NewGuy
NewGuy's Achievements
Post Fiend
Post Fiend (4/5)
3
  1. As some of you know i am looking at putting a Sr20Det in the Trump. I need to either make the Subframe lower to the ground, to get out of the sump way or go around the front of the sump. What issues may i have with getting a cert with changing this?
  2. NewGuy
    Coils
    Nah it'd spit and loose power
  3. NewGuy
    Coils
    Just a quick question about coils. I just replaced my so called 12volt coil in the car along with all the other ignition bits. I brought a Bosch GT40R off trade me, so i had to get a ballast resistor to run with it. So anyways with the old coil in but all the other new ignition parts it would drive and rev sweet but if i lost traction and over revved it it would then ping under load. Now with the new coil with nothing else changed you can do what ever you want and it never pings, would it have made that bigger of a difference not having the ballast resistor to keep the running voltage at 12Volts on the old coil? Cheers Stew
  4. Took my brake setup to my local cert man, he said it's perfect and it would fly straight threw.
  5. That is so tidy man i like it alot, who did you buy your k&Ns off?
  6. Found the Front Zaust leak, Gunna do a dodge on it now and fix it up properly once its on the road.
  7. Ho Hum, National preparations already, would have been easier to pass
  8. Went for a Wof this morning with the car basically untouched since my last couple of warrants And i got Failed on Both rear doors not opening nicely, Window wipers just stopped working, Left rear indicator not working, Handbrake shit on one side, Zaust leak up front where you carn't get to ohhh and its to noisy, its gotta coby, WTF same as the last 2 Wofs. Lol Trumphy does it again. Also the guy was kind of cunty lol. Ahhh well Lady in the office said that the older guys doing the wofs now have taken a disliking to the younger guns cause they come in telling them wat to do and the rules etc. fucking boy racers, and i think this is what i got classed under.
  9. Bro Top Marks, Best Read Of NZPC i might even buy it just for your article.
  10. 1Litre of primer plus thinners did my whole car. Im not sure the Paint Ratio, what kind of paint? Also there is already a paint thread man,
  11. Looks Sweet Love the Grave Yard Shot
  12. That is Freaking Crazy, Not a bad idea wither
