KE70 GL Posted July 31, 2011 Share Posted July 31, 2011 Discussion: viewtopic.php?f=18&t=28520Hello, figured i should join up instead of just using my brother's account all the time and post some info on my car.I used to have a KP60 with a 4EFTE race car which i sold and brought a very unloved AE86 Levin to turn into my new race car however we took it a bit too far and the car ended up far to nice to turn into a track car so heres where my story begins really.What i started withComplete from radiator to diff AE86 engine package1982 Corolla GL KE70 Rally Car Rolling BodyCar was setup to run a 20v 4age and had quite a few goodies on it:T series drum rear end with the drums removed and some Nissan rotors and calipers on it, quaife quick rack, bilstein shocks and unknown rally springs, all new bushings, oil cooler, adjustable arms, a cool homemade strut brace, aftermarket gauges, 5point belts, full cage through to the strut towers and is attached to the frame in several places, seam welded body, wilwood brake bias, hydraulic handbrake, surge tank and external fuel pump, all alloy fuel lines and handbrake lines, moded crossmember and all waterlines to suit a 20v, a rather large radiator and a 1piece driveshaftBody is very tidy for something that has been gravel bashed for the last few years, still orignal paint and i've found no rust in it.Part of the deal was that i had to return the rally wheels and tyres to the person i brought the car off so first job was to chuck whatever wheels we had sitting round on it, oh and i washed it too Pictures of the interior after i cleaned all the dirt/dust out of it Fuel setup in the bootThe first week we had the car we fitted the 4age and T50, the modded crossmember was poos so we used the factory AE86 crossmember we had and a TE71 gearbox crossmember, also took the rally suspension out of the rear and replaced it with TRD 5.5kg springs and no shocks but that didn't really matter at the time, at this stage we were still working out what to do with the front suspension The black bonnet on the car was off a twin headlite model so it fitted like shit, i ended up buying a complete front end even tho i only wanted the bonnet but hey its nice to have spares, looked much better with the right bonnet after i painted it but it still needed some bumpers Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted July 31, 2011 Author Share Posted July 31, 2011 My seats after coming back from patrick auto trimers, they are genuine Recaro SPG-N FIA approved, by far the best fixed back seats i've ever had and i've owned more race seats then i can countFinally managed to track down some bumpers but the front one only had 1 endcap Heres how the car looks as of yesterday, we fitted the front suspenion which was AE86 struts made into coilovers using 8kg springs, TRD shocks and Cusco camber plates, swaped the adjustable KE70 lower arms for some AE86 ones, also fitted my TRD shocks to the rear, Also have removed the drum rearend and fitted a factory AE86 disc rearend, oh and i found a endcap to complete my bumpers.Still need to fit my TRD 2way LSD so need to pull the rearend apart again grrrr why couldn't it arrive before we swapped the rearends over and the car must have been fitted with a k50 before as the driveshaft it came with doesn't fit in the T50 so we will be using a factory AE86 2piece driveshaftSo now the car is fitted with complete AE86 running gear/brakes/suspesion which i'm much happier with as it makes buying replacement parts easier if something breaks rather then having a bunch of mystery stuff in it, basicly we have changed almost everything that was on the car when we got it.Heres how the engine bay is looking at the moment, we ended up using the factory AE86 radiator instead of the one that came with the car, my sandwich plate arrived on Friday so i can sort the oil cooler out nowStill needs to be wiried up but we have a few complete AE86 ecus and looms so shouldn't be a major, also need to sort exhaust out. Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted August 16, 2011 Author Share Posted August 16, 2011 Bit working on this when i can, Got my RCA's fitted so front suspension is now complete, also made a new battery clamp and got the battery mounted, radiator is now mounted, sandwich plate is on and is plumbed up to the oil cooler and catch can is now mounted, only little things really but it all adds up Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted August 21, 2011 Author Share Posted August 21, 2011 Well lookie what we got here Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted August 29, 2011 Author Share Posted August 29, 2011 Painted the lip yesterday, gave it a bit of a test fit this afternoon Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted November 17, 2011 Share Posted November 17, 2011 Posting on behalf of my Bro, New track wheels arrived from Japan the other day 13x7, +1 offset Volk Mesh. Using 13's allows us to use 2nd hand TRS Slicks for certain club events May chuck on some crappy road tyres for a test fit/photos shortly/Should really finish wiring this thing & do some skids Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted September 13, 2012 Author Share Posted September 13, 2012 Got some tyres put on the Volk wheels Quote Link to comment Share on other sites More sharing options...
KE70 GL Posted October 11, 2013 Author Share Posted October 11, 2013 Ok so haven't posted about this in ages, i've fixed all the pictures links since i changed my photobucket account so everything should be working. Have been slowly plugging away with this thing but since starting my own business i haven't really been in a position to put much money into this thing lately. Engine bay as it sits now, engine is wired up and all unnecessary wiring has been removed, have gone to an electric radiator fan as the stock fan ended up being to far away from the radiator to be much use, intake has been changed and exhaust manifold fitted, also changed camber plates ECU,switches,fuses have all been mounted up inside and also have fitted a factory rev counter dash which has been repined so everything works as normal, lots of other little stuff too new wheel bearings, new brake rotors etc Picked up some more 13s which are fitted with 2nd hand TRS slicks will most likely buy brand new slicks for racing on but these will be fine for practice Of course you have to have your company name on the car somewhere 4 Quote Link to comment Share on other sites More sharing options...
