Posts posted by SOHC
3 hours ago, bathcollector said:
I have one Rudi, $800.00, runs well but a bit far to come pick it up I guess ?
Got any pictures, could be keen,
Would anyone in Auckland have a Volkswagen beetle pedal assembly I could borrow or take a look at?
A JR80 would probably keep up with traffic on the open road
I am in the market for an XR100, I think a Kawasaki KX60 would be too much for him at this stage?
Nz has a major dirt bike shortage, no one can afford a new one and all the hoodrats have driven up the prices on used ones
5 minutes ago, tortron said:
When did you become a quality used motorcycle salesman?
I have 2 dr200 engines where they have just cut the kick-start shaft off and silicone up the hole.
At least buy the factory rubber bung m8
Are they electric start to?
This kick start broke off flush with the side cover and its a split the caces job to fix it, tapped a bolt into it and welded the shit out if it
I welded a kick start on today,
On 08/12/2023 at 12:15, myk00l said:
He sings lots of honda 50 songs, gets stuck in your head horribley
On 03/12/2023 at 18:37, MIRAGE-MAN said:
I recently got out one of my old man's 30+ year old AM Uniden CB radios that he used in the late 80's. Got it wired up in my work truck, through the cigarette lighter, then his old magnetic antenna on the roof. Works well. I chat with a few other truckies through CH 11. But apart from truckies is the CB widely used now. Cause there doesn't appear be any activity on any of the other 39 channels.
Put a call out on the weekend or evenings on chane15 26.500mhz and there are a cople enthusiasts,
See you had been messing with things and pore old Kjet gets the blane
7 hours ago, Kiwibirdman said:
I have both 308 and 350 chev flex plates in the garage. The bolt pattern for the crank looks the same, so you should be right. I don't believe that GM changed the bolt pattern on the 305.
The flex plates are different, the offset is changed other wise the same.
Cool thank you, the bolt pattern is all that needs to match for the jetboat application
Most fucked old shit gets people hard round here
8 hours ago, kws said:
The WUR should have no impact on the cold start injector, it'll be electronically controlled, usually by a thermotime switch. Its worth checking the cold start injector isn't leaking though, as they can be known to do that.
I discovered the wiring for the WUR in my volvo was completely burnt and shorting out and it had no impact on the cars running, some of that same wiring I think was connected with.
I have a few spare kjet systems if you need anything? I probably do more miles with this system than anyone and I believe thats what they like or they have problems
3 minutes ago, tortron said:
Yes I think I mentioned its based on a GN125
The genuine gn 125 wouldn't do that in a week
After replacing the WUR is the cold start injector shutting off?
Engine may make more power but that bike is probably a week old and already chrome is coming off and frame is cracked in 10 places and engine makes a loud ticking noise and its on its 3rd seat cover and some how forks are full of water and gear change spline has rounded off and the ignition fell apart
Dont fuck with Kjet, just keep driving using injector cleaner,
The rule with k jet is dont fuck with it
I sent a piston to a shop to have the ring groves widened for new rings and I marked the front with a scribe on the crown its a split skirt piston and it has a T slot in one face, the shop took a cut off the piston crown and polished it for some unknown reason and now I have no idea witch way round it went
6 hours ago, locost_bryan said:
This thread says close but no cigar Holden - Chev flywheel - Engine - GMH-Torana
Its just for the adapter plate witch bolts to the flywheel to attach the UJ for a jet boat, I could slot one hole
I really want a shovel head but every one I have looked at in my price range has been totally destroyed
Bike spam thread
in General Bike Chat
What motor is that?
