kws
Posts posted by kws
  1. 2 hours ago, fuzzy-hair-man said:
    If you can find a place to repeatably attach them you can make 2 rods which are exactly the same length with notches at the same spots and it makes it much easier to setup your box.
    As I couldn't measure straight front and rear of my tires I found 2 bits of square tube which telescope, a couple of bits of rod sharpened to a blunt point which I welded in the ends of the tubes. This makes a telescoping guage which I could measure. To make it work better I cut off a section of the larger tube and welded in a set screw. I measure the smaller of front or back of the tire (use grooves in the tire) set the set screw, then measure the larger, measure between the section with the set screw and the other outer tube and you have your overall toe.
    https://photos.app.goo.gl/rVtqgMGrEnPTWvsE9
    I'll have to give the HPA video a watch later, thanks.
    This is the one I watched that had a couple of lengths of just simple old PVC tube resting on axle stands, which is something I might give a try
    Is your adjustable pole a fixed version of measuring with a tape measure from the inside tread blocks on one tyre to the other?
  2. 14 minutes ago, ajg193 said:
    I'm sure you are already aware, but best practice is to start with both rods equal length and keep them equal.  ie for more toe in wind both out
    That is what the book says to do
    I have NFI how it currently is :lol:
  3. On 01/11/2024 at 20:18, fuzzy-hair-man said:
    As the original position of the steering wheel on the column and potentially the column to the rack? has been changed, I'd start by turning the steering wheel all the way one way then all the way to the other counting the turns as accurately as possible, return back half of these to centre the rack, often the tie rods are adjusted to the correct toe but the rack wasn't centred. Then I'd check the column to the indicator self canceling mechanism, the mini has a little T threaded into the side of the column, with the rack centred it should be midway between the plastic fingers on the indicator that cause the indicator to cancel, (indicator indexes into the outer column so it should only fit in one spot, but mine was deliberately sitting in the wrong spot so the indicators would work). Once all that's set I'd put the steering wheel so it faces straight ahead.
    I didn't really get mine right till I'd done these steps but my mini had been completely apart.
    I'm assuming the setup looks somewhat like the mini, but given BL was in peak cost saving mode it's probably a good assumption.
    The ability to do a wheel alignment at home was great for me as I could tweak suspension settings without continually wasting money.
    The marina, in my testing in Mexico, seems to be tracking bang on straight since the string alignment but yes I'll check lock to lock like you say and see where the rack is at.
    The indicator cancelling in the Marina is done via the steering wheel which has tangs on the back which engage with a plastic collar in the column stalks. It's all the same thing though really.
    Just ordered some fishing line, pretty keen to improve on the home alignment setup. It's a real handy tool to have. If I could afford and had the space, I'd love to have a 4 poster and alignment machine myself. I hate relying on others for things I could do.
  4. Anyone got experience with VH44 remote boosters? I'm looking to add one to the Marina once it's on the road as unboosted brakes are a bit too... manly... for me. I see there are HEAPS of Chinese knockoff ones available, including from "reputable" classic car sellers locally, am I right in my thinking that I'd be better off getting a recon original one, than trust my life with a Chinese one? Or am I just being silly and it'll be fine?
    like, there is this which I presume is just a Chinese one, https://classiccarparts.co.nz/brake-booster-servo-kit-remote-single-line-1-:-1.9-aftermarket-tt3949z?search=servo&description=true
    And on the other end of the scale of Chinese ones, https://www.trademe.co.nz/a/motors/car-parts-accessories/parts-other-makes/brakes/listing/4985996566
    CBC often lists original ones they have rebuilt, which come at a much higher cost, https://www.trademe.co.nz/a/motors/car-parts-accessories/other-accessories/listing/4986494157
  5. 3 hours ago, JustHarry said:
    @kws something you mught find worth investing in is a scrub board. Its for setting toe as a dynamic measurement.
    You drive across it and the top moves from the toe and shows a combined measurement. Often measured in feet per mile of sideways travel . Between 0 and 5 in is pretty good for most stuff.
    They come up on trademe every now and again
    I was looking into these, but they had very mixed reviews and pretty spendy
    https://www.gunson.co.uk/product/G4008/Trakrite-Wheel-Alignment-Gauge
  6. 25 minutes ago, tortron said:
    https://brakeperformance.com/rough-feeling-hubs.php?srsltid=AfmBOorpByE41niF0yOxuzYkahRlSIGU9xF3sxIYrcUg6RJ2UbXKYXv8
    Tldr. They come with "gritty" feeling grease, Let it bed in for a few thousand revolutions
    Thank you, I obviously wasn't searching for the right thing.
    I've done a couple of sealed wheel bearings as an assembly and they have been stiff but not rough like this, so presumed it was bad.
    Will leave it for now and put some ks on it and check again.
  7. So, having just replaced the RH rear wheel bearing on the Marina, because there was a definite rumbling noise/feel from it, the noise/feel is still there.
    The old bearing was bad, it was hard to turn/crunchy once removed, and the grease in it was gross. There were a couple of small marks on the bearing race, but not as bad as I expected. The new bearing spun smoothly in the hand, although with a fair bit of resistance (which i presume is the grease in the sealed bearing).
    The LH side wheel spins smoothly and silently.
    Any thoughts? I was thinking maybe it's a diff bearing, but having spun the wheel with my head near the diff center i can't hear it from there, it's only really noticeable from the wheel end. Could it be a bad, brand new bearing? Pressing it on went fine, I used the old steel retaining collar to only put force on the center of the bearing, not the outer. Once the bearing was "home" I didn't exert more force on it.
  8. I bought one of these a couple of years ago, thinking it'd be handy https://www.machineryhouse.co.nz/s648
    I've barely used it and regret spending all that money on it (should've got shrinker/stretchers instead). The pressbrake has been handy once or twice, but it's nothing i haven't been able to do in my vice with a hammer, quicker and with less setup. The guillotine can only cut pretty thin steel, unless you strip the whole thing and set it up properly it struggles with 1mm. The rolls work, but ive only needed it once.
    Theres a couple of good videos on youtube about them and how when you get them you MUST strip them down completely and rebuild them, as the assembly and tolerances they come with from factory are terrible and it'll struggle to give any results let along good ones
    I should probably look at just selling it, actually.
  9. 5 hours ago, Tiger Tamer said:
    I am interested in this. I need to do the Avenger diff rear axle bearings as well. Never done it before so it would be good to hear any tips. Also any trouble getting the correct wheel bearings ?.
    I'm not sure if the Avenger has the same style bearing, but I think they're much of a muchness. I haven't finished the job yet, i still need to replace the bearings, but I've been following this video as the setup on his Capri is the same as my Borg Warner diff
    I got the bearing kit from Mytools on trademe, which sells the ABD kits https://www.abdgroup.co.nz/?action=autoinfo im quite lucky they do both front and rear bearing kits for the Aus Marina, for some reason.
    • Thanks 1
  10. Regarding rust work tools;
    I have a set of decent snips, and basically never used them for the bodywork I did. They are a pain to use, and thin/bend/curl the edges of the metal. I much preferred to just use a thin cutoff wheel.
    For my power file, which I can also agree is very handy, I got one of these as recommended in another thread on there somewhere, https://www.thetoolshed.co.nz/product/3433-toolshed-file-sander and some green belts from Aliexpress (which way outlast the toolshed black belts)
    and for the body saw I used, it was just a cheapie from Supercheap, and it cut through sheetmetal like butter. https://www.supercheapauto.co.nz/p/blackridge-blackridge-air-body-saw/572837.html#q=body saw&lang=en_NZ&vid=cMJ9mxC5VJn1zET7zKHliw%3D%3D&start=2 It aint perfect, but its cheap and does the job.
  11. 2 hours ago, cletus said:
    can you get a map torch or similar on the bearing housing, give it a bit of a warm up see if that helps
    I dont have fire, but i tried heating the housing up with my heat gun. Got it hot enough i couldnt touch it, but didnt help.
    1 hour ago, shrike said:
    Rear bearings right? might be time to think about dropping the whole diff out?
    Want to post some pics/video and is it one side or both?
    Could you seal the diff housing and try pop it out with compressed air? (id have something to stop it from firing out)
    Yeah Borg Warner solid rear axle. Access isn't an issue on the car, it's just stuck in there and the drum method isn't giving me enough thump. Slide hammer should be here tomorrow, so hopefully that frees it from its home. The Leyland manual does say to use "special tool impulse extractor 18GA284" or slide hammer for short.
