Posts posted by Adoom
STUPID CHINA FACTORY!!!! The triangle on the fuel tap sticker is the wrong way around!!? Small end of the triangle is ON!?!
I realised this after pulling out the float drain plug and thinking the hose must be kinked because no fuel dribbles. So I turn the tap "off", and dribble dribble. HUH???
So I put the plug back in and turned the tap to "off". Engine starts first pull! SUCCESS!!!!!!! Also runs fine off choke.
Only reason it ran at all before was because there was a bit of fuel in the float bowl.
I had it on blocks so I could run it without it escaping and discovered that my chain tensioner springs need to be MUCH stiffer before I can ride it. The chain flaps all over the place.
After tinkering I know how to make these pretty quick if you want to scare yourself, mine accelerates pretty rapidly to 60ks.
Baby steps. I just want it to start easier. I want to ride further than 30m without it dying. I want to be able to ride up a slope without needing to take a full speed run at it first.
I'll have a play with it tonight.
What does the plug look like?
I'll look tonight.
does it have a low oil shutoff thats messing with your chi?
I think so. How sensitive are they to being on a bit of an angle? I could bypass it.
Any suggestions on getting my new engine to start easier? I got home with enough light for a test run, but ran out of sunlight trying to start it.
Ignition is on.
Fuel is on. Big end of triangle.
Choke is closed. Small end of triangle.
A little bit of throttle. Manual says 1/3rd.
My arm feels like it's going to fall off from pulling on the starter cord.
It caught a few times and died after a few seconds. If I tried to reduce the choke. I thought I had it. It was idling with the choke on/closed. I rode it across the road and it died. I couldn't get it to start again and it was almost dark.
I've also tried half choke, no choke, more throttle, no throttle and all combinations of those.
My old tecumseh is much easier to start(once I cleaned up the points).
If I get it started again I'll leave it idling on the choke till it's 'warm', maybe it just needs running in or something. It will fall over when running if I don't hold it...
I also need to move my fuel tank over as the filler is under the frame rail.
I have a yellow titan brand motor and the tank does not move across as easily as some of the other china copies so i am still battling to fill it....
How does it mount? Mine has two long studs off the tank that bolt to two cast lugs that are part of the engine.. And another bolt on the back that goes into a captive nut on the tank.
I used a bit of allot flat bar and bolted it to the two mounting lugs then drilled new mounting holes further towards the clutch side. The holes are slotted and open towards the front, or I could not get the tank studs in. I used some nuts and washers as spacers on the studs. I ignored the bolt at the back.
I'll take a photo at home tonight.
I made it to Supercheap 2 minutes before closing and got some fuel hose.
I had to take the tank off to get the hose on. Initially it was too long and I realised the hose was touching the flywheel :/
So I shortened it.
Then tried for AGES yanking on the starter cord and it caught a few times and tried to run away from me. I eventually got it running. But it's dark and raining. So I did a little skid in the garage.
I moved the tank over yesterday. Initially I went into the garage to return my garage chair that the gf borrowed then forgot outside. One hour later....
Everything is mounted but the fuel pipe needs to be ~40mm longer. I need to get at least 200mm of 4mm id fuel hose. Then I can go injure myself!!!!
I need to further modify the chain guard, the hole I made for the crank bolt is not big enough for the washer as well.
Sorted the throttle cable. Realised I had a fitting I could use from the original brakes to hold the cable outer.
Still needs a better return spring.
I have a clutch here for a 3/4" shaft if needed... Doubt I'll use it again...
All good for clutch already.
Mounted the engine today. Had to slot the holes about 15mm. The flywheel cover seems to be a bit more bulky than the Tecumseh, I didn't measure it though.
Ordered the chain tensioning roller wheel thing linked earlier.
I accidentally/on purpose bought a 6.5HP engine off the tard.
It basically fits...
I had to drill a hole in the clutch cover for the clutch mounting bolt to stick through.
I need to slot the mounting holes to move the engine forward a bit because the valve cover hits the mud guard. The guard is too close to the tire to move. So I'll also need a new/longer chain.
I need to make some mounting dealie bits to attach the throttle cable. It has the holes for them...
I need to move the tank a bit to the left, or I cannot open the fuel cap. The mounts are part of the tank, so I think I will make an adapter thingy.
I think that was it...
Mine are not so fancypants as others.
My stop turning you bastard flywheel flywheel turning stopper. One clutch bolt goes in the hole and it rests against one of the locating pins. To remove/tighten flywheel bolts.
My exhaust gasket bolt hole bigger maker destruction stopper.
The exhaust studs on my old engine pulled out and were replaced with much larger ones but the studs did not fit through the holes in the gasket anymore. I use this to sandwich the gasket so I can use a drill to make the holes bigger and not mangle it.
My valve stem seal holder on to..er. The cut off bolt in the other end is just to keep it aligned. I use a large spanner against the through bolt as a lever and rubber hammer handle as a pivot.
More, which seen some hole saw action
You seriously cut those with a hole saw?
What brand/make of hole saws do you have?
I have very little success hole sawing any metal. I end up with a fucked saw and a ragged hole.
Just use a sash clamp to pull the motor forward on the slots and do up the bolts. Then you won't need a tensioner
Unfortunately the center bore for the rear sprocket is off by a tiny bit, maybe only 1mm, so the chain goes tight...loose...tight...loose...
A sprung tensioner would be ideal.
Pulley Tensioner Green Chain Roller ID 10mm For Chinese 50cc-160cc Pit Dirt Bike CRF KLX SDG Go Kart Motorcycle
Might take a bit of thinking to fit it in. Unless I get a new/longer chain.
Probably the only thing TS is good for these days?
Yep. I hardly ever look at it anymore, when I do, there are SFA new posts. Where did everyone go?
Fuck yes.
I always tell the younger guys here that you'll never be upset you took too many pics (of a component before pulling to bits)
I have lots of photos, I forgot I took them. I came across it while looking at my Toyspeed project thread.
I think the diff(T-Series) I had shortened 25mm each side was from a corona. The problem with the original axles was that the diameter decreased just after the spline, so if you shortened it and cut more spline further down the shaft, part of the spline "teeth" will not be the full height.
Is that the problem you have?
I managed to find some axles from a different toyota at Pick a Part, that were a few mm larger diameter overall but same bearings, same number of splines and even 10-15mm shorter than my original ones. They machined that old spline diameter down and cut the new spline.
I can't remember what I got the axles from though, it was 10 years ago. It was a Toyota something Wagon....
According to this:
http://www.toycrazy.net/tech/diffcompare.html
It might have been an E-Series axle. The GX61 wagon looks right.
Parts for 38 year old mini bike?
in General Bike Chat
Went for a 5 minute test ride. It's cold and wet out. After doing an unintentional small wheelie on only part throttle didn't risk anything like full throttle. No problem with hills if I sit forward.
OMFG the clutch band brake doesn't inspire confidence. I can't really tell if I'm slowing down, or if I've just locked up the rear wheel.
