Guest Rockfordboi Posted January 17, 2005 Share Posted January 17, 2005 thanx for all the pics guys, you dont have any ideas what brake upgrades i shud be using, if im rite serreria frount discs bolt in am i rite? and do you think ill need disc braking in the rear end as well, was going to go with a toyota hilux diff but mite need a later one 4 discs? Quote Link to comment Share on other sites More sharing options...
RT Posted January 17, 2005 Share Posted January 17, 2005 Seirra discs..hmm I don't think they bolt on. You'll need something better than that anyway. BMW discs and Wilwood 4 pot calipers or Austin Princess 4 pots on the front and a hilux LSD or Falcon similar with a disc brake conversion, which means you'll need a brake bias to adjust the correct 75/25% front/rear I think. This will also probably mean you'll need 15" rims at least to fit em. Quote Link to comment Share on other sites More sharing options...
