danbyran Posted April 30, 2013 Share Posted April 30, 2013 hi new here. just wondering if I can wire 4age igniters to run my seriers 2 1uz. I cant find the igniters I need. also I need a 28pin plug for the ecu if anyone would like to sell one :) thanks, Dan Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted April 30, 2013 Share Posted April 30, 2013 Not sure on the igniters but for the 28 pin you only need 5 or 6 of the actual pins . The plugs can be made from from spare ones on your motor if you have them I did this by soldering wires onto the plugs and using shrink sleeving . You need to work out what pins you use though . The proper plug would be good but is usually on the donor car Quote Link to comment Share on other sites More sharing options...
danbyran Posted April 30, 2013 Author Share Posted April 30, 2013 Thanks man i hav just used some spare female conectors. Its goin into an old school mazda so shouldnt be to hard just need to find a diagram now as the wires are not oem colours. Quote Link to comment Share on other sites More sharing options...
NVMPAJ Posted April 30, 2013 Share Posted April 30, 2013 I found belling and tracing out the wires and marking them worked for me . If your motor has the 28 pin ECU I would guess that its late model so the 4 part diagram on here or lextreme will help a lot . I printed it out joined the pages together and compared mine with the plan . Nigel's write up on here is very helpful Quote Link to comment Share on other sites More sharing options...
danbyran Posted April 30, 2013 Author Share Posted April 30, 2013 cool thanks heaps man. great website Quote Link to comment Share on other sites More sharing options...
