Rolla Beams
New Members
Everything posted by Rolla Beams
  1. hi there. what is the angle on which the ITB's must be on?
  2. What is the power figures if you run ITB's? What difference does make in terms of acceleration,kw and nm.
  3. i have someone that can fabricate for me, is there much difference in the links? the ecu im going to be using perfect power with an extra chip to run both vvti. my fuel setup i have the standard tank whcih i refurbished and running a surge tank to keep the motor from starving. will you be able to send me the designs of the adaptor? how much do you want for the cast aluminium adaptor?
  4. hi there. totally love your setup. im currently busy with the same setup but was thinking of using the original intake, only problem is that its quite huge and takes up a lot of space. so i was wondering how ITB's would look on the motor and then i came accross your setup. i bought a set of 45mm blacktop 20v ITB's but i dont know how to fit them on. can you please assist me. thanks
