MS51HT's RS56 Crown Ute
MS51HT
Had another successful weekend in the shed working on the ute. I'm pushing hard to get the two car halves stitched together as soon as possible so that the car can be condensed into one - the space that the chassis, front hand, rear half and OE RS56 front half consumes is getting out of hand.
My shed is starting to look like a hoarders den - with small passages and alleyways providing access to the various troves of parts and tools hidden within the workshop.
As a family, the upcoming year is going to be massive - a couple of overseas trips within the next 8 months combined with plans to renovate the house is giving sufficient motivation to free up some space in the only domain I have total control.
Fortunately, my wife is an absolute champion - and after a quick chat over the morning coffee she gave me her blessing to abandon her and the kids for most of the weekend and the promise of allocated time on the upcoming Anzac day public holiday.
So I got into the shed and tried my best to stay on target - which was resolving the rusty spots that would later be difficult to work on once the two halves were merged.
The inner structure panels were fully welded in and the weld penetration to the inside ground back. Not aiming for a file finish - but close would be nice!
Once that was done, I moved onto the lower section of the rear firewall. I slipped the upper firewall section back in to help establish where the missing metal was. Folded up a small template to show where steel should be.
Made a paper template up to pick up the key fold lines and general shape based on the best guesswork I had to offer.
After tweaking the template, I marked out two pieces of steel to make a patch for each side.
Replacement panels then folded, trimmed and spotted into place.
Once I got those situated, I moved onto the next big piece which was continuing the upper lip to which the upper rear firewall section spot welds to.
  • 4 months later...
Long weekend in WA gave me the opportunity to spend some time in the shed.
I considered working on mating the two halves together - unfortunately by brain couldn't see enough dopamine in doing that.
My brain suggested we do something cool, like work towards putting the M engine in between the front rails.
Issue the first - the damn R engine mounts and totally wrong for the M engine.
Luckily I have a partially disassembled MS55 to use as a comparison to see just how different they are.
To preface this, I had known about the discrepancy for some time - so I put the word out on the internets that I was chasing some mounts, with the hope that someone out there would have an old chassis that they could sacrifice for my greater good.
A few people reached out, but ultimately no one was able to help.
So after measuring up the material thickness of the OE mounts I dug through the steel pile to find some square tube that was close to the correct size.
Then I made up some paper templates from the OE mounts so I could transfer the shapes onto the material.
These mounts are made up of two separate components which aren't immediately obvious - paper templating the lower section was more difficult that I would have liked with the disadvantage that I was taking an inside measurement which I then used as an outside measurement - which kind of fucked things up a bit.
Anyway - I needed to do the lower pieces in two halves due to the material I had on hand not being exactly right;
Meh. Close enough.
Then I templated the upper pieces, marked out and cut from the stock;
I then proceeded to FLATTERZIZE them on the anvil;
  • Like 8
More hammering into shape had me a pair of things that looked like the thing they needed to look like;
More hammering, tweaking and drilling had something that looked even closer to what they needed to look like;
Got stuck in and pulled the boat anchor and transmission - then cut the R mounts off the chassis.
Swung the engine in and then fucked around for a few hours to try and get everything into the correct orientation.
Image to show mount + mounting components.
