griff666
New Members
Everything posted by griff666
  1. i have ke36 with 4age and has started popping out of fourth on deacceleration, and has started whining when take foot of clutch so im guessing that is thrust bearing, is it worn syncros causing it to pop out
  2. not sure mate how can i find that out
  3. i have a ke36 with bluetop 4 ageout of mr2, had stuffed head when i got it so got an ae85 bare engine and swapped dizzy manifolds etc over, took it to get timed up and the mechanic told me the distributor isnt advancing but he timed it anyway and now it is slower than before???
  4. i have a s2 rx4 sedan with a 12a extend port and 5 speed, and have just bought a s1 rx7 with 13b bridgeport 5 speed also, was looking at swapping the running gear over,was wondering if i will have to swap gearboxes and anything else
  5. do you know wat causes it
  6. yea that is wat im thinking but wat would cause that
  7. i have a ke36 witha bluetop 4age out of a ae86 in standard motor with 130000km extractors and a pod filter, i have trouble starting it, mostly when its cold ill have to wind over for 20 to thirty secs then it will cough and splutter some black smoke then go fine, i took out the cold start injector and its spraying good as ,the car started mint first turn when it was out but when put it back in had same problem, also i took it to get timed and the mechanic done the timing but said the dizzy isnt advancing and now have less power
