Goodie's HT Monaro
goodie
OK solved. pics show it when I got it in the early 90's when they were still affordable,third photo shows motor with the adapter plate I made for the T5 gearbox. I used a V6 bellhousing  and cut the back section off, To align it properly I turned up a collar that was a gentle tap fit onto the centre holes on the bellhousing and the plate.
last photo ,wasn't supposed to be here but its a 38 Ford I built sometime in the 80's
Here's how I made the adapter .I used a commodore v6 bellhousing because they were the cheapest,I think I payed 50 bucks for it. I cut the back of it off, then milled it down parallel with the mounting face.I had to mill a small step at the bottom of the bellhousing and a matching step on the plate.To make sure it was true I turned up the collar which I made a tap fit with a rubber mallet.Then I set up the bellhousing on the mill and would centre it over one tapped hole ,fit the plate,drill and countersink it (the plate is attached with countersunk allen bolts). Remove plate, centre over the next hole and repeat.Then drilling the T5 holes all the way through the bellhousing and tapping them.
All of the information I could find on the internet said to use the Falcon T5 because the shifter comes up through the hole in the floor so that's what I bought The first photo shows the Ford T5 and the input shaft is waaaay too short to fit using my bellhousing(Aussie 4 speed to trimatic block). And you can't just get a longer input shaft because the all have a different tooth count on the end of the input shaft. Commodore v6 has the longest input shat and look where the shifter comes through the floor. The shaft had to be shortened by about 20mm from memory so I cut it , turned down the end for the spigot bearing but extending the splines was beyond me.Took it to town and one of the biggest outfits in Blenheim said "shit no we haven't got the gear to do that, we've never done anything like that". Other outfits were better but still said it was going to be bloody expensive ,one outfit quoted $100 to send it away and get the hardness taken out ,$300 to extend the splines and $100 to send away and get it re-hardened.
So I went home , thought about it for a while and made a tool and did the job myself.q1d2gllr.fxg.jpg
  • 8 months later...
About time I updated this.I got the car road legal in January and since then since then been busy on another project.Anyway another of the modifications I did was to the clutch mechanism. I wanted to convert to cable clutch to suit the bellhousing .I spent the best part of three days getting the distances right so I had good travel and was light to use.Of course most of the time spent is bolting it in and removing it everytime you change something.The end result works perfectly though unfortunately I didnt take pictures of the assembly while it was out of the car (or measurements ) but here are some pics of it in the car.post-18665-0-97782700-1438773594_thumb.jpgpost-18665-0-16741200-1438773598_thumb.jpg
After rebuilding the front end all shims went back where they came from but heres how I set toe in.I still got it reset at a wheel alignment place but this is good enough while I'm test running it.
Also a  shot of my next project. The make should be obvious but who can get the model?
