Esky_addict
Posts posted by Esky_addict
  1.
    Dont know if it was right or if it will help you at all but I used penrite HPR 10w-50 full zinc + a bottle of zddp additive on my fresh 350 chev, new flat tappet cam.
    Cut the top off a old dizzy, turned the teeth of the bottom in the lathe and primed the oil pump using a drill and tuned engine over by hand a few times. Then cranked er up to about 2500ish for 20 mins.
     https://www.staparts.co.nz/View-A-Product/ID/9526/Product/SK65622?ProductName=High zinc oil treatment with ZDDP 4 oz bottle treats 5.5 lit
  2. On 10/08/2019 at 08:28, 64valiant said:
    I spotted a video of the joker ute been used as a hearse quite a few years ago. Since seeing it I've never been able to find it again, but every now and again I go looking for it and come up empty handed other than this video.
    And today I found this one
    That ute was on display at highlands last time i was in there
  3. I put a msd dizzy in my holden, not sure if EH are wired the same but I just ran a wire from the back of an accessory fuse to the coil for when  it's running and kept the original ballast wire hooked up to power coil while cranking. I used a msd blaster aswell but any non ballast coil should be sweet.
  4. On 24/09/2018 at 14:39, kws said:
    Slowly working on getting the Mini registered. Been calling around, and have determined the vtnz is the way to go, and Vinz are rip off cunts.
    Vinz trying to charge twice as much as vtnz, and take twice as long.
    100% opposite down south. VTNZ were cunts and the VINZ joker was mint to deal with. Was just a good wof check for me, which is all a rerego is supposed to be (a side from the extra admin side of things).
    Vtnz basically said that if the car wasn't completely restored minter then it would be a fail. What's the difference their names only going to be on it for 6 months lol.
  5. Haven't load tested battery in car but starts 173 and was starting xr6t fine, the ups battery was tested when they were taken out and all the rooted ones were turfed.
    Lol yea I was oblivious to the whole impedance thing when i had the stuff in other cars I just thought that the juice couldnt keep up. Problem looks to be semi solved just buy wiring the dual voice coils in series instead of parallel.
  6. 5 hours ago, Leon said:
    You're not imagining it.
    Vehicles where there is a separate chassis with its own identifier on it, you go to VTNZ / VINZ etc (compliance place) with the vehicle, and proof that you own both identities.  They then link your body / chassis mismatch together.   They select one identity (I don't know if they use body or chassis identity) which becomes The Vehicle.  They then make behind the scenes computer notes, to ensure that the same vehicle doesn't get registered twice (so if you're using the body, they then ensure that the chassis identity isn't re-registered by somebody else using that same chassis/vin number.
    I don't know how every scenario works, as I don't know everything about it.
    For the Escort question which sparked the discussion:  no, you can't legally pull the identifiers off another shell.  Identifiers, plates, and chunk of metal with wheels all need to be from the same vehicle.  Otherwise stolen and re-identified cars would be even more common than they currently are.
    Some good info there, Yeah I realise about the hole PNT situation, car in question is a hq holden very similar to my DP pic actually... it is going for a rerego in the new year anyway but just had me thinking about the loopholes.
    I'l probably get crucified for saying this but IMO there's certain situations where pnting a car isn' such a biggie, If I know a car is legally owned as has been pntd as a means to get a old smoothie back out cruising on the road i would sleep fine at night. Victimless crime unless your a dirty theiving mongrol prick then you shouldn' be allowed to share our oxygen, I am not and am more interested in the cars than the politics. ✌
  7. Was thinking about people for example rolling a hilux and chucking a good body on then back on the road again as the same vehicle... which I see no problem with anyway just like changing a body panel panels except they change ALL of them lol.
    Or replacing a rusty chassis with a good one keeping the body's plates. Do that to a vehicle a couple times and it turns a bit like granddads axe lol
    another "hypothetical" situation is someone having a dead reg car, some live plates and a subframe which may or may not have a chassis number stamped into it which matchs the also hypothetical live plates.
  8. Oh yep sounds good. Anyone know of a good site to get some info on wiring subs up to an amp properly, I've dragged my old subs and amp out to chuck in hq, I haven't had them in a car for a few years and am not sure I had them wired up correctly, they are rockford P2D4-12 subs and a PRS-d1100m pioneer amp.
    I'e just been having a look on the net about the different ways of wiring them 1ohm 4ohm etc
  9. that' not a bad idea. would it kind of defy the point of a 2nd battery though as it would isolate the batterys when you need it like when the bass hits or am I missing something (VSR That is)
  10. Bump. These coils get me every time i need a new one.
    Holden still has factory resistor wire, went into BNT to get a new coil there options were C-80 or C-80r, I grabbed a C-80 thinking oh well if its not the right one ill just get a resistor to chuck in there but....
    Does the R mean they are internally resisted or they require an external resistor?
    I'm thinking now I'm running a 12v coil with reduced voltage hopefully causing my miss under load/acceleration
    Edit. lol just reread thread so yeah basically what threeontree said but opposite.
