Guest mike Posted August 5, 2005 Share Posted August 5, 2005 Does anyone out there have any info about The Shorrock Supercharger-I basically mean about how you set the correct timing for initial and how to use a vacuum canister to alter the timing at smaller throttle settings. I'm using a manifold takeoff but I really think I should try A ported takeoff- - Mike. - Quote Link to comment Share on other sites More sharing options...
Pushrod Posted August 5, 2005 Share Posted August 5, 2005 I think I may have a small amount in a book at home shorrock s/c set up on a pre xflow but I will have to check and get back to you What car are you running this in ? Quote Link to comment Share on other sites More sharing options...
Guest mike Posted August 6, 2005 Share Posted August 6, 2005 Its a Consul Capri 109E 1963 - -pre-crossflow. -- Mike Quote Link to comment Share on other sites More sharing options...
Pushrod Posted August 7, 2005 Share Posted August 7, 2005 Sounds good still running the 109e 1340cc engine ??? I just had a quick read and it does not have the info you need sorry just a quick overview of the shorrock kit and a bit about compresion and how many pounds boost you can run on a standard engine and a few other things you could try http://www.105speed.com a try I know neil the owner of 105speed has a shorrock supercharger on his pre xflow in a anglia van he may know or someone else on that site will. Ive been looking for a shorrock set up for ages they are very rare Quote Link to comment Share on other sites More sharing options...
105Speed Posted November 16, 2005 Share Posted November 16, 2005 Hey up Groovers... I see you're looking for info on setting up your Shorrock. Is it the C75b or the 142b ? Cheers neil Quote Link to comment Share on other sites More sharing options...
Pushrod Posted November 16, 2005 Share Posted November 16, 2005 Welcome to the site Neil Have you got a pic of the set up on your green van or is there a pic up on 105speed Quote Link to comment Share on other sites More sharing options...
