mfordy
Posts posted by mfordy
What do you guys reckon is the best fix for the transmission mount?
I read somewhere an auto mount backwards would do the job or just fabricate a new one.
Holes are about 45~50mm out.
Next photo slightly out of focus - sorry
This has got to be the slowest build in history!..
Car's back from panelbeater de-rusted and new floor.
Rollbar and seat mounts sorted
Dummy fitting of Type E gearbox and single piece driveshaft
Front suspension nearly sorted. Just missing decent sway bar, green tie rod ends and quick rack
Off to the painters next $$$$
Nice list of bits there mate.
How do you find Burtons to deal with?
I understand we don't pay their VAT, just GST when landed - is that correct?
Either way, some of those prices are still pretty good even with the exchange rate (especially that alloy radiator)
You use PAYPAL or credit card?
Thanks
Mike
Shes a write off mate
You should have seen the Civic. Ford:1 - Honda:0
Yeah it has pinched. So whereabouts can you get new panels from??
I can't see any old ones on Tardme.
Cheers.
Palmside in Christchurch
Looking for better road handling, at the moment, the wheels are too wide so the guards rub when i have friends in the car.
Depends on what you want to do with the car and how many $$ you want to spend.
Still sorting mine out but it isn't cheap.
Will add a twin cam roll bar with double width kit to sort out the front.
Probably a 2 link with reset springs and adjustable shocks in the rear.
Turns out that the short extension housing is unique to Aussie escorts - UK readers on another forum had never seen one like this before!..
Ended up buying gearbox (not the one shown but a different listing on TM) c/w bell housing, fork, bearing and driveshaft. Unfortunately, bell housing had been modified and will require some welding to recover - maybe replace with alloy one
Just got to sort out a gearbox mount now. Was told an auto gearbox mount will fit straight in. Can anybody confirm this?
Thanks
Will be pretty much no difference between that and a UK RS2k box.Use a Hillman Avenger or Hunter clutch plate with your stock pressure plate and flywheel.
How'd you get on shortening that type 9 tail housing?. Thanks
Looking at buying this gearbox. Advertised as an RS2000 box but I think it's just a gearbox out of an Aussie 2 Litre escort. Anybody got any ideas whay clutch I'm going to need to mate this up to my pushrod? Spline count is: In 23 Out 25. Distance from bell housing to gear stick is the same as existing type 2 box so should fit straight in with a bit of persuasion around the tunnel
Thanks
Off to the panelbeaters for:
- New slam panel and front panel
- Drivers floor
- AVO strut plates
- Replace last owners bodgy repairs
Cheers man. I'm going with the T9 at the moment aye, have a new sierra clutch and have modified the escort flywheel to suit. Will also be modifying the tail-shaft on the gearbox to bring the leaver forward so I can keep the original shifter hole. Here's a couple of pics:
Really keen to hear how you get one modifying the extension housing/tail shaft - keep us posted.
You staying with a cable clutch or going hydraulic? Is that a Sierra bell housing and what fork are you going to use?
Thanks
Escort is looking good mate!..
I see from your pic, you're not using a standard escort gearbox with integral bellhousing. What gearbox you going to run? T9 5 speed or rocket?
Planning to go classic racing in 2013.
Period mods only so probable spec will be:
-1760cc Pushrod with Rocket Box
-Adjustable front suspension with capri vented disks
-TranX LSD
-2-Link Lit and lowered rear with standard drums
-Full interior plus cage
-Standard sport exterior
But the plans may change - YB after winning lotto!..
Discussion Thread
New to this forum.
Thought I'd post the current rebuild. Genuine '78 Sport that will be on the classic race scene soon - hopefully!..
mfordy Escort Rebuild
in Project Discussion
Thanks Raizer.
Anybody got one they want to sell?..
