Guest Luke Posted April 16, 2013 Share Posted April 16, 2013 best have a thread....... bought in september 2011 for $3200. had all the desirables attached already A15 Twin sidedraught dellortos Racey cam Double valve springs Slight Port and Polished head Extractors 60a 5speed box And WOF & REG Rust done i.e. new sills and radiator support panel. Bought it in auckland and flew up, drove home with only minor hiccups considering it was unseen. needed a jumpstart in havelock, had a leaky fuel line, someone needed to have their face lit up holding carbs open to start it, and in woodend just outta chch i blew teeth h145 diff. so made it home and took to my mechanic to look over etc, joined the nzdatsun forum thanks to mint16, and had another diff/axle drum to drum within 3 days. and then......drove it home from mechanics and went to take it to supermarket......fucked starter motor and flywheel. threw a tantrum and pulled the whole car to pieces, the start of my resto began. found a LOT of rust under a pillars, so bad you could look through both sides, rear quarters, the works. since then i have sunk about 12k into it trying to bring it back to the road, when i started i knew absolutely nothing about cars, now i know how to bribe people into coming to work on my cars! so far: * all rust cut out and replaced with steel * full panel and paint (which iv scratched,dented, and just generally abused unintentionally trying to put stuff back together) * all new bushes * everything i could buy new for my steering * too many sets of wheels * reset leaves with blocks * shortened shocks * shortened springs my detailed thread is on nzdatsun.com under the most original title "lukes 1200 coupe". but il post pics up when someone tells me how! Quote Link to comment Share on other sites More sharing options...
