Posts posted by kws
Too many photos. Soz.
But still, here we are
Took me ages to scroll down
Its getting pretty busy in here
Could really do with a new page
First tank of fuel since getting the car done. Averaged 5.98L/100KM. Its currently my most efficient car, and I wouldn't be surprised if its the most efficient car I have owned.
It doesn't get an easy time either, with it coming on boost almost instantly, it lives either on boost or high in the rev range most of the time.
Going from your thread, id be more worried about the Aliexpress steering wheel than the boss kit. Last one I had you could bend the rim just by looking in its direction. Its still on my garage wall as a tribute to the gods of Chinese knockoffs.
I got one a while back. It was OK. It was a real tight fit on the column spline so a bastard to get off again, and the threaded holes for the wheel were cut a bit shite. The metal is also the cheapest Chinesium, so take care not to strip those threads, maybe chase them with a tap first. Other than that, did what I needed it to.
I know the obvious answer is "replace the seal", which will happen, but is having a shitty windscreen seal on a 70s car with a non-bonded windscreen a WOF issue? The glass is secure, but the previous owner replaced the seal with a shite generic one and there are gaps in the corner instead of it being a one piece seal
The VIRM only really seems to indicate it should be "strong and securely affixed to the vehicle", which is is, because it ain't gonna fall out.
red springs could be Jamex
Regarding front panels, a lot of the Evo/GSR ones are obsolete, and ALL rust out, so good to keep spare parts if you can, as you may need it later.
23 minutes ago, tomble said:
Yum! I've been eyeing up some weather shields too but will put it off for now to avoid looking like a copy-cat.
Weathershields are life, highly recommend. These are the ones I bought https://store.shopping.yahoo.co.jp/parts-conveni/99000-990h6-a01.html
We left off the last post waiting on a set of new HKS spark plugs to replace the rather tired-looking ones in the car. They arrived, but did they fix the misfire?
I whipped the coils out, which is pretty easy on the Alto. Just remove the two bolts holding the airbox in place, remove the intake duct (pulls off), and loosen the turbo intake hose clamp and remove it from the airbox
This gives ample access to the coils and plugs.
The old plugs look pretty average compared to the new HKS M40XL. The gap on the old ones was about 0.1mm bigger than the new ones.
I'd say the coils were original. The previous owner had stuck heatsinks onto them with tape (not thermal pads)
I fit all the plugs, using my fancy new magnetic spark plug socket (so lush) and refit the coils.
So, did it fix the misfire? No. It still misfired.
I was sure it would be a coil. The RPM reading on the EVC6 was spiking all over the place and dropped to zero when it misfired, leading me to think it was spark, despite it not throwing a misfire code. It was sputtering at idle and broke down at higher RPM or under load.
Plenty of research was done and I decided to replace the whole set of coils. I could order some original R06A engine coils like currently fitted, or there are plenty of "high output" aftermarket coils on Yahoo JPN, of course there is also the option to spend heaps and get some brand name aftermarket high output coils (KC Technica and the likes).
I chose none of these and found there is an option to use genuine Suzuki coils from a Swift Sport ZC33S with an adaptor harness. This is a kit made by a Jimny owner called dai@works.eng and it's top notch.
I ordered this kit and began the wait.
In the meantime, now was as good time as any to fit the genuine Suzuki weather shields I had bought from Japan.
The instructions are all in Japanese, but with some Google Translating, it wasn't too hard to work it out. I started by cleaning all the areas the tape would stick to with grease and wax remover. I then carefully pulled out the window runchannels.
The reason for this, and one of the reasons I went with the genuine option, is that unlike the aftermarket ones that only stick on with tape, the genuine ones have clips that slide over the window frame and are retained by the rubber runchannel as well as VHB tape
I carefully worked my way around the car, measuring the areas the instructions told me to, to get the perfect gaps all around
Not gonna lie, I'm also a sucker for stuff like this.
ALTO
I'm a huge fan of weathershields. I don't smoke, but I do like being able to have the window slightly open to get that extra airflow, but keep the rain out and not be buffeted around in the wind. It helps a lot in keeping the windows clear in winter too.
While the car was in the garage I also took the chance to polish the carbon blade on the front of the bonnet as it was quite faded. The difference is obvious in the 50:50.
I used some Ultimate Compound on a foam ball on my drill
After that, the car got parked out on the drive and left while Christmas happened, and DHL flung my coils across the planet to NZ.
Finally, today, the coils arrived. Along with a new Greddy air filter to replace the old HKS foam one.
Fancy new Swift Sport coils and adaptors
The new coils are chonky bois compared to the original ones
I plugged the adaptors into the coils, plugged them into the engine harness and slotted the coils into place. They fit perfectly and my screws had no issues reaching (some cars may need longer screws due to the thicker mounting on the coils).
I slipped the new air filter in before putting it all together
So, did that fix it?Heck yeah it did!
The engine runs smoother, idles smoother and under boost it's like butter. I suspect the coil has been weak since I got the car and just gave up when I looked at it and uttered those fateful words, "Preventative Maintenance"
I took it for a quick run around the block to confirm the issue was gone but had to fix one more thing before a decent drive.
Back when the car was last in the garage I noticed something a bit weird... The drivers front wheel was cambered out at the top, meaning it has positive camber. Not good. The passengers side had ample negative camber.
The positive camber was really obvious when looking at it in person.
A quick and dirty check indicated I had about 2 degree positive camber on the RH side
and about 1 degree negative on the LH side
The wheels were literally like \ - \ instead of / - \
I recall I had read on the previous owners blog that he had fitted camber bolts at one point, so that was the obvious place to start. My plan was to remove them for now and just run standard bolts, so after a Pick A Part run to grab some of the correct part number from an old Ignis, I jacked the car up and had a look.
Sure enough, camber bolts fitted to the top of the knuckles
I could've just adjusted the bolts correctly and dialled the camber in how it should be, but at the end of the day the car isn't lowered anymore, it's on standard suspension and I don't really need heaps of camber at this point. So out they came.
Both sides had been badly adjusted. I'm not sure if the guy I got it off who swapped the suspension forgot to set them, didn't know how to set them, or just didn't notice they were cammed bolts. Who knows.
The RH side bolts were barely hand tight too, which was a concern. I fit the replacement standard bolts and gave them a good elbow-clicking torque.
After reassembling everything, we now have about half a degree of negative camber on both sides
And what a difference it's made. I took the car for a decent run over some twisty hill roads and it's much more controllable now. Before, when you let off the throttle mid corner and the diff unlocked, it would dart sharply toward the middle of the corner (usually toward the center line) with murderous intent. Now it still noticeably unlocks and tucks in, but it is much tamer.
The car in general is running much better, much smoother and loves being driven hard. The diff just pulls the car around corners on boost. I've had cars with torsen LSDs before, but this plate diff is a different beast.
The new gearbox oil has improved shifting, and the diff seems a bit happier, although it's still a clunky old thing when cold. I can live with that, we'll call it character.
Now that we're back up and running, I'm looking forward to getting some Ks under the new tires and seeing how this little thing really goes. So far, I'm loving it.
Hopefully it'll be on the track next month as I have another track day booked. That'll be exciting.
Finally, here are some photos of the car that aren't in my garage, sans stickers and with weathershields.
The carpet should be here in the new year, which I'm really looking forward to.- 25
4 hours ago, Nominal said:
I just bought an un-plated import. It had a WOF and when I arrived we ran it around to VTNZ and had the plates issued.
Same with my Alto, seller ran it through compliance, it got a WOF, and I just took the MR2A to VTNZ and they exchanged money for plates. They didn't even need to see the car.
12 hours ago, Raizer said:
Happens here a lot too, normally rough 4x4s or Tesla's parked straddling 2 parks.
Shitty old teranos and things parking in EV charging parks seems to be a point of pride for the owners. Assholes.
3 hours ago, Nominal said:
No security features on those plates, so you should be good to go on.
As long as the plates made arent more modern than MX#### I guess
1 hour ago, tomble said:
I've got some plugs I haven't installed yet if you want to come over and try them out
Cheers, mine arrived this arvo. NZC didn't try and deliver them to the wrong suburb this time, which is nice.
Despite the car currently throwing a grump and being stuck in the garage, there was still work to be done.
One of the main things I needed to do before driving the car more was to replace the tires. All four tires, based on the date code, were the original ones that came with the car new. Unsurprisingly, they were all down to their wear markers, and not that safe to be driving on.
I ordered some new Yokohama ES32 Bluearth in 175/55R15. This is one size wider than the standard fitment 165/55 tires because 165 isn't a very common size here in NZ.
I can order some awesome tires like the AD09R in the correct size from Japan, but would mean if I blew or damaged a tire I would potentially be months away from having a replacement, and that's no good. 175s are on the shelf, ready to go, albeit not in some of the best semi-slick tread patterns.
I've been running the ES32s on the daily Honda for years, and I like the compromise between comfort, wear and grip. Even in the wet I have confidence in them.
After work, I fit them to the Alto. I had originally planned to run some nice new red (to match the calipers) open-ended wheel nuts, but they're just too long and stick out past the face of the wheel
The reason I wanted open-ended nuts is because the owner in Japan had been running spacers at one point and had replaced all the studs with slightly longer ones, which poke out the end of the stock nuts. Not to mention the lock nut is unsightly.
I've found Aeroflow does some short, open-ended black wheels nuts, so will grab some of those at some point, but for now, whats on it will have to do.
The new tires look good, very purposeful and slightly chunkier than the old ones. Hopefully they aren't too soft in the sidewall from being that little bit fatter, but we will see.
While in the garage I took the chance to fit some more bits that arrived from Japan.
I have a real hatred for cars that don't have rear wipers, especially with tinted rear glass, as once it's dirty the glass is impossible to see through.
In Japan, the previous owner had removed the wiper and fitted an R's Racing Parts wiper blank
Removal is easy. Remove all the clips on the tailgate trim and remove the trim. This is the cheapest, lightest and most "cost-effective" trim I have seen. No effort to hide the clips or anything.
With that removed, you can see where the motor should be, and the back of the blank. The previous owner had kindly ziptied the plug I needed up and put the bolts back in their holes so I could reuse them.
Using a spanner, I removed the blank. It has the inner and out parts, both with a rubber seal to seal against the tailgate
These are the parts from Japan. A motor, with seal, wiper arm and blade. The motor came with some harness but wasn't needed.
I fit the grommet to the tailgate, put some silicone grease on the motor shaft and fit the motor into place. The arm just slides onto the spline and is held with a nut. It took a couple of tries to get the arm in the right place, so it sat horizontal when parked.
Tested and working well. Probably needs a new blade at some point, but it's fine for now
You can see here the difference it makes in clearing the glass
Very happy with that.
Now I'm just waiting on spark plugs, to see if it cures the misfire, if not, I'll need to wait until the coils arrive from Japan and cross everything they fix it.
7 hours ago, KKtrips said:
See Note 4 (or 5, I can't remember which - I looked at it earlier today), I have a stick on plate on the front of my Prius and I will be using that as an out if I get poked by my WoF inspector.
Good spotting, but I'd wager that unless you've somehow removed the factory fittings, they'll fail it until you refit it as standard. I guess it depends how much of a dick you wof man is though.
Regarding the black plates, I'm surprised they haven't pulled them yet or done some sort of swap out recall to fix the ones you can't read in the dark. All in the interests of safety, no doubt.
Going a full circle into a Marina again. KwS's 1973 Morris Marina Coupe.
in Projects and Build Ups
Now?
