Posts posted by BAR118
I think the biggest hole is the oil return.
The is actually a cast aluminium cradle that the blower bolts into. Although most folk dont have them. (I have the one which came with mine.
Cheers mate, when I took the charger out I didn't even see the craddle there, just taken off it off now.
- if it doesn't go i'll eat my own poo.
lol I'll get to work on it tomoro asap, it's depressing having it there and not running Again.
I'm not at home atm, but I told the mrs to put some fresh gas in and crank it lastnight as she's at home, and still got no splutter or anything. I have tried pouring a little bit of fuel in the carb and cranking and still got nothing.
Yeah I do have decent spark, I do know my timings not set perfectly but it's within 2-3 degrees of where it was when it was running.
O well I'll be home tommorrow and I have no work so I'll investigate some more when I get back.
I am getting strong spark on all plugs. It was running absolutly perfect before I had all the sludge run through my lines. When I started building the car up there was no coil, engine, subframes etc. It's running a non ballasted ignition system.
Coil, points, dizzy, plugs have done a total of 1700km so far, so all is new. Points are set correctly. It would be good to get it going cos I need to take the Jeep off the road for a bit to do c.v'z and the mrs isnt all too keen on walking (and neither am I).
YAY!!! Someone else is using the same S/c as me! I need a bit of info on mine, which of the holes on the bottom is the oil feed? Is it the one in the middle? Also how hard is to pull apart and put back together?
I'm changing over to elec ignition in the next week or so, just waiting on an ignitor from a member on here.
Always worth trying a towstart...
Tryed tow starting with the Jeep, and still got no start.
Could even be timing possibly, which 2 cylinders is it not firing on? Running Single SU or Twin?
It's actually not starting at all now after I replaced fuel lines and cleaned tank etc. I'm running single Hs4.
where are you?
In Te Awamutu mate.
Sounds like it could even be electrical especially if the spark plugs are getting wet with fuel, what are the points like? have you tried new leads? The spark plugs may not be to good either if you had dirty fuel go through. Let us know how you get on
I've checked my spark and points etc and everything electrical is wotking sweet. I'm not currently at home atm.
She's still not starting, do you reckon stale fuel would be causing it to oerfuel like this? I've changed needles, changed float valve, this is doing my head in, the bastard just does not want to run!
Dryed the carb, leaned it off and cranked it. There was less fuel sitting in the carb but it still doesn't want to fire properly (at all). Yanked out the spark plugs, theyre soaked in fuel, so cleaned them and I've got heapsa spark. Went to start cranking again and my battery's dead again so once again waiting for charger... FML
Mixture is sitting where it was when the car was running last week, I'll go lean it right off and see if I'm still getting the same thing.
Ok so Battery is charged, still no starting and I still have fuel all through the carb. I'm tossing up weather to change the needle over, but it was running perfectly before with the needle that
I put in there. What do you guys reckon?
Just took apart float valve, was nothing in there but gave it a wash and a blowout with the compressor. I also went and leaned the mix right off and went to go crank the engine but dead battery, so waiting for batt to charge.
Last week my mini decided it only wanted to run on 2 cylinders, so i spent hours messing round with my ignition and timing before noticing that my reasonably new fuel filter was basicly solid black and the fuel that was going through it was a dark brown. I took apart the float chamber and there was literally half an inch of sludge in the chamber. (Keep in mind that I have only had the car running for 1000kms or so since full over haul).
So I took out the fuel tank, fuel lines, carb and manifold out and started drowning things in meths. Replaced filter, and fuel lines and gave the carb and tank a thorough clean.
Put it all back together last night and now I have copious amounts of fuel in my carb/manifold. Anyone got any idea why I'm getting all this fuel building up?
Howsit people, new to oldschool.nz so thought I'd better post my introduction.
Cars: 2004 Jeep Wrangler sport, 5spd 4litre petrol (daily); 1980 Mini 1000 Saloon; 1979 Mini 1000 Saloon; 1993 Mazda Millenia 2.3 Supercharged (15.5psi) (daily)
Mods: 1980 Mini: freshly rebuilt 1380(12cc dished forgies, shot peened rods & crank, copper h-gasket), Twin Hs4 carbs, 3-2-1 extrators, 2.25" exhaust, reconed ancillaries Dizzy etc. 13x7 Dished UltraLites wrapped in bridgestone vGrid 50's, 4" Flares, De-bumpered, De chromed, Bare metal sand Currently primered. Simple sounds Kenwood H-deck, Kenwood 6x9's(2), 250watt Kenwood Amp, Brand new carpet and sound deadening (DynaMat), New door cards, New headlining, New custom dash panel. HEAPS more to come...
Wrangler: Stock standard (completely)
Millenia: Hard pipe intake kit 3", Turbosmart Wategate setup on I/c piping for boost limiting, 2.5" exhaust, D2 adjustables w/camber plates, DTM shines 19x9.5, Rolled gaurds front & rear, HKS boost gauge (genuine), Evo 4 FMIC.
1979 Mini; Currently getting weight reduction carried out via Donating parts to other Mini, But will be getting used in the next 6 months as I finish off first Mini.
Here's a coupla shots of BAR118
Hamilton Monthly Meet - Thursday 4th of August, 7pm
in Upper North Island Region
Anyone from te awamutu going? Real keen to come along but mrs has work til 9 and I am without a licence...
