Adoom
Posts posted by Adoom
  1. I've got some worn out, really old TEIN coilovers in the S14 IRS that I've got in the Triumph. I asked Driven Performance if they can supply just the rear in the new style with the adjustable body. But they say TEIN will only supply full sets.
    But they can do just the rears in either Border, or D2.
    Does anyone have experience with either of those? What's the quality like?
  2. SO MANY HOLES to fill. The seat base originally is one big panel that includes the boot floor and it would join to a forward facing flange on that vertical panel. When the seat was deleted, the forward facing flange was cut off and the join was reinforced by wrapping a long strip of steel over it down the whole length.
    But that leaves me with something like 30 spot weld holes with nothing under them.
    So what's going to be less work, filling all those holes, or welding on a new flange(which isn't straight at all) so I can weld through those holes into the new flange?
    It looks much more complete with the seat bits in there.
    • Like 8
  3. I've been stripping and derusting the donor rear seat pockets. I've also done the seat base panel, but it's basically just a flat panel.
    I used paint stripper and KBS rust blast, same stuff as metal rescue but it's a powder that you mix with water. You can see from all the tide lines, my tub wasn't big enough.
    They are just drying after I rinsed them with my outside hot tap.
    There's a little bit of paint left to sand off and some panel beating to do.
    These don't have the mount for the front seatbelt reel, so I'll have to make something.
    • Like 7
  4. 8 minutes ago, bathcollector said:
    It's going to be a stirling effort if you manage to get a 7/16 nut on a 12mm stud. I think you will be okay. have a look on Nice products site, they might have something that will work if you want to match the stud thread.
    The S300 stud is the only one that looks like it might work. I'd need to measure for the shank length, might be too long. It's also 12X1.5 so I'd have to change the rear to match. I'd prefer to buy just one to test if the taper is correct. It seems no one in NZ who sells NICE has the S300. I'd need to get it from Aus I guess, but it says I must contact them for a shipping price.
  5. So the Triumph has 12X1.25 wheel studs from the nissan IRS. And 7/16th UNF on the factory front suspension.
    To avoid cross threading when the nuts inevitably get mixed up, I want to change the front studs to metric.
    But the triumph has a tapered countersink for the head of the stud. All the aftermarket studs I've come across so far have no countersink with a flat head.
    What are my options? Can I turn a taper on a flat head stud?(I'm guessing not). Or can I just use a flat head stud as long as the knurled section is long enough to fully engage?
    Also, if I need to drill out the holes in the hub for a larger knurl, they are just straight holes right, the knurls on the stud "cut" the spline?
  6. 2 minutes ago, Tiger Tamer said:
    8mm is what the certifier told me I had to achieve when I Changed the Sunbeam tigers steering rack to a mx5 power steering rack. If I had the Toe change measured before I had pulled it apart then I would have only needed to make an improvement. I made my own bump steer bars from looking at their photos and using the measurement they gave to work out approx how long they were. I measured I had 3mm of toe change through the entire amount of suspension travel  using them and that was the same as they measured on the wheel alignment machine.
    Damn, that's a good outcome for yours. I'm going to try space the rack up further to see if it makes much difference.
  7.
    1 hour ago, Tiger Tamer said:
    I think 8mm is the maximum change in Toe you can have if you haven't had your bump steer measured before your modification. So you are on the edge there.
    Is that 8mm based on their hypothetical 575mm diameter wheel? They use that size because it makes the conversion from mm to degrees super easy. Eg 10mm is 1 degree.
    According to the LVVTA infosheets there's no fixed maximum amount of toe change that is acceptable. It depends on the vehicle. It's supposed to be "the same or better than factory".
    16 minutes ago, cletus said:
    lvvta say 10mm is generally the limit for newer vehicles or custom independent suspension
    20mm for older cars
    id think 8 mm is likely fine, and probably better than original.
    where the toe change occurs in the suspension travel is also important
    I think that 8mm was a measuring error due to the awkward way I'd previously been measuring it.
    This is what I've got so far. Spacing the rack up by 2.5mm seems to have made little difference. I could possibly go another 4mm before I have clearance issues.
  8. So the left side one is done. And it fits, thank fuck.
    The ball joint is not quite binding, there's a little left. The inner tie rod joint is binding, but this is at full droop and I intend to reduce the droop travel when I get around to making coil overs.
    I'll have to get on to trying to weld up the taper I messed up on the right side and try drill and ream it again. THEN I can see if I got the height right to fix the bump steer. If it needs fine tuning, I hope it can be sorted by spacing the rack up because I've got a little room there.
    • Like 9
  9. This is my, probably a terrible idea gonna hurt myself, e-bmx. 500W, it's got a mountain bike width rear cassette, but I bent the rear forks out and used a single speed conversion.
    It's been sitting for ages, I kinda lost motivation when it came to buying cells and making a battery. I don't really want to spend the money for an off the shelf battery.
    But I did get a spot welder that apparently is an okay one. It supposed to work best powered by a car battery, but I've not actually tested it yet. And a BMS. And some nickel strip.
    But, dad has just offered me his old battery that is supposed to just have some bad cells. Hopefully it's actually the voltage I need, and I can find appropriate cells to swap in.
    • Like 5
  10. 9 hours ago, rusty360 said:
    Please tell Me if I'm telling you to suck eggs here.
    Also remember a reamer will just follow the hole before it. If the drilled hole was a bit Oct or triangle shaped the reamer will try and do the same thing especially in a drill chuck. Have you got a boring bar for the mill?
    I learn all my machining from youtube and trial and error, advice and suggestions are welcome.
    Ah, okay, I initially just wanted to start the reamer in the drill press so it was straight and continue by hand with the big tap wrench so didn't clamp it down, just held it still, but I got overzealous with the definition of "start" and it grabbed and got a gouge in the side of the hole. I assumed the reamer would be able to clean that up, but I guess it just followed the gouge.
    I don't have a boring bar or boring head for the mill. But a boring head is on my wish list.
  11. 10 hours ago, rusty360 said:
    What's the taper angle? Have you got a mill? I'd say the prob is the reamer flexing in the chuck, needs to rigid as possible, you really wana ream down to a stop to because I'd say it's trying to pull the reamer in?
    When I say ream down to a stop I'm meaning ethier wind the knee of the mill up or use the stop on the quill and slowly work your way down. Don't try and hit it in one go. Depending on the taper angle you could step drill it to, just so the reamer doesn't have to remove so much meat.
    It's a 7 degree taper.
    https://www.amazon.com/gp/product/B07NMG3XWL/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
    Yes, I have a RF30 clone, a round column mill, so no knee, the Z axis is the quill, the whole head can be raised and lowered on the column, but it will also swing side to side so you lose any point of reference to the part.
    I have the head low enough that I can just reach the bottom of the part with the endmill. But the taper needs to be cut from the top of the part, and the reamer is 165mm long and has a shank with 3 flats on it to go in a chuck, not a collet, so that makes it even longer and it doesn't fit without moving the head. So I used the drill press to avoid moving the head.
    I guess I could just clamp the part directly to the table and that should hopefully give me enough room... And run the mill really slow. And use the fine feed, not the quill handle thing.
    It didn't feel like the reamer is being pulled in, the flutes are basically straight, not a spiral.
    It definitely flexes in the drill press.
  12. 1 hour ago, rusty360 said:
    How are you doing the taper? Tapered reamer or machining it.
    I have a reamer, it's huge, had to get it from the US, cost me over $200. :shock: It is the correct taper because it machined a perfect fit taper in aluminium.
    I did it in the drill press, so it could have been too fast, or not enough pressure... or too much pressure. I think if I figure out the problem and try clean up the existing hole, the balljoint will go in too deep.
    Early on I did try machine the taper, but it was such an awkward shape to fit in the lathe and I could not get the taper angle perfect, so I bought the reamer(the CCM says it has to be reamed anyway).
    I think I'll have to try machine some test tapers in steel until I can make a good one before I scrap another thing I spent hours machining first. I probably need to go REALLY slow.
  13. Made a couple of holes and a slot so I can cut the corner off so I've got space to fit the long 13mm drill.
    Here it is with the alloy prototype.
    I've drilled the pilot hole for the balljoint tapered hole. And milled the mounting faces to the right heights.
    Cut a corner off because I no longer need that bit as a reference surface. It takes aaaaaages to cut on the bandsaw.
    Buuuuuut, this one might be scrap :( When I reamed the tapered hole, it made an octagon and I'm not sure why. It worked fine on the softer aluminium.
    I suppose I could try build up the walls of the hole with weld, then re-drill and try cut the taper again. At least it wouldn't take as long as starting again.
    • Like 9
    • Sad 1
