Tidying up little bits while we wait for Distributor and Ignition Components to come back. Fingers crossed they are here before Christmas so I can work on it over the holiday period.
Shortened the Dipstick, made a more rigid mount, and replaced the O-Ringed it.
Finally mounted the Intake for the last time with the gaskets. Didn't Anti Seize them which I'm now thinking I should have.
Replaced all the Hose Clamps on the motor with the same to make servicing easier in the future, still looking for a tidier way to do the fuel lines on the carbs but I think I have that sorted. It's pretty low priority at the moment so it'll come later.
Throttle cable has been run, P-Clipped and terminated. I had a mount built for it to allow me adjustment of the lateral position of the cable end. This lets me adjust the pedal feel if I ever need to by moving the position at which the cable is pulling the throttle shaft from. Also has cable tension adjustment.
  • 5 weeks later...
  • 3 years later...
