So.. can't stand not having this up and running. Am commencing (very slow) work on it, will post with updates, including pics and vids and stuff once she's going
First update. Complete exterior clean and assess..
Breaks have seized :( few spots of minor surface rust, a little bit of worrying surface rust. One Tyre won't hold air.
Here's a rough idea of how I plan to go about it (some are just dreams, this will probably take me years) ** & would like to ask some advice from forum members;
Pre-starting;
Completely tidy the interior, assess,
1. Problem/s: Won't start, no spark getting to sparkplugs, Bonnet latch cable broken, Electronic fuel pump installed needs to be wired to igt power, tyre needs replacing (can't find locknut key!! :/) - Either get a mobile mechanic out, or towtruck it to a mechanic and get these problems sorted so it is driveable. estimated cost = ?
2. Electronics burnt out, gauges/lights not going - Auto-electrician, get completely rewired, replace lights etc if blown. estimated cost = 3-400
3. Power steering leaking from both ends up of the racket - Power steering specialist, get reconditioned. estimated cost - 400
4. Assess, clean, try for a Wof
5. (far future - not in any particular order)
roof rack removed and holes stopped up
complete panel, surface rust fix, and re-paint (not sure on colour yet)
refurbish interior
new mags
professionally tinted
dropped maybe 30mm
engine replace to something with more power... 350 chev maybe (far far far distant future)
Questions for forum members;
For first lot of work Mobile mechanic or get it Towtrucked to one? Any suggestions? (prefer cheap but quality, still a student, got a bit of cash saved though) (Hamilton/Waikato)
Eventual colour?
Cheers
Pics (a few generations of megapixels in phones later..) >
Up and going now! new ignition coil, distributor rotor, have got new leads and sparkplugs haven't put them in yet, Also picked up a bosch dizzy for cheap from a 202 but it looks like I won't need it. front brakes unseized, still need to find a locknut key.. but have a few ideas how to get them off... next step bonnet latch cable fixed, then to auto electrician for rewiring (from fire years ago that took out some of the electronics)
Noted. power steering pump squealing on full lock either way. sound from diff driver rear when engaging first gear...
  • 9 months later...
All the work done so far.. and keeping going... ;
Done so far; (1-12-13 -> 15-02-14)
Replaced Ignition coil (testing bad)
Replaced Distributor Rotor
Fixed snapped bonnet release cable
Fixed choke cable
Unseized front brakes
Electrical system rewired, 1 headlight replaced
Replaced alternator (fried)
Fixed rear view mirror :D
Fixed side mirror
Replaced core plugs (after one blew) - (Favona Automotive)
Replaced Fuel line (as was splitting)
Compression Tested (160 all 6 cyl)
Transmission Tested - (Favona Automotive)
WOF Passed
Water pump overhauled - (Favona Automotive)
Block Pressure flushed out - (Favona Automative)
Sparkplugs cleaned & gapped - (Favona Automotive)
Brake Master Cylinder removed and reconditioned - (Favona Automotive)
& Brakes
Fuel Pump reconditioned - (Favona Automotive)
Engine tuned on tune scope - (Favona Automotive)
Radiator reconditioned, repainted - (Favona Automotive)
REG
(16-02-14 onwards)
Oil Change & Moreys added
Tightened all sump bolts.
Dash gauge lights fixed (Though will need further rewiring later)
Removed bull bar mounts (found a 1.5l sprite bottle of water that was the cause of a sound that had worried me rolling round under the boot tray)
Repainted dash gauge mount, rewired/tidied up
Repainted two doors where paint was flaking
Mounted Ignition coil properly
Replaced crankshaft seal which was a major cause of oil leak and in doing so found engine was missing oil slinger (old seal probly ok lol), sourced and replaced, regasketed crankshaft cover, Now no oil leaks from front of block.
Adjusted clutch cable
Replaced harmonic balancer
Sorted tappet side cover gasket, soon to be replaced to stop oil leaks.
Purchased new cobys, will get welded on soon
Replaced tappet side spring gasket.
Replaced rocker cover gasket & detailed rocker cover.
Stored 10 June. Resume work after winter.
After Winter!! 28-11-14:
Tinted 35% all round
Electronic distributor & new racing coil fitted
New air filter
Oil change & Filter
Side gasket & rocker cover gasket replaced
Windscreen wiper fixed
Gearbox leak fixed & bung replaced
<Turned into a big job of removing gearbox and drilling new hole for new sump plug as gearbox bung is... well and ... truly ... in there>
Full Tune
Repainted & Polished rocker cover
Summer WOF
Queue some more photos soon :)
