Gaz Posted August 1, 2006 Share Posted August 1, 2006 does your car have a brake booster too? my car went from drums all round(no booster) to recond drums and mk2 disks with recond m16(standard) calipers and a mk2 booster, was an enormous upgrade, I now have wilwood 4 pots on the front on the standard disks and they are sweet as I did the same. Was huge upgrade. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 1, 2006 Share Posted August 1, 2006 yea shes got reconditioned drums on the rear and came standard with discs on the front so yup brake booster, well if the mark 2 hub will fit onto the escort stub then life is good me=hoping & praying Check front disc diameter, you may already have sport/ghia size discs in which case just put the four pots straight on and get a booster. Easy as. Quote Link to comment Share on other sites More sharing options...
escortu Posted August 1, 2006 Author Share Posted August 1, 2006 Yea i have tryed the AP's on the original discs but to no avail quite a lot of the brake pads was overhanging so that ain't good! what is the diameter of the mk2 discs you used? 240mm? Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 2, 2006 Share Posted August 2, 2006 Cant member. Will look tonight if I have time. Im sure 4 pots go straight onto the sport discs. Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 2, 2006 Share Posted August 2, 2006 250mm sport discs. AP four pots bolt straight on, no spacers needed and they bolt up to original struts. Will have to play around with hoses. Convert to 1 hose. Quote Link to comment Share on other sites More sharing options...
escortu Posted August 2, 2006 Author Share Posted August 2, 2006 ok that sounds good! yea i have got two pairs one has double input and i have another which has been changed to single so thats sweet might sell the double as not needed! i also found out today that tradeparts make rotors so if the mark 2 hub doesnt fit that can be my second option. Quote Link to comment Share on other sites More sharing options...
