal or poor stopping performance, the booster is dead.Either way, I would recommend replacing the booster.
Sounds like a sad booster to me.
AllTorque's 1970 Buick Sportwagon
in Projects and Build Ups
I haven’t done any more panel work. Wagon has been sitting in the shed except for Wagnats and Swap meat. While cruising around at swap meet the starter was threatening to leave me stranded by clicking and not spinning. Pulled it out and gave it a once over. Brushes were still good, solenoid contacts were worn, so got a shiny new starter solenoid.
