Lincooln Posted February 8, 2015 Author Share Posted February 8, 2015 More stuff. Cam is now re-ground. and the followers re surfaced. My cam guy was not happy about making the cam and the followers flat, but he did it. haha, but he did forget to press on the cam sprocket. Cam is a turbo mild road and I will post up a full cam spec card when I get it soon. It is a huge difference to the original cam, which is very cool indeed. Specs of the new cam:Looks like I will need to check the compression ratio now, as the standard one is 8.1, but the head has been ground a bit, but I feel like it will need more. And this coupled with a new turbo, should be some fun.Auckland Cams #206 I Intake duration @010”: 266 degreesExhaust duration @.010”: 266 degreesIntake duration @050”: 211 degreesExhaust duration @.050”: 211 degreesIntake cam lift: .244”Exhaust cam lift: .244”LCA: 112 degreesMild Road Turbo cam. Strong midrange and good upper rpm performance. This cam will give a slight idle. Works best with 8.5-8.7:1 compression ratio. Timing at .050” lifter rise Intake opens 4.5 deg ATDCIntake closes 35.5 ABDCExhaust opens 39.5 deg BBDCExhaust closes 8.5 BTDC Intake centerline: 110 deg ATDCExhaust centerline 114 deg BTDC Intake valve lash: .012””Exhaust valve lash: .014” Cheers Henry van VugtAuckland Camshafts Limited Old Cam Specs: Intake duration @010”: 240 degreesExhaust duration @.010”: 240 degreesIntake duration @050”: 175 degreesExhaust duration @.050”: 175 degreesIntake cam lift: .195”Exhaust cam lift: .195”LCA: 111 degrees And Because I have been asked as to hwy the followers are flat, here is an explantion: Two reason for this. firstly, this design has been proved through Numerous race motors built by Frans, and some of his reasoning is at this link:http://www.aussiefrogs.com/forum/technical-performance/89618-807-competition-motor-2.htmland secondly, looking at it from a lubrication point of view, as the follower is offset on the cam lobe (50-75% coverage of the lobe), it naturally gets a rotation going, also being flat will help induce hydrodynamic lubrication. As in when the follower reaches the top or bottom of the lobe, it draws oil under itself, which is enough to keep it lubricated for the lift/drop of the valve. The rotation insures that new oil is still being brought in under the follower and even wear is achieved.At least that is how I see it playing out... 2 Quote Link to comment Share on other sites More sharing options...
Lincooln Posted July 7, 2015 Author Share Posted July 7, 2015 Discuss: //oldschool.co.nz/index.php?/topic/31502-lincoolns-1986-fuego-turbo/?hl=%2Bfuego+%2Bturbo Yay lots have been happening. So engine was finally dis-assembled, cleaned of all the huge amount of varnish buildup. Poor old motor hadn't been very well looked after apparently. Frans helped me CC the head to check on how much need to be skimmed off. this was due to the cam needing 8.5-8.7 compression. Turns out it was all good. Took the head into the head shop, resurfaced the valves, bead blasted head, re do the valve seats, then I took block in to be cleaned properly, and a small amount of corrosion on the liner seats on 1 and 4 was discovered, so that needs to be fixed. Engine mounts are being re rubbered with solid infills to minimize twist. Radiator has been checked,cleaned and painted, starter has been rebuilt, alternator has been re built. Need to get some shim stock to make spacers for the liners. This is due to Frans machining a lip into the top of the cylinder liner, this then compressors into teh fire ring on the head gasket. providing better sealing and less chance for the liner to move and break the bottom seal. Engine will need to be painted once it is back together, also need to clean intake Manifield, paint lots of little bits and get the clutch rebuilt and flywheel machined. But it is getting there. Hopefully have the motor back in the hole before I start racing in October. Picture dump below. Pictures of Clean parts, old dirty parts and an engine block being disassembled in a lounge. 1 Quote Link to comment Share on other sites More sharing options...
