Posts posted by SOHC
1 hour ago, Indiana_Jones said:
I see the new 'BSA's are coming to NZ
https://www.autocar.co.nz/bsa-returns-to-new-zealand-shores/
It looks like someone forgot to fit the carburetor and bolted the airfilter to the head and when they were inflating the tire it leaked into other parts of the bike and then got rear ended by a truck and some bicycle parts fitted
4 hours ago, tortron said:
Normally there would be a protective layer of cowshit holding it in
Yes there was on noth engines
TF crankcase gasket started leaking really badly, its like the crankcase halves dont even match in shape, engine nipped up but came free, that engine has been a total Jonah from factory,frend gave me his ktm 520 to use
Bike fucked out
4 hours ago, Lord Gruntfuttock said:
I tapped lots of chewed out alloy threads on the ironhead to metric coarse.
Seemed to go ok, but it's a pin in the hole having to use metric and imperial tools...I have tapped all the drain plugs on my ironhead to metric because some monkeys stripped them
3 hours ago, 440bbm said:
that was my thoughts. same method. the 5degrees of pitch angle difference between whitworth and metric/imperial wont matter and will screw in. might be more luck with a 1/2" over 12mm in brass.
1/2 UNC might bite into the alloy better?
1 hour ago, GregT said:
Best fix is old school. Tap it 12mm and make up a brass insert 12 on the OD, 8mm on the inner. Put a drop of Loctite on it when the bush goes in.
I could use a brass bolt and screw it in, they sell silicon bronze bolts but they are super hard.
my Dum and Dummer stretch bike ran well all day, it was getting slower but that was the outer throttle cable slipping in its clamp, I could blow the rotory away.
- 8
16 minutes ago, Motu said:
Sounds like Bruce - but he's more likely to break down because he replaced a high tensile bolt with a coach bolt.
The tractor PTO clutch plates he found in a bin were playing up
Minibike drags today, I am taking the stretched bike, I really hope people are not going to take this event seriously
1 hour ago, cletus said:
Nope. Which is kind of weird as you can't read speedo at night without a light
Has to have high beam light and something to tell you the indicators are on, that's it
He must of been checking with his boss and when they sed its ok he just gapped it
Are dashboard lights a wof requirement? I got pulled over the other night for a routine stop and the cop started going off about the dash lights, I was going to show him how there is a factory switch to turn them up and down and off but he went back to his car and then drove off
I can make you a port map from something I have here but you would need a sleve with no ports to start with as it needs an exhaust port bridge
On 26/03/2024 at 16:41, 63Ragtop said:
I'm fully Gunna snake you Torrie!
I should have sold the details
13 minutes ago, GregT said:
#308 in the top pic is an oddball. Jawa top end on a BSA ? And is that Inia holding up the fence ?
308 is Bruce Frasier and yes thats a Jawa head but thats an air compressor barrel under it, when I was going to beat him so he went home. Inia is somewhere elce
Oldfuckedlathes.co.nz
3 minutes ago, tortron said:
Please. I think.i could use some bits on mine
I sent you a pm with the details but it says you cant receive messages
On 22/03/2024 at 07:50, Vintage Grumble said:
Is there some sort of lyfe hack for getting paint off motorbike plastics? Or just good old fashioned sanding?
ALSO, has anyone had good results sanding/polishing scratches out of clear plastic windscreens or the like?
Petrol works if its just spray cans.
Bike spam thread
in General Bike Chat
Triumph made some ok looking fake carbs but failed hard in every other area like proportions of things
