Gator's 1982 Kp Starlet 4age
Gator
Hi Team
I recently saw the light and left the world of horizontal turbos and came back to where I belong.
after selling the legacy and sending it to Ireland of all places I quickly found this.
1982 Kp with what i think is a red top 4age.
running twin side draft 45mm Dellorto
has a cert including after market seats and was great value
Discussion Thread
  • Like 6
Good Points.
Starts runs drives
body seems quite straight - love the color
wheels are the style I like
Bad Points
The wiring is shall we say creative it works but umm how.
The springs are all cut different heights
the fuel pump in on constant feed so you need to turn it off all the time
no fuel pressure reg
fan doest cut in you turn it on
Timing is run by the efi ecu so the timing is static
Over heats in town only one small fan on the radiator
That rear bumper
when you start the car it turns over with the key forward and actually fires when you let the key go
Did some shopping this week.
2 x 10 inch radiator fans
also discovered the radiator was cable tied in on the bottom so will make up a mount to fix it to.
also ordered a hyperpak ignition module for the timing.
seemed a better option to converting to K dizzy.
ok so this weeks mission was sorting the radiator.
The fans arrived and fit on very well.  With no instructions on mounting with the kit provided I made best practice guesses. - happy with the result.
Next was to build a bracket to hold the bottom of the radiator.  The normal mounting point for these cars is a radiator with taps on the sides and you bolt it to the verticals that sit either side of the radiator.  I didnt want to get a new radiator as there is nothing wrong with the rest of this so I got some ali and went and visited a few mates.  I dont have a complete photo of it and I still need to get a two new gromets for the holes but it worked a treat and now the radiator isnt moving an inch.
Now gearing up for the next few weeks.
Spoke to Marc at Marcs Auto Electrical he is the guy that will lead me on the re wiring of it and installing the hyper pack.
he is coming around next week to get started.so I figured I might as well start making room for us to work and unwrap the silly amounts of wires that go every where. straight away found 2 wires that were about 2M long that were not connected at either end.
I also hate working under dashes and seeing as taking one out of these is a minor job did that to help with the future.
wired up the engine bay . amazing how fast someone works that has done it for a living.
Marc from Marcs Autoelectrical makes short work of looming it.
next week we will do the interior and the hyperpak pics to come when the job is all done
1 Month 2 Days till gumbootrally
Check these out thelma.
got some new shoes
15x7 +25p
they were alarmingly cheap with tires so I got them so it would be with in its cert until I can decide what to do next.
They look better than I thought pretty happy with the result.
fitment looks great and with out driving it looks like it shouldn't rub.
its the little things that count.
Last night dropped my fuel tank and fitted the battery box.
got some heat proof satin black and gave the extractors (with fitting for wide band) a buff up and a paint.
trying to do something every night so I can get it all going asap
Now I'm no sheepers with his magical glue gun and im a function over form type.
here is my way of covering the hole cut in my gear box tunnel im very happy with the result
also baring in mind there will be underseal, underlay and carpet on this so it will probably never see the light of day
also had the auto sparkie back around we are about 3 hours away from being complete everything forward of the A pillar is done now
3 weeks 2 days till gumboot rally
Fuel Pressure Reg.
as mentioned above had no puel pressure reg.  Did some hunting and Malpassi have a pretty good rep.
Webber Specs seemed a good local place to get one so after a quick discussion with the guy there I got this.
3 weeks 12 hours till gumboot rally.
Suspension.
Went with cobra super lows got a stupid good deal through a family member.
Front shocks went to SAS and found some that fitted but god knows what they are out of.
very happy with the new practicable ride height.
The Auto Sparky is booked in for monday so now to get on to the nicety's
seeing as this car is built for gumbootrally (1000km of driving in a weekend) cumfort is important to my old body.
step one fitting Teroden sp300 - its like dynamat but has more of an OEM look and is around half the price. I had a little Dynamat left over so I used that too.
I got this from Car Colors if anyone wants to use it you cut it to shape peal the backing off and use heat (a fair bit) to mold it down id suggest a two man job and allow a couple of hours but the results speak for them selves.
good time to give the car a good hose out too.
2 weeks 3 days till Gumboot Rally
The auto sparkie came around last night and we got a fair bit done.
Looks awesome again watching someone at their trade is something I am still in awe of my trade is talking so not that exciting to watch.
almost ready for start up.
quick before and after shots to appreciate the work
5 days till gumboot
HyperPak
as mentioned before I purchased a Hyperpak ignition module for the timing. reasoning was price for $330 I would retain electronic ignition. (thoughts were by the time I got a 4k one and converted it to electronic it would be a similar figure and the 4age dizzy looks nicer.
So when you get the hyperpak its a simple hook up. 6 wire hook up.
3 to the dizzy and the colors match (easy)
1 to negative of the coil\
1 to ignition and positive of the coil.
1 to earth
we hooked it all up and went to start the car and no spark.  The Hyperpak got thermo nuclear hot and I was quite frankly shitting my self with the dead line looming.
back to the instructions I checked one bit that I hadn't given as much notice of than I should have
"coil should be 3 ohms static resistance is less than 2.7 ohms will cause failure"
a quick check revealed my coil was in fact 1.2 ohm not enough resistance and I cooked it.
I sent it back to Wayne at Hyperpac and now I must plug the guy I have read people saying that e is bad at communicating and hard to deal with I had the complete opposite with him. He emailed me and then followed up with a phone call to see I had his email he worked over easter to repair the Hyper pack that had blown up and returned it to me quick smart. I really can not be more impressed with his service and his communication is fantastic.
So got it put it back in the car (with the correct coil) and boom.
Possible the smoothest idle I have seen in a carb car ever you almost want to change something to make it sound tougher.
Starts first touch of the key idles without chokes on when cold and I have only reved it to 5500 but it jumps up there like its been munching on blue pills.
will road test tonight and report the result.
also got the dash back in and the front seats (factory ones) bolted up.
All left to do is.
top up radiator with coolant
wheel allignment
a couple wires
mount chilli bin
because a update isn't right with out a photo I polished it while I was waiting for the Hyperpak to return. looks great
  • Like 9
3 days till gumboot rally
Marc from Marcs Automotive Electrical came back around last night and we are FINISHED.
starts stops charges all the dash lights work.
All thats  left to do is a wheel alignment fit the dash cluster and change the thermostat.
the classic thing is the fans are louder than the motor its classic.
and it has a nice quiet exhaust as well so on the long trips it wont be annoying.
Im wrapped all the work is about to pay off
  • Like 8
ok so in the lead up the Gumboot Rally.
thursday I took her to work to make sure it was running right turned out I had a mean water leak after taking all of the water lines off I discovered the previous owner had use fuel line and a bolt to block up some water take offs and no hose clamps so as soon as it got up to pressure it leaked.
so I used hose clamps to stop that for the weekend.
Friday morning I took her to work all loaded up ready to head to Pukekohe for the night as I pulled into work to put the window up the gear on the window winder fell apart. Luckily I found one in Waitara and got that on my way to puke.
On the way to Pukekohe I realised that the second hand wheels I had purchased had not been balanced and it was too late to get it done so I shook it all the way to Pukekohe.  On the Saturday morning while everyone registered at the start line I shot to Carters Tyres in Puke and the owner opened up early and balance all four wheels for FREE absolute legend I will be dealing with him as often as I can.
How does she run,
It starts and drives even starts well when cold and the chokes are not connected. Rich is how I would term it between 10-12 on the Air fuel guage and there is no real point reving higher than 5,000 rom the power just doesnt get any better.  But OMG its fun especially on the gravel.
It was fast enough to enjoy it all weekend and have a lot of laughes.
heres some pics of it and its friends on the weekend.
  • Like 6
Small update.
did oil filter and plugs on the weekend. Suddenly the car has life above 5,000rpm shes alot quicker now so good result.
pulled the diff out for an inspection and discovered its a U code (Larger of the ones that fits the KP housing) so thats a good result also the diff oil looked fresh and all the parts in great condition.  I replaced the oil and sealed her all back up.
Ordered the fuel pump today so she can sit on a solid 3.5psi and I can look at some tuning.
  • 2 months later...
Since the last update I had the car tuned. Tuner is saying 45mm Dellorto are too big for the factory 4age (this is what my research has found as well)
but car runs alot better he also fitted an oil pressure guage so its good to see that working.
A few of the Naki boys organised a Skid pad day so not one to say no I chucked a locker in and went and had a play.
infortunatly - Predictably - I blew an axle on the second time out (first one I used as a shake down ) so didnt really get going was still a good day out.
4age Kp
4g63 na Colt
13Bt Ke70
i think 4L escort
on the way to the skid pad I ran it for a wof - mainly so I had a fail sheet if I had trouble from the boys in blue.
most of it is easy stuff.
the brake one is what I would like some ideas on.
do I just fit new pads or should I get the booster rebuilt?
Front shocks have left to get shortened.
snapping an axle effectively removed the locker (at least my rear brakes were even)
the rest is pretty straight forward.
