Type49
Posts posted by Type49
Hi everyone, i thought i'd start this so if anyone has any questions etc i could try to answer them. Cheers
Brief spec on the car before the rebuild was 1600cc Xflow, Kent 244 cam, big valve head with double springs and steel rocker posts and solid spacers. Datsun pistons and twin 45mm Webers. 4 speed Straight cut , close ratio Tran-x gear kit. English axle with a steel plate type LSD 4.9:1 Ratio. Two link rear end. 4 wheel vented discs and bilstein shocks all round. Quick rack and a world cup cross member. All pretty normal for a rally car of that era.
Plans for the rebuild are making it look more like a period works escort of the 70's, ie. Satin black interior with correct works twin cowl dash and centre console, correct smiths gauges etc etc. Improving the rear suspension travel by adding mini tubs and a diff tunnel. Adding a panhard rod, proper seat rails and sill mounted jacking points.
I will still use the Tran-x 4 speed and same rear axle, i may have to change to a 5:1 diff ratio tho with the new engine.
- 7
Hi all .
Back in 1992 i built myself a Mk1 Escort rally car, i used this car for a couple of years before barrel rolling it in Woodhill forest at a rallysprint. After sourcing another shell i reshelled the car and did events in it till '99 when i parked it in container while i went on my OE. Fast forward 20 or so years...
So after a gentle nudge from my partner that went along the lines of " You should do another rally before you're 50.." So i started to unearth my Escort ( it has been out of the container for about 10 years ).
I will try to up load some progress shots as we go.
Cheers for following!
- 38
Evening all. I thought I'd start a discussion thread if anyone had any questions about my build. Cheers Steve
More work on the rear axle today, bare housing has been stripped, rust treated, etch primed and painted satin black. Will be checking diff, cleaning, painting and hopefully fitting it to the housing today. Pics to follow.
I wish i could work on this full time.... Making some good progress this weekend.
Type49’s Mk1 Escort Rally Car Rebuild
in Projects and Build Ups
Car stripped and mounted on spit to start the paint stripping and mods.
