Leaf Springs and Tramp Bars
Elmo2003
yes it stops the diff from jumping around under heavy accelerating or braking why is that
Often people ask questions without understanding the problem properly. Then the thread goes into a tail spin of spam.
I'm going to presume you have lowering blocks.
No you don't need to have reset leaves to have tramp bars/rods.
However I would recommend it. And also because it gets rid of lowering blocks.
Lowering blocks can exacerbate axle tramp.
Yep those would suffice.
But you have to get the spring height right.
Tramp bars shouldn't touch the body under normal driving conditions.
They should touch a bit with a car full of people.
If they touch with no one in the car or have a preload they send vibrations into the body and its gay.
Its better to make your own after you have got the springs reset to the height you want.
