EvoBilly Posted September 25, 2011 Share Posted September 25, 2011 well ive been on the hunt for one of these for a few years now and at last i got one Specs 1978 ke35 corolla coupe more details to come i'll let the pics do the talking for now from oldest till now Note: plates in photo don't belong to the car i will be putting bumpers back on plans are to take the 4age out as need more money to finish that off and drop a k motor and box bak in get it back together and reg and wof and start using it well i get more parts together im also going to borrow some bits off my ke30 wheels etc just to use temp till can buy new ones ive gotta go through a shed full of parts to try find all the missing bits to put it back together thats all i can think off for now IDEAS? and to talk bout this project got here http://www.oldschool.co.nz/phpbb/viewtopic.php?f=18&t=29447 Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted September 29, 2011 Author Share Posted September 29, 2011 Pic-less update been on the mad hunt for parts this week ive found a guy with some bits ive gotta go look at tonite and i picked up a crossmember was told its out of a ke30 turns out its a kp60 one so not sure if its going to work can anyone tell me how much different is ae85 crossmember engine mount points from the ke35 one as its got a ae85 one in there for the 4age and that conversion is on hold i want it on the rd so just putting a k motor back in to get some use well i save up for the more costly bits also i need seat rails can anyone tell me are kp starlet ones the same or dx rolla's or any other cars got rails that will fit a ke35. oh and if anyone knows someone wrecking a c33 luarel with gray seatbelts i would like the front pair as they have the pillerless bits to hang from the roof cheers in advance for any answers to the above Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted October 3, 2011 Author Share Posted October 3, 2011 had a little play in the weekend heres a pic of the engine bay as it is at the mo it use to be super clean and shinny but its thick with dust at the mo the whole car was going to be hothouse green but the paint got used on another car so the next choice was the tin of toxic green that was there that will do for now look at changing it down the track might have to mod the guards to fit my dream wheels if i ever get them then decided to try my 13x7 superlites on got a small issue with the rear guards rubbing but the car wont be that low at wof time coz at the mo its got no bump stops and the leaf springs are bolted in upside down 15" rims look better planing on getting some dished ones i would run the supra ones but all the tyres are stuffed so the 13" got good tyres since im on a tight budget to get it on the rd can had a good car like this locked away. so half way through cleaning up inside bits to put it back together still deciding if i'll put carpet in or not as the floor is all clean with all tar removed trying to find some chrome corners trim for the rear windscreen once the window is in the car will be water tight and i can bring it back to my house and progress will be faster long term goal is to have it on the road for nats nex year ready for ROAD TRIP!! Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted October 27, 2011 Author Share Posted October 27, 2011 well been busy as trying to find all the bits i need found most bits to do the downgrade to get back on the road still nead * seat rails * engine crossmember for ke30/35/36 * seatbelts from a c33 really want gray ones thinking of finding another set of doors so i could have a set with handles also a tidy rear bumper might be on the to find cards bad part of the story shut the door tonite and the window smashed so now i need a drivers side window parts i got so far another diff with working brakes rear shocks front struts and uncut springs 4k k40 (which will have to be changed as it wont fit) door cards in the build window washer bits wiper motor bucket seats some inside trim headlights and bowls this is the new engine door cards need some stock ones to use as template gave engine bay a quick wipe down test fitting a couple old gauges new rear diff installed and leafs fliped up the right way got all new bush's in the rear end now just need some lowering blocks to complete the rear donno what the hell is going on got the uncut springs in and its MEGA 4x4 spec can fit my head between guard and wheel its BAD going to have to cut a couple coils and try keep it captive till got coin to get shorter inserts and some better springs i can understand it sitting that high with no engine but all the weight is there in the front and it goes a little higher when i jack it up need to get the front back to this with captive springs tho Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted November 6, 2011 Author Share Posted November 6, 2011 was a long weekend went on a road trip to chch to help a mate pick up his new car and well there found some needed parts for this ke35 project now for a few pics our wheels for the trip down to chch the new car both cars stoped to check tyre pressures and oil water etc for the long trip home driving through town back of the wagon loaded with my parts almost back to blenheim will do more of a update on what parts ive got in there i still need to sort out some sort of seat rails but should have everything i need to get the car together and running back on the road hopfully Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted November 9, 2011 Author Share Posted November 9, 2011 so weather has gone crap so havn't been able to fit parts yet and the only pic of bits i got is also did a deal with a guy and got this as part of the deal was told all i need to do is bolt it on put oil return into sump and longer throttle cable and it will be a runner but also should do a fuel reg if anyone has advice on setting this up tips would be good im going to have to mod it coz it seems to stack high and i don't see how it would fit under the bonnet lol not sure what it was on. Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted February 21, 2012 Author Share Posted February 21, 2012 bout time i did somthing to this so started with a lil play with a old style roof rack i picked up for a mate then it was time to get on to the real work dug out the rear bump i got with the car its in a poor state has some good classic bumper stickers but not going to go well with the rest of the car striped the front off to clean up some over sprey issues and finish some rust proffing plus pull the 4age out to put the 4k back in (so it will see the road in time for nats) I HOPE rear bumper fitted and muffler dumbyed up to see if it will do (it will pass for now) motor ready to come out and looking at sorting those front springs out asap decided 4x4 mode in the coupe not my style also i need advise on best way cost effective way to paint crossmembers so that it lasts and the plastics for inside the car thanks in advance more progress tommorrow Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted March 11, 2012 Author Share Posted March 11, 2012 time for a update been busy working on it and slack on posting bout it so ripped into it pulled the 4age out ready for the downgrade back to k mota painted up k motor cross members 4age crossmember out and k one in motor and box on crane ready to put in hole things were going real easy and good to good to be tru i knew there was a issue coming can you see what the issue is maybe a zoom in and before ya say thats easy get a bar and leaver it over and in the photo dosn't show as clear that its not even touching one side on and the other side dosn't reach so spent the nex few hrs rushing round to see people i know who might have a answer and found these both mounts are about this much wider fixing my issue motor in ready to drive to nats well maybe a lil more work to be done new coil and starting to work out some of the engine bay wires so next is to paint these bits and touch up were over spray got on the front of the car and if anyone can help with books links color codes to make this go back into the car to make is run as theres alot of cut wires i only need basics to work also anyone in the blen area or passing by wanting to help beer is on offer time is short really hoped to be working on wof by the end of the week still got alot to do for that to happen comment diss bag like here http://www.oldschool.co.nz/phpbb/viewtopic.php?f=18&t=29447 Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted March 21, 2012 Author Share Posted March 21, 2012 photos and a big update coming the car is now starting still got many issues to work through majors are fuel tank seat belt wire issue exhaust front suspension im just bout to drop the car to the exhaust place so that will be ticked off the list Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted April 1, 2012 Author Share Posted April 1, 2012 STRESS!!! appears to be no time left going to be cutting it bloody fine if i make it once the stress is gone and i have time to look throught photos i will do a photo dump in here so last nite reached a major point started engine with the key put it in gear and drove it for bout 2 mins till the carb ran out of fuel as i havn't got a fuel tank yet today at work well the boss not looking ive been building the front bumper and modding the seatbelts to try custom fit them nothing dodgy here and painting a few more bits of trim, after work im hopin to rip into lowerin the front and finishing plumbing up tank then gotta take it to finish getting welded hoping he can hav it done by tommorrow nite so far brakes and hand brake seem to work ok its going to be a long nite trying to get as much done as poss once the front is lowered all the guards and bumper etc will go bak on and bolt most of the trim in then just look at minor wof issues, wof by the weekend would be good for a road test Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted April 2, 2012 Author Share Posted April 2, 2012 Went in to town at lunch time to get some parts to work on during a slow work day and my partners bro was having a slow day and had mounted up the fuel filler on the fuel tank taken it to finish getting welded and leak tested it just have to plumb the fuel line up and got a full running car and my custom modded seatbelts appear to fit another plus so new plan for tonite sort out front end lowering little bit of under sealing adjust doors put all front end back on put some of the inside trim in and seat belts do some more wires don't think that will all get done tonite but gonna give it a good crack if i make it tonite might try a wof check tommorrow one can be hopfull Quote Link to comment Share on other sites More sharing options...
EvoBilly Posted April 6, 2012 Author Share Posted April 6, 2012 to tired after a few all niters car is going for wof check today heres hoping i can get through since im to tired to post all the details heres a lil vid questions and comments HERE!! http://www.oldschool...hp?f=18&t=29447 Quote Link to comment Share on other sites More sharing options...
