Adoom Posted April 25, 2023 Author Share Posted April 25, 2023 Spent like 3 hours making two seat brackets. But didn't like them. I guess I'll start again. 4 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted April 29, 2023 Author Popular Post Share Posted April 29, 2023 I'm glad I decided to cut out the lumpy bits where someone had welded in captive nuts. OMG! Much better. 17 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted May 7, 2023 Author Popular Post Share Posted May 7, 2023 Before I could weld the companion boxes in I needed to sort out a mount for the seatbelt reel. The companion boxes came from a MK3 which had static belts so there is no mount for the reel. MK4 onwards had a mount like an inverted bathtub that was spot welded only to the sheet metal of the companion box. It always seemed a bit weak to me. My mounts might be a bit over-engineered. 2.5mm thick, the crush "tube" is 25mm round bar. It's spot welded to the b-pillar and welded to the inner sill with a reinforcing plate. 18 Quote Link to comment Share on other sites More sharing options...
Adoom Posted May 15, 2023 Author Share Posted May 15, 2023 And done the other side. Also stripped off some more glue and tar seam sealer off the seat panel with turps and the brass wirewheel. Buuuuuut, when I drilled the hole from the inside using the boss in the seatbelt bracket to align the drill..... I discovered that the boss is not flush with the panel like the other side. There's a 7mm gap Le sigh. Well, I'm not cutting all those welds off, I don't think the panel will survive the operation. I think I'll try slide a washer of the appropriate thickness into the gap and drill a couple small holes in the panel so I can spot the washer to it. The bolt just needs to be a little longer. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted May 20, 2023 Author Popular Post Share Posted May 20, 2023 It has a rear seat again. Like a REAL car! And a seat base still fits! 14 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted May 21, 2023 Author Popular Post Share Posted May 21, 2023 I made the 7mm spacer and tacked it in so it stays there. 11 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted January 3 Author Popular Post Share Posted January 3 I thought I'd do some work on the poor neglected mini. I took out the subframe and welded a jig for it on my steel bench so I could cut it up and weld new bits in and have it still bolt into the car. I used the plasma cutter for the first time in years and years. After cutting it up I realised that I'd mounted it too low to fit the engine in the subframe while it's in the jig. Le Sigh. I guess I can work around that by fitting the engine in the car to ballpark where stuff needs to go then use the jig for the welding. I've since added some tabs to the jig to prevent the front mounts from turning on the bolt. Right now, the big bit of the subframe is in the paddling pool full of citric acid to clean it up a bit. 14 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted January 17 Author Popular Post Share Posted January 17 The engine is pretty much in the only place it fits. With more trimming around the back of the subframe I might get another 10mm before the gearbox meets the steering rack. I'm going to step the top/front corner of the inner wing into the guard to get a little more clearance off the corner of the head. I threw some "stunt parts" in the hole to see if there is any chance this is going to work. Mounting the turbo at the front will have almost all of it in front of the grill.... But if I put it over the gearbox... There might be enough room to run the manifold under the engine, then up the back to the turbo then back down for the dump pipe. Loads of room if I top mount the IC.... interwarmer styles. Gonna need a powerful fan and vents... Only done the lower control arm mounts so far. Still got to make a bridge under the top arm mount. I trimmed the inner guards and hammered some new flanges to put some stiffness back in them. Turned out quite good! There will be a CV and driveshaft here to try get an up and down pipe around. 13 1 Quote Link to comment Share on other sites More sharing options...
Adoom Posted January 17 Author Share Posted January 17 Oh and alternator will be high mounted behind the oil filler cap, that seems to be a std solution in other K11 minis. 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Adoom Posted 3 hours ago Author Popular Post Share Posted 3 hours ago Aren't they just the cutest little wheels. So glad my fancy brakes fit. with half a gnat's foreskin to spare. I'm fairly sure they are 'straya contessa "minilites". 10" X 5" 10 Quote Link to comment Share on other sites More sharing options...
