Mr Currie
Everything posted by Mr Currie
its a B1600 diff off a rally car, its a pretty h-core LSD setup. I have 4pot fronts and will have 2 pot rears.
Rear end finally in, just needs a few spacers to tighten things up
A bit of progress this weekend. R32 Master cylinder in, snapped a brake line with retard strength so had to pinch a new one off a ae82 in picapart. Made up a 2.5" down pipe from the turbo and chucked it in
Been slowly chipping away at this, sorted the water lines and made up a dump pipe, still have to finish the rest of the exhaust tho. Got some bosch 440cc injectors and the link to run it. Heres some pics IC mounted and plumbed up Im going to get a fiberglass bonnet so i thought I would try out a rust camo idea I have... its slowly sarting to take shape, will be interesting to see how it goes. Next task is to hook up the fuel system then to get it all wired up.
Hey guys I have most of the engine part sorted now, excluding wiring. Now im looking at the fuel system. What are some of you guys using? Im looking at getting a walbro external and a surge tank, but i need a 'lifter' pump to feed the surge. Any suggestions on what pump I should get?
Its just a LEMV4 Ver4 G1. Ok wicked cheers for the info will do
oh yea, how do you adjust the duty cycle, is that done through tuning the link?
Ok so I have a link ecu now and am running a T25. I now need to match some injectors to it. I think the 440 VR4 injectors are the go, but im informed that i need high impedance injectors to work without the resistor and any larger like 550cc and it will idle crap. Im a bit clueless when it comes to this stuff haha. What injectors are you running on your AE85 kpr?
Looks wicked man!
Cool cheers, Im not using the link anymore my mate needed it back, Im using a standard 4agze ecu. I assume there would be problems with those injector upgrades with the stock ecu. Im looking at buying a megasquirt.
Also pulled my turbo off today and its fucked turbine is munted, so im looking for a good turbo to replace it. Any suggestions?
Hey team, do you think these injectors could work on my engine? http://www.trademe.co.nz/motors/car-par ... 765407.htm
Yea you can bolt the front ones right in and drill the rear, but its not centre. I did what this guy did and extended the subframe front holes an inch forward. But im thinking about just welding the subframe onto the chassis so its nice and strong. Heres some links on it: http://www.rx7club.com/showthread.php?t=967834 http://www.rx7club.com/showthread.php?t=695029
Cool thanks for the info guys, good shit!
I have no idea how to use that site. Any tips? did you go thru mark as above? because his prices will be half of retail, which they will be charging if you just walk in off street. ]Nah just walked in of the street,.
Checked at toyota, the pipe was $50 and the housing was $250! I think I will check some wreakers!
Cool thanks man! will start a wanted thread for it
Interior is a cracker!
Also what screws into this waste gate?
Yea must be, Im not to sure what suspension it has will get back to you on that And I dont know about the chassis, I dont think so tho.
Ok here are some things that need to be done to the engine and I dont know what the fucks going on in there! Whats missing from this water pump here, a reservoir? Need to sort out a dump pipe and exhuast system for this Then there is all the wiring shit to do! On a plus tho I have finished the little bogging that need to be done and now its ready for paint.
Link to run it
Its got a black top thats all I know! haha
viewtopic.php?f=18&t=33923 Discussion.
Just about finished fabricating a S4 RX7 subframe onto her
