di0n Posted July 3, 2010 Share Posted July 3, 2010 I bought this recently as a quick do up only to find a lot of the parts needed replacing due to someone else's poor work. So after replacing both front hubs and struts and the rear diff it is getting close to being cert-worthy. Should make a sweet daily for a while. Anyway heres a few pics: Let me know what you think... Quote Link to comment Share on other sites More sharing options...
di0n Posted July 7, 2010 Author Share Posted July 7, 2010 Took this for a test run last night out the back roads. Cleans up cats eyes and any uneven patches in the road and leaves great trails of sparks. Needs the plate "GRADER". But handles real well and isn't very bouncy which is great. Have to sort out some issues now though as it is losing charge and couldn't handle headlights and wipers on the way home. Also it seems to be overheating at strange times. Hopefully sort all of this out this weekend though. Sorry no pictures to show. Quote Link to comment Share on other sites More sharing options...
di0n Posted July 11, 2010 Author Share Posted July 11, 2010 Good news: -Cleaned up and tightened some connections (coil was just sitting loose in the engine bay) and is running way better. -Found i have room to lift the exhaust around 2 inches which should cure my belly drag problems. -The overheating may have been an air lock or something as we managed to get another litre or two of water into it this morning and had no more overheating troubles today. Bad news: -Alternator appears to have died so I need to sort out a replacement. Quote Link to comment Share on other sites More sharing options...
di0n Posted July 30, 2010 Author Share Posted July 30, 2010 Alright so over the last week I have removed the battery cable from under the car and run it inside the car to stop it dragging on the road (battery in boot). Also had the front half of the exhaust lifted making it driveable but it has made the rear section bang on the diff every bump I hit so more work is needed sometime. Seeing it over the pit also gave me more problems. One of the axle seals is leaking badly all through one of the drums. The fuel pump is wired badly and the wiring is hanging down. And due to the exhaust shop moving my loom slightly it now had a rather big melted section where it was left sitting on my extractors. So it seems once again its one step forward two steps back. Will get more pics this weekend... Quote Link to comment Share on other sites More sharing options...
