Guest rotornut Posted April 3, 2013 Share Posted April 3, 2013 hey, ive got a mitsi l200 and the fuel gauge reading is inconsistent, i can fill it right up drive for a bit and it will be down under 3/4, then drop to half, then come back up and so on. any ideas what the cause here is. thanks Quote Link to comment Share on other sites More sharing options...
Guest Llama Posted April 3, 2013 Share Posted April 3, 2013 Poor earth/sticky float Quote Link to comment Share on other sites More sharing options...
Guest shizzl Posted April 3, 2013 Share Posted April 3, 2013 common fault on b2000s, usually its the contacts on the sender. we just chucked another sender into the tank of our work truck.. earth your sender wire to the chassis and the gauge should go to full, no earth and itll read empty, if that works out then the gauge is sweet. Quote Link to comment Share on other sites More sharing options...
Guest coldturkey Posted April 3, 2013 Share Posted April 3, 2013 I had an issue before where the fuel gauge was reading randomly all the time. Turns out some muppet had put the float on the sender unit on it's side when they put the fuel tank back in. Quote Link to comment Share on other sites More sharing options...
