a shitty phone pic while being panel and painted, note rear guard height in relation to the lines of the car compared to first pic
soooooo i better have a break down of what has been done so far...
ENGINE/GEARBOX/DIFF
The engine was a freebie from Simon. W55 gearbox and i just happened to have the correct bellhousing lying round.
There was issues with the headers fitting, BUT ALAS! they happen to fit upside down, so some 2.5" U bends were bought and some super head-turner headers were born.
But what really blew my mind was that the 1GFE throttle body points upwards....... in the same spot as the 4k carb........ with the same OD! so the factory air cleaner assembly was retained and is still plumbed up to suck air from the inner guard. Between the intake and the exhaust, many LOLs were had. Oh and it has a SURFAB flag.
I already had a link G4 storm for the Starlet, so i bought a second loom and wired it in. I can't drive both cars at the same time so one computer with two maps is perfect.
The firewall was cut and half the trans tunnel went with it. Cheers SURFAB for folding/rolling up some new ones!
I had a spare hilux diff which was shortened, converted to disk brake, with new mounts and redrilled stud pattern to suit my weird ass wheels (4x130)
SUSPENSION
The fronts are shortened strut castings with shorter shocks, coil over springs and keepers on a new spring perch. Luckily it is a late model wagon, so AE85/6 bits bolt on with no redrilling or modifying. Some camber plates up top while the LCAs have been rose-jointed, very helpful for widening/shortening track to fit wheels.
Also in the mix are some motorFIX 45mm RCAs and Hardrace caster arms.
The rear leaves have been reset 3 inches with an extra leaf for stiffness and has 2 inch blocks. Hilux front shocks now live in the back to keep things firm.
The bumpstops have been relocated due to the original bumpstop mounts being cut off due to clearance issues. The chassis rails have been notched for the diff and the floor under the backseat cut out and remade to clear the diff head and driveshaft. I swear every time i cut something out, the car would sit on another part of the diff!
BODY/WHEELS
As you can see the rear guards were cut right out to fit the wheels. I wanted to have an standardish looking body so didn't want any bolt-ons or moulded guards. Some front KE70 guards were acquired (thanks Cheerios), the flares were cut off and the stitched onto the back. I really wanted the flat edge on the side of the guards and I think it worked out perfectly!
The wheels are SSR Formula Mesh in 15x8s and 8.5s with 195 45 15s all round
So theres still heaps to do before cert so there will be a lot more pics/updates to come
