Adoom
Posts posted by Adoom
  1. Gave it some fuel system cleaner(probably way more than necessary). Seems to be going a lot better now. Took it for a ride along the Hutt River trail from Totara Park down to the gate for the Trentham golf course. Was about 16km according to the gf mountain bike speedo.
    It used over 3/4 of the tank. I've not worked out how big it is, but it seems like a lot.
    How far have other people ridden their mini bikes on one tank?
    The chain came off once, but it is easy to remove the link with my keys, just annoying cause it jambs between the frame and the sprocket and makes the wheel lock up.
    Has anyone tried making some kind of tensioner thing?
  2. How strong is the mounting for the brake? Is it secured to the engine casing?????
    A stronger point would be the frame of the bike.
    There are four threaded 3/8th holes around the crank.
    I have a 25X2.5mm flat bar vertically between two of the holes.
    There is an M10 bolt welded to the plate.
    I've drawn in the plate and bolt holes and direction I think the force will go.
    This appears to be a fairly common arrangement....
    Maybe it needs the plate to go to three of the bolt holes, to cut down on the levering forces on the bracket?
    In hindsight, maybe the band should be flipped around so, when braking, it pulls on the mounting end instead of pushing on it?
    But, with the forces involved, will it really matter?
  3. It seemed to start a lot easier with a clean filter. I've not been able to test it yet, as I had only half assembled the band brake.
    I had to change the brackets on my guard so it fit with the brake.
    Not sure if the spring is required, but I had them....
    I still need a brake lever.
  4. I've ordered a clutch band brake and air filter from eBay 'murica.
    It doesn't pull consistently. It sometimes pulls good from go, but after running for a while it loses power. If I hold the throttle open it sometimes picks up. If I fiddle with the mixture screw it sometimes helps, but it eventually happens again. I was going flat out over a field and it was going well, but the revs would drop and eventually pick up again.
    It had a full tank.
    Any suggestions? Could it be the governor? It's not loose...
  5. It was raining this morning. :( No ride.
    So I made a clutch guard.
    By then it had stopped raining, bloody windy still. Pushed it over the road to the park. Went the back way to pick up my bro and nephew. We went for a hoon along the stop-bank park thing. It was a bit sluggish until I wound the power jet(?) screw out a bit. Got up to about 30kph with a tail wind. Work boots do not make effective brakes.
    Threw the chain a couple times. Seems like it stretched a bit after first use?
    Rode it back home and hosed all the mud/grass off.
    Re-adjusted the chain and gave it some proper motorbike chain lube. Also adjusted some metal where the wider chain was touching it.
    Painted the guard.
  6. Pretty sure I won't be able to fit a bicycle disk brake to the front wheel like I thought. If I space the disc out as far as I can, there is still not enough room to fit the back side of the caliper between the disk and the wheel/tyre.
    I'll have to try get the original rear caliper working. I think half of it is missing. There is no friction material, only hard plastic.
    Totally got to take it out tomorrow along the stop-bank.
  7. My sprocket arrived yesterday. I just have to get around to seeing my engineer to machine out the center hole because it's a blank with just a pilot hole.
    I attached the throttle cable and greased the throttle handle last night, then promptly broke the nipple thing off the end of the cable.(It was very frayed).
    I picked up a new brake cable from the cycle shop today to replace it with.
  8. The stand is turd. Try and find a stiffer spring for it or it will roll forward or backwards and fall over. They are long enough just not strong enough in the spring. looking good so far. Is there any movement in your headset bushes ??
    The stand was assembled in the wrong order when I got it. Spring on outside LOL.
    I put it back together with a washer between the spring and split pin. I was going to put a washer on both sides of the spring, but couldn't compress it enough to get the pin in.
    The headset bushes don't have any noticeable play. I cleaned them up and put plenty of grease in there.
  9. Made my giant 'washers', then discovered that the slotted holes in the engine plate did not line up with the holes in the engine. I wondered why it had really skinny bolts on one side.
    I had to file the holes 4mm wider! Good thing I made those washers about 50X50mm :D
    Engine is mounted now, with M8 cap screws and nylock nuts.
    That big bottom spring for the headset was a bit of a bitch to get in. They cleaned up really nice, they looked like stainless or something!
  10. Managed to find a 1/4 unf tap to fix the thread in two captive nuts, so I could put the flywheel cover on. And two replacement bolts.
    Damn hammerite is taking aaaaaaages to fully cure. So I haven't mounted the engine back in the frame yet.
    My rear sprocket is due Nov 6th.....
    I did use the polishing compound on the rusty rear mud guard.
    And pushed the headset bushes in.
    I think I could probably get a tophat mount thing machined to fit the front wheel and put a mountain bike disc brake on there. The wheel seems to be a split rim with cap screws that could be used to mount the top hat thing.
