michael0008
Posts posted by michael0008
yea seen that, thats crazy but i think theres some ss ones on tm for 500..
yea making them is the way to go im doing mine with 40mm id tubing , just let me know if you want the cad for the exhaust flange or intake flange as ive got them around
hey yoeddynz theres some headers around for them theres some on trademe and ebay has ss ones,but you would just have to remake the merge collector as your rwd but headers should work?
and few other companys make headers for them hotshot,pacemaker ect
At a later date I may well bolt a turbo to it but for now I want to see how economical it'll be. I think to start with I'll fit the KF 2litre. I think the KF I have lined up is a ZE model with the higher lift cams.
The 1.8 litre engine in the eunos that I am stripping out now may well be a ZE rather than a DE as well.. Not sure as I'm still learning heaps!!! Like so many bloody wires!! The vaf is a JA50 if that means anything.
yes there quite hard to tell if there a ze or a de with the kfs,k8s but easy to tell the displacment as theres a k8 or kf or kl printed in the back of the block on the left.question why don't you just find a full klze 2.5v6 one with the 10:1 comp pistons ? or do you want to stay in the 2l range ,
ps you will have to do some porting on your kf 2l heads to match the square ports on that manifold you are getting as thats to fit a klze 2.5 with the square ports
Yeah depending on what I end up with I could certainly be interested in the Ecu. The eunos has a dizzy on back with one seperate coil- basic stuff. Still not sure on ID of engine but I think only the very last mx6's etc came with a crank mounted trigger wheel and Ecu controlled ignition...?The clutch in the eunos is a brand new exedy item. In fact the car still had the boxes in the boot. hopefully it'll work but I might need a 1.8 mx5 disc to suit the rx7 box input splines.
i think they all have the trigger wheel which is a 6-1 spikes on it , also have a look at 98+ 626 klg4 2.5 ecu and ign setup if you just want a maf and obd2, 3 outputs to the coil pack and no dizzy as they have a cam angle sensor mounted in the back cyl head which would probably suit you more as your rwd ,but they only came out in the states... as for clutch i think they use the stock v6 clutch but have a Gooooogle around for klze swapped miata
I'm still not sure if the eunos K8 engine I have now is a DE. But yeah- I will have plenty of bits to play about with. I have also read that it can be wise to check the cam bearing tolerances because if too much clearence then you can lose oil pressure - some engines dropping pressure can end up with the main bearings spinning?yea ive seen that kind of makes sense as you have too much oil pressure in the head and not much down below near the 6th bearing, ill be checking all my clearances when i get around to putting mine back together..
Not exactly sure i he means just a bell housing for conversion or if one is already converted to suit? I'm still keen on keeping my rx7 box in place but will see what happens. Cheers for all your info. What cars have you had with these engines?theres a adapter around somewhere on the net for using a rx7 gbox on a kl and the spacer for the flywheel to retain the stock one and clutch setup
its alright happy to share some info , heres mine http://oldschool.co....-kfze-to-klze/
oh yes another kl swap
they can handle some boost about 8psi on a stock klze then you can upgrade the rods to 302 ones and use a oversized bearing or use KJ-ZEM rods with different wrist pins, but N/A is the way to go!
also got klze vaf/ kl36 ecu/klze dizzy with the ext coil and a brand new exedy clutch if you are after them
if you plan on going n/a look at upgrade the keepers and retainers from the klde as the ze ones are know for dropping out at higher rpm lol
nice score on those parts tho i would of loved to snap them up with the other parts ive got ,so is the bellhousing you got bolt to the kl and w55 gbox?
yes i know its sad but at the end of the day was going to be too much of a mish and sc is going to sound sweeet whinning away
oh my
just the usually setup changed again supercharger found its way on my engine
boost is back
eaton m90 sc off a ford thunderbird 3.8 plan now is to run a water / methanol setup into the roots and a water to air intercooler if i can fit it in the manifold im going to make over the week, then widen the track 2.5cm each side to match the lantis track
cant be ass with fitting the itbs and tuning and the sc got my attention. now lets see the hater comments coming
yea bpt are quite good motors all tho just get a bp from the wreckers and turbo that only difference is pistons, then get evo injectors and then do a vf10 or vf8 hybrid and you should be sweet
or get a klze if you want to get 200hp n/a but would be alot of work to fit
oh really weird , um crap cant remember what the combo was the tutor told me when i was at course last year
it was a ford courier bellhousing with another gearbox or the other way around and he had that fitted to a zetec in his track car
what wrecker you go to?
hey hey floor pans are a little different
bfmr rear subframe bolts up two holes match up and the other 2 you need to drill out and maybe weld a threaded tube in or something.
i know there a person around who has converted there bfmp to a bfmr ,driveshaft fits fine down the exhaust bit of the floor pan but was a bit close to hitting around the transfer
i was going to convert my bfmp to 4wd but no gboxs would clear the v6
that is true, got to love oldschool!
ah yes seen that! that would work sweet just have the air coming from gbox side and just get a bit grinder happy to some of the bonnet support and weld some bars in
that modeo reminds me of this lantis which has a very similar setup http://www.club323f.com/forum/viewtopic.php?f=10&t=34772&start=330
to steel and tube again for some bends next week then
i do like the above keen to give it a go! ,but wouldn't it get crazy hot like that even with heat wrapped exhaust and plates to absorb the heat?
heat is the only thing worrying about the above
pic for idea of bonnet space and where it would put the trumpets
http://i841.photobucket.com/albums/zz340/michael0008/SAM_0228.jpg
http://i841.photobucket.com/albums/zz340/michael0008/SAM_0283.jpg
but i need more room!, should just mount engine down more
i see where you guys are coming from , by the way i was just meaning the height of the factory manifold not the length of the runners.The bends would of been similar to what the sliver tops have as stock in the plenum
only thing would be worrying about having them angled would start to put plenum very close to the radiator and exhaust manifolds and entry of the ports...
yea kind of being thinking about this for awhile , quick paint drawing to show you
factory manifold comes up about 6.5inches my itb length as they are is 7 inches then going to add a curved trumpet on top to gain another 4 inches.Then have two half manifolds with panel filters on top, so will stick like out a inch or so passed the bonnet so filters will nearly be kind of flush with bonnet so good amount of cold air coming in
question would the half plenum be counted as some of the length of the runners? the plenum's are the things that confuse me :roll://i841
cheers man
that was with factory bushing in now have all Nolathane Bushings . I do see what you mean tho think it just looks like that as the front bumper wasn't bolted down .
im going to have a big play with the suspension again as not 100% happy with it, going to fit rx7 lower ball joints at the front to get 10mm more track and going to make some adjustable control arms to add another 10mm of track for the rear too as im not happy with the camber in the rear as well and might make some top hats so i can adjust caster as well
then out comes the engine again for the 80th time
one manifold done next one to go... and then got to make injector boss
41mm tube flared out to the square size of a klze port then the ends flared a mm
think i might have to chuck away my exhaust mani and remake one again as it probably will hit the radiator support...
ah update time maybe been a busy few months with moving and about to change jobs again this week so not too much done on the étude
started making some 40mm headers which will be about 22 inches long out of alot of bends, then into two 2.25 inch merge collectors then merge again into a single 2.5inch that will be merged over the gearbox .As theres no room to get both exhaust banks piping equal from under the car from the longer headers...then 2.5 inches mandrel bend pipe all the way to the back
also started making the inlet manifolds to fit the 4age sliver top individual throttle bodies , which should look sweet when done
^new labtop to tune the ms2 v3 ecu with, also got a innovate mtx-l wideband
and what else the engine is in 1000's of pieces till ive finished porting and modifying cams ect then give the engine a refreshing up
solid edge ST4 is another good free program for drawing http://www.solidedge.com/free2d/
also anyone got a 4age silver top itb cad file?
and you can always go gte easily from there later on
mazda 323 bfs have pump setups like that and theres heaps of them at pap.
think the 323 bgs have a similar setup as well
yea i know what you mean most them did it just for living costs ect, i did the courtesy ford one but was doing the paying course which was really good didn't have those other havewits around and tutor was the best....Think in 4 months we did there whole years work and was onto other stuff like a golf cart power by a 1300cc motor bike engine ,then ended up finishing my work+extra units and just worked on my car for a month or so
main problem atm most the garages are having trouble staying open
i want one its the only thing i like to do , but cant seem to find one and all those dam people from the pre apprenticeship courses they pump out every year makes its harder..
i see glad i didn't get one then, all tho would of been great to fit the battery under the bonnet
haha should of just got two and run dual batteries as there not a bad price to buy
étude "Michael0008" B6D to BPT to KFZE to KLZE
in Other Projects
oh no you again haha
not too sure whats the deal with the dizzys i think they just chucked the external coil ones on when ever they did randomly, because the kfze(2l) i had was out of a lantis type r with the lsd and it had a internal coil..
but do stay with the external coil setup as the internal ones are known for crap performance and burning out
from what i gather people use the k8 ecu and the mx3 afm which is the je50 same as the 2.5 one and loom on there klze ,as they don't have to change wiring but not used to 100% of power but still work fine.
i don't think you can use a kf(2l) ecu and afm on a klze(2.5l) as some of the wiring is different and i think the vris points are different on the ecu soo won't work so well, but the k8 vris points are closer matched to the klze(2.5l)
there how ever is a base map i have in my hands for megasquirt and theres a pnp setup out for mx3 for the klze and theres some people around that can chip the k8 ecu to match the klze.
sorry if im making it confusing with all the klze klde ect can get very confusing quick but keep posted as would love to see your one done rwd in a little viva
cheers hopefully very soon make some big progress on it and go for a drive in it for the first time in 2 years a 1 month and with the v6 those moments are very sad when i sit in it and pretend it was drivable
