Guest kos420nz Posted April 2, 2013 Share Posted April 2, 2013 Hi, Can anyone help me Im after abit of info of what i can do in the front end of my 79 TT132 Corona Wagon . i have heard that ae86 coil overs work , but what hub and disc, rotors ? camber plates ? if anyone has any info on what fits or what is easily modified to fit . Thanks Quote Link to comment Share on other sites More sharing options...
Guest Toucan Posted April 3, 2013 Share Posted April 3, 2013 If you have the means you can modify what you have as per Seedy Al's guide here: //oldschool.co.nz/index.php?/topic/29372-seedy-als-guide-to-home-made-coil-overs-56k-u-r-fucked/ Quote Link to comment Share on other sites More sharing options...
Guest kos420nz Posted April 3, 2013 Share Posted April 3, 2013 Thanks for that , im looking to do something with the brakes aswell , cant get new tt132 rotors , plus it has to stop a ca18det . any idea if ae86 coilovers fit ? or what i have to do to get to fit . . Quote Link to comment Share on other sites More sharing options...
Guest 4AG_Addict Posted April 3, 2013 Share Posted April 3, 2013 If you feel like you need adjusties for some reason then you would be better starting with MX73 Cressida items, BC & Fortune Auto both have kits to suit. They have the same bolt spacing on the steering knuckle as the TT132, AE86 has smaller bolt spacing. MX73 brakes are larger than TT132 and also have a Vented disc from memory. MA61 Celica would also be another option to look at. Can't remember if the Tophat spacing was the same or not, but easy to just redrill that to suit anyway. 1 Quote Link to comment Share on other sites More sharing options...
Guest Celica RA45 Posted April 3, 2013 Share Posted April 3, 2013 tt132 and rt132 coronas are the same bottom platform as ra40 celicas from the skirt and rails through to the back all the bottom pick up points front and back are the same the ra40 rt132 have the bigger stub axle which doesnt flex like the ae86 1 does and also uses the 2 spot calipers on them as well can also put a spacer in the caliper for a vented disc if need be as well 1 Quote Link to comment Share on other sites More sharing options...
Guest kos420nz Posted April 3, 2013 Share Posted April 3, 2013 Awesome , thanks guys , just now need to track some parts down . great help .. Quote Link to comment Share on other sites More sharing options...
