Posts posted by kws
Going from my drive this morning, even at almost-stalling rpm the alt is still pushing a min of 13.5v. Normally it didn't drop below 13.8v when driving.
3 hours ago, ajg193 said:
Heck that's expensive. At what point does it make someone an inconsiderate prick when their worn out old car is blocking a charger for a long time due to reduced charge acceptance?
If youre at 80% and still trying to squeeze more in, youre a hog. It really pissed me off when I needed a quick charge and some shitty old leaf was blocking the charger trying to get another 2km range.
Need special chargers for slow cars.
2 hours ago, AllTorque said:
Re dash lights, check your alternator and battery. Often when there are codes everywhere it causes by low voltage. A lot of modern cars will turn off the alternator when idling until there is enough electrical load.
Oh yeah, i didnt mention it but i tested the battery and alt and both had good voltages. It is a Japanese battery, so no idea how old it is, but it has no issue starting the car. I do wonder since I was creeping along in traffic if the revs, and voltage, dipped a bit low and caused the CANBUS to throw a wobbly.
The Alt has a normal solid pulley, so fancy clutched pulley here, so no idea if the ECU can control it.
It's been an interesting few weeks. I had a scare in the Alto, and more parts arrived.
The weirdness started when I was taking the Alto to work the other week. I jumped in, started it up, and all was normal. I'm cruising along, jamming to some tunes, and hit the usual start stop traffic. I'm just crawling along... And BAM, ALL the dash warning lights suddenly light up and start flashing. They flash a few times and then the majority turn off, leaving only the Check Engine and Stability Control warning lights lit.
I'm worried, will the car suddenly die stuck in traffic? Is the car about to asplode? I've never seen all the dash lights flash like that. I quickly jump off the highway at the next exit and crawl the car home.
It was running fine, no misfire, no smoke, no leaks, nothing. Just the lights.
I made it home fine, swapped cars and left it to think about what it had done.
After work, I plugged in the tablet and fired up SZ Viewer to scan the codes. Ah yes, I think I have a couple of codes. None were current, but nearly all modules at at least one code.
Reading into the codes, they all centered around one thing, the loss of CAN communication with the ABS unit.
I checked all the modules and they were all the related codes, so I saved screenshots of the codes for later and cleared all the codes in the modules. Nothing came back.
I've driven a few hundred KM since, and haven't had any issues, so hopefully it was a once-off and not an intermittent CANBUS issue.
I did have a quick look at the ABS module and it looked normal, so I gave the plug a wiggle and left it
While in the engine bay, I forgot that I hadn't shown my awesome duct tape duct.
For whatever reason, either the intake rubber intake or the fibreglass duct are too short and they don't really meet up, leaving a large gap between and around the two. I made the duct tape duct before trackday to try and encourage more air into the airbox rather than slip out around the smaller rubber intake. Its fully enclosed and seals the two parts together.
It withstood the trackday heat and is still there. I might look for a proper solution one day, or maybe not.
The other day I finally had some bits arrive that I have been trying to get for months. Before Christmas, when I first got the car, I tried to order these bits through the local dealer. They asked Suzuki NZ, who asked Japan, and were advised they could be ordered, so we placed the order.
Japan then proceeded to ignore the order and not process it. After a couple of months of chasing it, I cancelled the order.
I enquired with Amayama, who I have been getting the majority of my genuine Suzuki parts through, and sure enough, they could supply and at a lower cost.
Finally, those parts arrived. What are they? Well, the main one was the massive polystyrene insert that sits in the boot and gives me a proper boot floor. Without it, the floor of the boot is much deeper but tapers and makes it kinda useless for carrying anything in.
The insert just slips into place
All the shaped spaces in it are meant for things like the jack, tyre iron and flat tyre goo kit. I have none of these, so all it is used for is my tow hook
I would like to find a water bottle for the intercooler spray that fits into one of the spaces too...
Having the block in place means I could reinstall the coreflute "floor" and carpet. These are retained with two special clips with little pull tabs on them, so you can access the tools under the floor
It's a kinda dumb thing to be excited about, but I can finally use my boot.
The other thing to arrive was the LH and RH front A-pillar trims. The LH side had a big crack in it, and the RH side had a bunch of holes from when the Japanese owner had a gauge pod fitted there.
To remove these trims, all you do is pull down the door seal
And pull the trim free, starting at the top.
It's hooked into the dash at the bottom, but easy to pull free. Refitting is the reverse, hook it in at the bottom and then push the clips into place. Refit the seal, and you're done.
I've got a couple of other small things on the way and then that should be most things sorted. It's crazy how well priced genuine parts are for these wee things. I'm paying the sort of prices I would normally pay for secondhand junk on Facebook, for brand new parts from Japan.
Future thoughts are an oil cooler for the engine, an SWK intercooler and water sprayer, and maybe some half-down lowering springs. All in good time, and depending on cost.
- 8
7 minutes ago, Nominal said:
Looks like you might need to buy it back and fix it up again.
Not one of my old ones, thankfully. I know where both of my old Zircon ones are. This was just one from my collection of NZ Sd1 photos.
The wheels will be some Minilite clones of some sort.
I had no issues with my 14point7 spartan. Easy to use, compact and reliable. A+ still have it to use again later.
Also bought a Glowshift gauge unit to use as a portable wideband setup. Also works well, but was pretty spenny new.
29 minutes ago, ul9601 said:
what's so great about recaro? a genuine question.
Comfy and body hugging. Holds you in better for mad touge racing
- 5
Probably depends on what car you're painting too.
I quite like the Mitsubishi A39 Graphite Grey used on the Evo 8/9/10
As you say, Nissan BL0 is a nice colour too
6 minutes ago, tortron said:
ah yes, wet primer grey.
Almost everything was being painted in that boring colour a few years ago
45 minutes ago, Bling said:
If a HKS coilover'd Note is a shitbox, boy have I got the wrong idea. Might have to keep the wheels unless you want to pay Clints beer tab for a while. They look good to me, maybe a new colour would change your mind? Are you sure it's not a midlife crisis car?
Yeah that Note is nicer than my daily
On 09/03/2024 at 21:23, Doug Hill said:
All the premium EV stuff had resale like an S class merc, it's absolutely wild how anyone can comfortably piss away 100k in a couple years just to own a car.
Tbh most high end merc/s class owners leased anyway, so gave the car back each year
Afaik marinas have it as per of the alternator
Just now, KKtrips said:
I banned them, because they are a fake account, ie: not a real person, but left the discussion up because it is a good discussion.
I'm curious, what tipped you off they aren't real?
3 hours ago, ul9601 said:
regardless it's a daily or a "collectible", 6 monthly wof is no big deal if you got your car in tip top shape, as it should be. if you can't manage your dozen-car fleet to be roadworthy and wof'd, i think you got your hands too full.
Having spare time and $80 each check must be nice. For me at least, It's a real ballache if you have more than one or two cars that are 6 monthly wofs, plus at least one that has yearly. All that time and money adds up, even if they do fly through each time. Heaven forbid it fails on anything, no matter how small, because that's more time wasted waiting for a recheck.
I thought it wouldn't need a cert since technically it's "factory fitment", Nismo being a division of Nissan after all?
I mentioned in my last post that I had new shocks on the way, well, they arrived, so let's get them fitted.
I began by jacking the rear of the car up, putting it on stands and removing the rear wheels. This gave me access to the shocks and springs.
Both the yellow stripe and the part number on the shock indicate that it was a poverty spec shock from a low spec (not Works) Alto. Note the missing lower rear spring pads, the spring shouldn't be sitting on the metal like that.
The spring also had the incorrect colour code, yellow and white, not blue and white like the Works spring has. Other than the paint mark they look visually the same, I don't know if the Works has a higher spring rate or anything.
Removal is really easy. On my car the side boot trims have been cut, I believe for the damper adjusters for the adjustable rear shocks the car used to have. This gives me perfect access to the nut that holds the top of the shock in place. Because I didn't care about the old shocks, I used a rattle gun to zip the nuts off.
Before completely removing the nut I supported the rear beam with a jack under the spring, so the force of the spring wouldn't ping the arm downwards
With the top nut removed, I removed the lower bolt on the shock and removed it. This one was very dead. Because they have gas in them, once compressed by hand they should extend to their full length again. This one had no resistance to compressing it and made no efforts to extend. The other side was only marginally better, where if you left it for about 5 minutes it would have extended in full (it should extend to full in a matter of seconds).
The new shock has the correct KYB sticker and P/N on it, but it appears the new replacements don't get paint codes like factory-fitted ones do; the factory paint code for a Works is purple and green. I ordered these from the parts book to Works part numbers, so I know they're correct.
With the shock removed, I could push down on the hub by hand and pull the spring out. I then fitted the new lower spring pad, in the correct orientation based on the service manual
I then replaced the old upper spring pad and fit the spring
The new shock slips into place next
The top mount on the shocks is interesting to me. The top of the shock has a captive rubber mount and steel sleeve. There is then a top bush and metal washer that sandwiches the shock tower into place.
On the underside of the shock tower there is a metal cup that locates the captive bush
Even the top bush is weird, the shoulder goes face-up
The washer sits on top of it
and the nut is placed on top
As the nut is tightened, the bush squishes and flattens out under the washer
I guess compressing the bush like that creates a fair bit of tension, so the shock won't be rattling around in a hurry.
Other than jacking the hub up to ride height and torquing the lower shock bolt, that was one side done. I copy pasta'd the other side.
and then onto the ground it went.
With the combo of fresh new zero km un-saggy springs and the lower spring pads being fitted, the rear ride height has increased a touch. It's only a couple of mm higher and should settle a little as the springs bed in.
I know why they put the KYB sticker where they did now
The Suzuki lineup at work the other day
So, how does it drive now? Well, the blown shocks explain a lot! I thought it was just lame povo spec shocks, but even that wouldn't have been as bad. On the road at low speeds the rear feels firmer, but there is a huge difference in how the car feels on the open road, the rear is much more planted and doesn't pitch and dive so much.
In the corners, it's a lot more controllable and the rear doesn't feel like wobbly jelly. I still think it needs the extra stiffening of the rear swaybar to balance it, but cornering speeds can be higher than they were beforehand and the rear follows the front wheels like it should. I reckon it'll be good for a second or two off my laps at Manfield next time, particularly if I can get it to rotate as the Jazz did (no hope for trying to do that when I was lacking any confidence in the rear end).
Some more (boring) bits should be with me soon to tidy the interior up further, and other than that I'll just keep driving the pants off it. Should hit a milestone soon too...
- 18
On 20/02/2024 at 07:41, locost_bryan said:
Just set the grill back a few inches and call it a mk1 Landy.
Although, since it's a cheap copy, call it a Mitsi or Suzuki or Mahindra?
Stick the three diamond badge on it, scrap the batteries, fit a 2 stroke powerplant and forever bask in the glory of it being followed by a haze of blue smoke.
52 minutes ago, 87creepin said:
Ralliart Colt is the logical next best choice.
Have you seen the prices of them recently, particularly the manuals? Oof
I'd rock the pants off a Dingo. Cool wee cars
Old school tachometer, driven by aftermarket ecu? How please?
in Tech Talk
I guess you could use something like this to drive the tacho if its analogue, https://spiyda.com/smiths-rvi-rvc-conversion-external-1.html You should be able to feed the tach signal from the ECU into the box, but as Goat says, there will be a few different makers of things like these now.
Im running this version of it for the Smiths tacho in the Marina, which takes the signal from the negative of the coil, does some electronic wizardry and then the needle moves, https://tasteslikepetrol.net/2021/06/project-marina-tacho-conversion/
