BeastyBlue Posted May 28, 2012 Share Posted May 28, 2012 right, so im building up a pinto and have gone to the local parts place to order a new clutch, and today i get a message saying that they need to know the inside diameter of the clutchplate exact mm, i dont have a clutch to measure, so i went onto burton power and found this http://www.burtonpower.com/parts-by-bra ... 17506.html im not sure why they would ask the inside diameter, is 215MM the inside diameter? do i just ask them to get a std clutch? Quote Link to comment Share on other sites More sharing options...
Simon Posted June 1, 2012 Share Posted June 1, 2012 I'm in no way a pinto master but the pinto masters seem to have ignored you. They want to know the inside diameter because there will be a difference in pinto flywheel sizes. The bigger one will require the larger clutch plate. I'm not sure about the link you gave but spend 30 mins googling different key words and you should be able to figure something out. Specifically try to find out about variations in pinto flywheels. Quote Link to comment Share on other sites More sharing options...
