Type49
Everything posted by Type49
In keeping with the " works spec" twin cowl dash and "Mada" centre console i thought i'd make a start on the dash. As with the works cars they started with a genuine 6 dial dash as the starting point. Now i happened to have one of these that i kept as a spare even tho someone had decided it looked good painted pink!
Yes AX motorsport block, yep going out to 85mm so it'll be 1760cc. Nice amount of torque ... Would be cool to see some of the projects in your shop too. Cheers Steve
Correct ! L16 goodness, The new engine will still have a Datsun connection , i'm using an L18 fully counter-weighted steel crank which is getting massaged to fit the AX crossflow block. Should be a nice strong bottom end.
- 268 replies
- 19
Note the new sill mount jacking point in the pic too..
Working out where i needed to make some clearance to get the most travel in the rear. After cutting out the original diff tunnel the axle tubes now sit on the chassis rails and the tops of the tyres are just touching the tops of the wheel tubs. Here's a pic of what the maximum bump travel would look like. This is the most i can do without raising the chassis rails and wheel tubs which would involve changing the rear of the rollcage as well..... Too much work !
- 268 replies
Brief spec on the car before the rebuild was 1600cc Xflow, Kent 244 cam, big valve head with double springs and steel rocker posts and solid spacers. Datsun pistons and twin 45mm Webers. 4 speed Straight cut , close ratio Tran-x gear kit. English axle with a steel plate type LSD 4.9:1 Ratio. Two link rear end. 4 wheel vented discs and bilstein shocks all round. Quick rack and a world cup cross member. All pretty normal for a rally car of that era. Plans for the rebuild are making it look more like a period works escort of the 70's, ie. Satin black interior with correct works twin cowl dash and centre console, correct smiths gauges etc etc. Improving the rear suspension travel by adding mini tubs and a diff tunnel. Adding a panhard rod, proper seat rails and sill mounted jacking points. I will still use the Tran-x 4 speed and same rear axle, i may have to change to a 5:1 diff ratio the with the new engine.
- 268 replies
Here are some before pics of the inside floor before stripping and fabricating of the new seat rails and sill jacking points.
- 268 replies
Hi everyone, i thought i'd start this so if anyone has any questions etc i could try to answer them. Cheers
- 268 replies
Brief spec on the car before the rebuild was 1600cc Xflow, Kent 244 cam, big valve head with double springs and steel rocker posts and solid spacers. Datsun pistons and twin 45mm Webers. 4 speed Straight cut , close ratio Tran-x gear kit. English axle with a steel plate type LSD 4.9:1 Ratio. Two link rear end. 4 wheel vented discs and bilstein shocks all round. Quick rack and a world cup cross member. All pretty normal for a rally car of that era. Plans for the rebuild are making it look more like a period works escort of the 70's, ie. Satin black interior with correct works twin cowl dash and centre console, correct smiths gauges etc etc. Improving the rear suspension travel by adding mini tubs and a diff tunnel. Adding a panhard rod, proper seat rails and sill mounted jacking points. I will still use the Tran-x 4 speed and same rear axle, i may have to change to a 5:1 diff ratio tho with the new engine.
- 268 replies
- 31
Hi all . Back in 1992 i built myself a Mk1 Escort rally car, i used this car for a couple of years before barrel rolling it in Woodhill forest at a rallysprint. After sourcing another shell i reshelled the car and did events in it till '99 when i parked it in container while i went on my OE. Fast forward 20 or so years... So after a gentle nudge from my partner that went along the lines of " You should do another rally before you're 50.." So i started to unearth my Escort ( it has been out of the container for about 10 years ). I will try to up load some progress shots as we go. Cheers for following!
- 268 replies
- 38
Evening all. I thought I'd start a discussion thread if anyone had any questions about my build. Cheers Steve
Evening all, I'm really wanting to complete the rear axle so have had a really big push on it today. Have assembled one side of the brakes, happy with the outcome... even if nobody else sees them.
