Mr dori Posted March 10, 2007 Share Posted March 10, 2007 CAR: 1981 toyota Soarer MZ11 repower: 1UZ-FE 4ltr Quad cam V8 250hp Weight: around 1100kg Mods Toyota Celsior front sump 1uzfe quad cam V8 Custom 4-1 extractors Custom 2-1 3" exhaust with resonator and muffler A1 turbos full billet lightened flywheel with auto ring gear sweated on A1 turbos Cast 1u-w bellhousing Link lem g3 Ecu Bosch fuel pump Suspension s13 BC/Apexi coilovers, 32way damp adjust, camber, height,spring preload adjustable custom modified front lower control arms boxed and lengthened 20mm ga70 supra tie rod ends T3 30mm RCA All new bushes front and rear (ronnie) Rear subframe modified for camber adjustment (bmw bolts) s13 BC shocks only Cut GX61 springs preloaded up removed bumpstops Locked 3.9 ratio F series 15x7.5/15x8 SW mesh wheels 15x7 SSR Takumi projects Nardi steering wheel Jeep gear knob Honda Accord EURO R recaro reliners Removed sound deadning/rear seats carpet etc Quote Link to comment Share on other sites More sharing options...
Mr dori Posted March 11, 2007 Author Share Posted March 11, 2007 My favorite soarer from japan Quote Link to comment Share on other sites More sharing options...
Mr dori Posted April 3, 2007 Author Share Posted April 3, 2007 Picked up another shell on sunday, Its a 1981 MZ11, first of the soarers. The interior is brown, its has a 5MGE and a factory LSD! It came with loads of spares too. some speed star wheels i got for it Quote Link to comment Share on other sites More sharing options...
Mr dori Posted April 3, 2007 Author Share Posted April 3, 2007 some inspiration for me.. Quote Link to comment Share on other sites More sharing options...
Mr dori Posted April 8, 2007 Author Share Posted April 8, 2007 Cleaned up the motor Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 8, 2007 Author Share Posted July 8, 2007 O.k time for a update, Ive got a custom bellhousing from a1 turbos, w57 box with a front shift (i need a rear position). got a billet flywheel to suit 9.5" clutch, also got a exedy pink tuff 5 puk clutch kit. Ive decided to make new mounts on the crossmember instead of making new ones from motor, by using the factory cast alloy ones, it looks like it will be easyer and will look abit better and will be sitting the motor vertically on the mounts rather than form the side, hopefully works out.. Also brought brand new BC coilovers for a s13 that ill adapt onto the jzx81 5 bolt struts that im putting in, felt weird cutting up brand new coilovers! Ill keep the rear 4 stud as to use all the 4 stud wheels i have, but im think a 6.5" wheel isnt gana be enough grip 4 a v8. decided to just keep it white as i CBF going hard out on body owrk incase i stack it or something, good thing ive got like 3 sets of everthing! Would love it to look like this! Quote Link to comment Share on other sites More sharing options...
Mr dori Posted July 10, 2007 Author Share Posted July 10, 2007 Trying to mod these to fit as theres not alot out there for older toyotas Quote Link to comment Share on other sites More sharing options...
Mr dori Posted August 5, 2007 Author Share Posted August 5, 2007 motor and bbow dummy bolted up checking clearance around engine, motor sits alittle forward and high but ohwell Installed a new crossmember with std mounts on it, thanks to david with a ma61! got some engine mounts from him to suit a 1uz so i will copy them and make them this week Quote Link to comment Share on other sites More sharing options...
Mr dori Posted August 12, 2007 Author Share Posted August 12, 2007 Made these engine brackets to sit engine on the factory mounts Quote Link to comment Share on other sites More sharing options...
Mr dori Posted August 12, 2007 Author Share Posted August 12, 2007 . Quote Link to comment Share on other sites More sharing options...
Mr dori Posted August 19, 2007 Author Share Posted August 19, 2007 Quote Link to comment Share on other sites More sharing options...
Mr dori Posted August 19, 2007 Author Share Posted August 19, 2007 Been at it this weekend, motor and box became 1, set up clutch with 1g fork and slave cly, 1g release bearing required a 5mm spacer to have the fork in right place. Motor now sits on factory 5mge mounts and member, Not 100% on what diff to run, factory us a 3.7 lsd, was thinking my wheels and tyres will be smaller than factory so not to sure, might throw a 4.1 locked in there and see how that goes. Also cheers to WAZ in the pic he helped me do some rust work arond the rear windows, also around boot has abit, funny how much bog you find when you start looking!! Goto be ready for the nov trackdaY! Quote Link to comment Share on other sites More sharing options...
Mr dori Posted September 25, 2007 Author Share Posted September 25, 2007 Quick update, finally got some good garage space, Started extractor making, what a bitch of a job, everything is in the way! Been doing some panelbeating in some bits also, amd got some new seats, recaro recliners from the horipito wrekers. Quote Link to comment Share on other sites More sharing options...
Mr dori Posted September 29, 2007 Author Share Posted September 29, 2007 Wheels are perfect offset! -5 with all that negative camber still fender it is hitting Good 80-90mm of dish on the 8s Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 6, 2007 Author Share Posted October 6, 2007 Drivers side extractors mostly made, abit rangi but hopefully be better than stock ones Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 26, 2007 Author Share Posted October 26, 2007 made some more progress, *Link G3 ecu is wired in, just needa suss a power relay and she should fire *passenger extractors were made *New Super pro bushes installed in front suspension *some techno toy RCA also up front Coilovers hopefully go in this weekend, and maybe fire it up! if someone can hook me up with dodgy WOF then maybe trackday! Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 28, 2007 Author Share Posted October 28, 2007 . Quote Link to comment Share on other sites More sharing options...
Mr dori Posted October 31, 2007 Author Share Posted October 31, 2007 Made these coilovers fit my soarer, suspension is the same as most other old toyotas so you could do the same0 Quote Link to comment Share on other sites More sharing options...
Mr dori Posted November 9, 2007 Author Share Posted November 9, 2007 . Quote Link to comment Share on other sites More sharing options...
Mr dori Posted January 19, 2008 Author Share Posted January 19, 2008 Update: Motor and gbox back in car, both sides of extractors made Front suspension sorted with new bushes and jza70 supra tie rod ends to suit 20mm lengthened lower control arms, Scored some Techno toy tuning roll center adjusters, to get steering paralell again. Mounted recaro drivers seat, modded rear subframe for adjustable rear camber using bolts from BMW. wired in Link G3 ecu, now trying to get it fired up. finishing some rust work and will primer bits of car next weekend. so now im concentrating on getting it back together and getting it ready for d1s Quote Link to comment Share on other sites More sharing options...
