excort Posted February 4, 2010 Share Posted February 4, 2010 hey guys does anyone know if you can wire up a megajolt to run off a hall afect dizzy? i dont want to play with my crank pully for the sensor that comes with it as it would put my balance out . cheers Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted February 4, 2010 Share Posted February 4, 2010 EDIS has a variable reluctance sensor to measure crank angle and these use the hall effect for signal. So yes, you can use a hall effect dizzy, you may need to select some different options for inputs however. Does this use a similar setup to the megasquirt ignition tuning program Quote Link to comment Share on other sites More sharing options...
excort Posted February 4, 2010 Author Share Posted February 4, 2010 yeah aparently megasquirt is very similar just does injection aswell and acouple temp sensors etc so sounds like it might be the go then. cheers man Quote Link to comment Share on other sites More sharing options...
